| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | I want to degrease the heavily crudded areas before I sandblast the frame. I have scraped what muck I could scrape off and pressure-washed the frame but the grease is still there. What degreaser do you stovebolters recommend that is economical to use and works? Much thanks, Wayne | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | "Gunk" engine cleaner works pretty good with a couple of applications and a biodegradable cleaner like "Purple Power" works pretty well in a diluted solution that you can pump through your power washer.
Drew
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | All of these work very well, especially if followed by a good power wash:
Gunk Meguiar's Extra Easy Off oven cleaner Simply Green Industrial Purple dry powder laundry soap (one wet frame & scrub brush) Kerosene (if all else fails, due to volatility)
to name a few.
Tony | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I have the best luck with Castrol Super Clean, I buy it a gallon at a time from Flaps spray it on strait with a small weed sprayer and let it set for an hour or two. Then take the pressure washer to it. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've noticed that the grease around rivits comes off real easy once I've cut the head off the rivit with a torch.
Probably not the best way or the first thing to try, but for those stubborn spots getting it good and hot will loosen it right up...
I'd hold this approach for bare frames with no fuel tanks.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Twisted wire brush on a drill works good too. It gets it down to the metal and then the degreaser will get rid of the last bit of scum. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I'm not sure why you would want to degrease when you're going to sandblast. Sandblasting will take it all off. It might take a little more time and time is money but I wouldn't think that much more. Just make sure you get a good prime coat on soon after blasting.
~Jim
| | | | | Joined: Apr 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 38 | I have used oven cleaner with good results. Using a propane torch and putty knife works too. Bill | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Putty knif and torch. Then pressure wash it with 2700-3500 psi before taking to the blaster. | | | | | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | Thanks everyone for all of the responses. I am finally getting time to work on the truck. The reason I want to degrease the frame before sandblasting is to help keep my sandblaster running better when I recover the sand. Everyone have a great day, Wayne | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | if you can locate a Buddy or a shop local that washes Big Rigs that has a steam cleaner ..?? That works wonders ! Local guys did my frame for me ...an they got 90% of the crud an 50 yr old grease off but they didnt get the underside very good as i am sure it wouldnt be a pleasant time with that HOT water blastin back at ya ...but they did a super job on the worst . | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Wayne, the Castrol Super Clean works great but a word of caution it is NOT good on skin. I cleaned up the frame and engine on my 41 and got some of it inside of the rubber gloves I was wearing and spent 4hrs in the Emergency Room and a week recovering from the 2nd degree chemical burns. I still use it but I am a lot more careful now.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I thought about the "self sandblasting" just as I hit the ENTER button. I agree, recover the sand if it's your sand.
~Jim
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Talk to a powder coating shop about having them degrease it. A friend of mine did that and said it was well worth it. They tanked the whole frame in phosphate or something like that and it removed it all. In my little experience it takes to darn long with the sandblaster and is a waste of time.
I like the oil eater they sell at Costco myself, its like 9$ a gallon as concentrate and I use it as is. Spray the hell out of it, let it soak awhile and pressure wash it and most of the grime falls off in chunks. Rinse and repeat! Good luck. | | |
