BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
8 members (IHPWR, GMCJammer51, DJHobbit'46Chevy, Danielbolt, Dragsix, RBs36, 2 invisible),
559
robot. | Key: Admin,
Mod | | Forums66 Topics126,780 Posts1,039,295 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: May 2007 Posts: 6 Junior Member | Junior Member Joined: May 2007 Posts: 6 | Hello everyone, lemme just introduce myself. I am a 18 y/o high school student who has an unaturally strong bond with mechanical things. I spent most of my childhood in my grandpa's mint condition 1960 chevy apache 10 custom with original custom camper, i guess thats where it started. Anyways i'm am looking at a couple different '60 apache's to restore, and i have a few questions.
first of all, one im looking at has the 283ci. and i was wondering how those do on power and gas. thats what my grandpa's has, but he drives it so i don't know. i am also looking at one that has the in-6.
so i was wondering how the power and gas was on the 8-cylinder, and the 6 cylinder. also i was wondering how much if any mods where necesary to put a 327cu, or evan a 350 cu with a more modern 5 or 6 speed trans.
thanks!
if you want to see the afterlife, touch my truck
| | | | Joined: Apr 2007 Posts: 146 Shop Shark | Shop Shark Joined: Apr 2007 Posts: 146 | A 6 will nearly alwyas get better gas, and a 8 will have more power. Not sure if your wanting speed power, or hauling power. I do believe up to the later 70 early 80's that most nearly any trans/ang will bolt right up, same w/rears. Of course you may need a adap kit for some. A 6 trans is better, if your running a higher geared read. If a lower geared rear, use a 4 possibly a 5 depending on the ratio's. Not much help, but it is some info. Also, you've beat me. I am 26 and I believe there is a fellow here that is 24. 18 huh, you a punk?  We dont like punks here Best of luck, and have fun!
Chey LOST1953 My favorite color is CHROME The ugliest trucks are driven by the prettiest girls  I dont suffer from insanity, I enjoy it! O Lord, WHY did I buy another "Thing"? (again??) ---- 1953 Chevy 3800 1-ton Gallery More photos at MSN ----
| | | | Joined: Apr 2007 Posts: 146 Shop Shark | Shop Shark Joined: Apr 2007 Posts: 146 | PS: The afterlife? What you should have is a stick I have on my truck
Run your fingers over my truck, and my truck run over your fingers
| | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the shop Kid, study up on the archives here and you'll have a lot of info to work with
it'd be a direct bolt-in swap to use a 327 [more 'stressed' 283] or 350 [common as dirt], but for my money the 283 is the best, plenty of power and decent mileage - also not to much involved to drop in an OD 4/5 speed
Bill | | | | Joined: May 2007 Posts: 6 Junior Member | Junior Member Joined: May 2007 Posts: 6 | ok, thanks!! i was hoping it would be that easy, i'm mostly worried about mod. the engine compartment and framework.
yeah, i want as much power i can get without losing to much miliage. from what i understand, a 350 will give me all the power i need, but i understand they are not the most effecient desighn, i might occasionally pull a trailer, but mostly just for a transport vehicle, so i'm thinking the 283 will prolly be my best bet. My brother says that if i strok it, i will get a little better torque...is stroking acutally worth it?
as far as trany's, if i get a six speed off of a 350, it will match the bell housing of the 283?
thanks!
i'm not going to drag with it or anything, but if i need to move, i want to be able to MOVE!
and no, i'm not a punk, i'm just a normal kid that spent to much time around engines and fumes growing up.
| | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | Shop Shark Joined: Nov 2004 Posts: 1,552 | ClassicCarKid:
Welcome to the stovebolt! I have several '64-'66 Chevy trucks and several have the factory 283 V8 and 327 V8. I also have a factory 292 six.
The 283 was the only V8 available in the C10 trucks up to '65. In 1966 the 327 became available. Both the 283 and 327 had relatively low horsepower ratings, as compared to the modern high rev 350's.
I feel the best factory combination is the 283 or 327 with the factory 2-speed Powerglide and factory 3.73:1 GM twelve bolt rearend. I have several factory automatic trucks and several granny-low 4-speed (SM420) trucks and the best mileage is a 283/auto (OLEBLUE). The best puller is my 292/4-speed (BIGBLUE) and the best speed/mileage/towing is (BCKNBLK).
If you are going stock, there are many good options/combinations, that will give you good overall performance. Good luck with your project and welcome aboard.
Tony | | | | Joined: Jul 2006 Posts: 707 Shop Shark | Shop Shark Joined: Jul 2006 Posts: 707 | The 283 is the best engine anyone ever built. Period. That, with a T-5 transmission from an S-10, will give you more of what you want, while easily putting up with the staggering abuse ANY 18-year-old routinely dishes out. I couldn't help it until I learned better, and neither, I suspect, can you. I know what you mean about the bond, though. Maybe you need to go highway truckin' for money, like I did. I hope you find an easier way, though . . 1951 3800 Be the change you want to see. -hotshoe
| | | | Joined: Dec 2002 Posts: 3,374 Moderator - The Electrical Bay | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,374 | welcome to the 'bolt.. dont listen to all those "old folks" dinging you on your age, heck, i'm 16 going on 47, or is it 46 going on 17?
| | | | Joined: May 2007 Posts: 6 Junior Member | Junior Member Joined: May 2007 Posts: 6 | "The 283 was the only V8 available in the C10 trucks up to '65. In 1966 the 327 became available. Both the 283 and 327 had relatively low horsepower ratings, as compared to the modern high rev 350's."
ok, thats what i was wondering... a question though, what kind of miliage do you get with your 327? lets say the "19sexy6"? (awesome name)
| | | | Joined: May 2007 Posts: 6 Junior Member | Junior Member Joined: May 2007 Posts: 6 | haha, thanks Rusty Rod. Its ok though, i'm used to it, my first major mechanical project was replacing a clutch in a super-compact kubota. If you know anything about compact tractors...its a nightmare, it was older so i didn't have a book, but i had the thing torn in half(they use the drivetrain as the framework) in about a day. Dad about had a heart attack when he saw it, but the best part was when i returned it to the farmer(who i work for). He asked dad if he had any trouble, dad told him i did it, you should have seen the look on his face!! i was like 13.
so i'm used to being heckled because of my age...
| | | | Joined: Jul 2006 Posts: 51 Wrench Fetcher | Wrench Fetcher Joined: Jul 2006 Posts: 51 | I don't think any of them are very good on gas if that's what you're worried about. My '63 is a 230 (six), and it runs so much fuel through it you'd think it had a hole in the tank. But like most old stuff, it seems like the more gas they use, the better they run. | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | Master Gabster Joined: Oct 2006 Posts: 4,983 | CCK, welcome to the bolt, we all wish we were 18 and know what we know. BTW what do we know???
~Jim
| | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | Shop Shark Joined: Jul 2005 Posts: 1,158 | Welcome aboard!
I'd go for the 283. With a 5 speed, you should be fairly decent gas-mileagewise. | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | Shop Shark Joined: Jul 2005 Posts: 1,158 | | | | | Joined: Apr 2007 Posts: 146 Shop Shark | Shop Shark Joined: Apr 2007 Posts: 146 | Hmmm.... I feel OLD now when some 18 year old comes in... I got my eye on you "kid" :blat: J/K! Welcome and enjoy, I aint near as grouchy as some of the guys in here And OLD FART? Thems fighting words, calling me a old fart...How 'bout "young" fart, I can handle that! These guys have always "got my back" so I am sure they will adopt you under their wing as they did me. And I too, will adopt you under my wing and help you, the best I can! This is a bunch of kewl folkes!
| | | | Joined: Nov 2006 Posts: 677 Shop Shark | Shop Shark Joined: Nov 2006 Posts: 677 | Welcome to the bolt Bro !! Doesn't matter if your 18 or 24 or 26 or 43 "like me" even as old as Rusty Rod 47 ! Lol !! It's all the same street man!! As long as it's in a Bowtie !! Ive ran 283's, 327's, 350's,and my recent install a 454/TBI in my 1986 C20 Tow Rig.(now that's what Im talkin about) It's all in how YOU want to do it ! At this point and gas reaching $3.26 a gallon (here in Vegas) Whats it gonna matter ? Build it ! Drive the hell out of it ! and when it breaks (and it will) Fix it ! Just remain seated & keep your hands and feet inside the ride at all times ! WELCOME ABOARD LITTLE BROTHER !! Your in safe hands here at The Bolt! you'll find out some good info, Good people, Buy & Sell Parts, and best yet you ll make some GREAT FRIENDS !! As Joker told me a while back when I needed a few kind words "This is the real deal"(Thanks Fred) The Stovebolt Page ROCKS !! It all fun and games till someone gets punched in the eye ! Lol!! See ya !! Todd ( lost1953: still lookin for a neighbor with a camera ? ) Ha Ha !! "just kidding"  Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | Joined: Oct 2006 Posts: 166 Shop Shark | Shop Shark Joined: Oct 2006 Posts: 166 |
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | Shop Shark Joined: Sep 2006 Posts: 1,276 | Welcome aboard you've come to the right place.
Hey Lost1953 be proud to be an old fart FATHERS AGINST RADICAL TEENAGERS. Ha Ha
My life is full of shoulda wouldas' and couldas' and the older I get the more useta coulds' there are. | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | Shop Shark Joined: Dec 2003 Posts: 1,554 | Yeah,welcome to the bolt.Hey I was 18 yrs.old about 51 yrs.ago.Another thing to consider is the rearend gearing.you can run just about any engine you want and get good gas mileage if it is geared right.I am running a 350 in my 55,along with a 700R4 tranny and the original 3;90 rearend.Due to the OD tranny ratio it is turning about .78 to 1 to the rear.If I was using a non OD the ratio would be 1 to 1,and I would probably want a 3:08 rear to compensate.My 55 gets 20 MPG all day long ,has great pickup and will cruise at 70 to 80 MPH.So as you can see there are many combinations,to consider.As far as 283s,327s,and 350s there aint a whole lot of difference.The 350s are probably more plentiful. | | | | Joined: Mar 2005 Posts: 311 Shop Shark | Shop Shark Joined: Mar 2005 Posts: 311 | Welcome to the BOLT! This place has ALL the answers to ANY question you may have.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | Joined: May 2007 Posts: 6 Junior Member | Junior Member Joined: May 2007 Posts: 6 | Thanks dale937! i looked at your pics and a really nice truck!! What carb. are you running on that 350? I was thinking i would try to find a 6 speed manual, i cam across one with a .63 OD. but feirc expensive.
also, would anyone know what the factory gearing would be on a 1960 chevy pickup, with the 6 cylinder three speed?
thanks!
| | | | Joined: Jul 2006 Posts: 707 Shop Shark | Shop Shark Joined: Jul 2006 Posts: 707 | Grant from Roy;
The older I get, the better I was.
Mark 1951 3800 Be the change you want to see. -hotshoe
| | | | Joined: May 2007 Posts: 6 Junior Member | Junior Member Joined: May 2007 Posts: 6 | another question: Where can i get glass for my truck? (1960 apache 10) since this is my first project so i dont know all the good places to get the antique parts and stuff...
| | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | Shop Shark Joined: Jun 2005 Posts: 1,756 | Gee, Isn't it fun to have a kid all pumped up with the enthusism we had at that age. WoW makes me feel like a kid again. Kid do any darn thing you feel, like, and can afford. the 283 will be a fine engine till you get enthused and move up. Probably get the best mileage too. the T 5 will be the most economical for you now. a 6 speed would break the bank unless daddy is financing this project. Make it run good and go from there. You have a lot to learn and it is going to be so much fun I am green with envy. I wish you the Best. | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | Shop Shark Joined: Jun 2005 Posts: 1,756 | A P.S. there are lots of links here at the bolt for the resto parts you need. | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | Master Gabster Joined: Oct 2006 Posts: 4,983 | Classicarkid: Glass is the one thing that is not antique. I would look for glass at your local auto glass shop. They have what you will want, even tinted. Also they can cut and install it professionally.
~Jim
| | | | Joined: Jan 2006 Posts: 74 'Bolter | 'Bolter Joined: Jan 2006 Posts: 74 | hey welcome to the bolt, good people here, ive learned tons about my truck from this site.
and hey your not the youngest one here im only 17. good luck with your project.
mines almost finished, i need to get some pics on here. | | | | Joined: Mar 2007 Posts: 864 Shop Shark | Shop Shark Joined: Mar 2007 Posts: 864 | Lost 1953: I'd rather be an old fart than a fresh fart  | | | | Joined: Mar 2007 Posts: 2,993 Crusty Old Sarge | Crusty Old Sarge Joined: Mar 2007 Posts: 2,993 | CCK don't let these old Farts razz you to much, we'er all 18 at heart, some are younger than that. The first truck I ever drove was a 60 Apache with a 283 4 spd so I'm right there with you. My son just turned 13 so I get to go through it all over with him. I'm a big fan of the little V8's, 283 was probabaly the best all around SBC that GM ever produced. They are getting a little rare but can still be found. Best of all you can still find parts, and most of all the parts interchange with other SBC's. These are some great folks here and they won't steer you wrong. Good luck and welcome to the "BOLT".
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) Come Bleed or Blister, something has got to give!!! | Living life in the SLOW lane | | | | Joined: Sep 2005 Posts: 191 Shop Shark | Shop Shark Joined: Sep 2005 Posts: 191 | My first car was a 64 Impala with a 283 and a 2-speed powerglide, it had 3.08 gears in the rear and got right around 21-24 miles to the gallon. A 283 with a T-5 and 3.55 gears would probably do real well as far as mileage and power. Good luck with it, sure wish I'd had access to a site like this when I was 18! | | | | Joined: Feb 2002 Posts: 2,877 Socket Breaker | Socket Breaker Joined: Feb 2002 Posts: 2,877 | ClassicCarKid,
welcome. Read a lot, ask questions and help out when you can. A key to getting your questions answered is to come up with the right topic. Some folks know about about certain body style trucks, or some know more about the inline sixes than the v8's. So if relevant, put in the year model, class(1/2, 3/4) and engine in the topic. Then the people who know something about those will click on your post.
have fun,
-W | | | | Joined: Feb 2006 Posts: 222 Shop Shark | Shop Shark Joined: Feb 2006 Posts: 222 | Hotshoe36, I like that line, "The older I get the better I was" I tend to embelish stories more each time I tell them! Hi ClassicCarKid! I am a little over 18, and don't know nearly as much the others, but I welcome you! Rick | | |
