| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | Seems like everything I fix has 2 or 3 repercussions. I really want to go back to tube tires right about now. I've just realized there's a 2" wide strip rubbed off on the inside of both front tires. The back tires are being rubbed by the Emergency Brake Cable and I just can't seem to bend those back to stay in place. I really regret having changed the tires - they are far to wide/fat for this truck. | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Oldblue58,
You have my sympathy.
What is the condition of your rear spring shackles?
I had a similar problem when I first purchased my truck. Tires rubbed... not on the emergency cable, but on the frame. Previous owner bought wider tires,in conjunction with old floppy shackles.
I replaced the shackles which helped. However, I got rid of the radials and I am currently running bias plys.
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Connect a long spring to the cable and run it to the frame to hold the cable away from the tire, Scott | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | does your e-brake work? if no do what i did-cut it off, i severed the cables right up next to backing plate, removed e-brake components, at first glance you wouldn't be able to tell of an modification or sounds like you'll have to go back to the perious size tire 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | what was the original tire size? I'm looking for oem sized whitewalls for my '58 GMC shortbox stepside. | | |
