0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#230258 03/25/2007 11:05 PM
Seems like everything I fix has 2 or 3 repercussions. I really want to go back to tube tires right about now. I've just realized there's a 2" wide strip rubbed off on the inside of both front tires. The back tires are being rubbed by the Emergency Brake Cable and I just can't seem to bend those back to stay in place. I really regret having changed the tires - they are far to wide/fat for this truck.
1958 Chevy 1/2 ton Apache Stepside Longbed
Never trust a driver with a collision shop courtesy car
Photo Album
#230259 03/25/2007 11:40 PM
Oldblue58,
You have my sympathy.
What is the condition of your rear spring shackles?
I had a similar problem when I first purchased my truck. Tires rubbed... not on the emergency cable, but on the frame. Previous owner bought wider tires,in conjunction with old floppy shackles.
I replaced the shackles which helped. However, I got rid of the radials and I am currently running bias plys.
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
#230260 03/26/2007 2:13 AM
Connect a long spring to the cable and run it to the frame to hold the cable away from the tire,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#230261 03/26/2007 4:16 AM
does your e-brake work? if no do what i did-cut it off, i severed the cables right up next to backing plate, removed e-brake components, at first glance you wouldn't be able to tell of an modification grin
or sounds like you'll have to go back to the perious size tire
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#230262 03/27/2007 6:37 AM
what was the original tire size?
I'm looking for oem sized whitewalls for my '58 GMC
shortbox stepside.
GMC: Get More Cash...
1958 GMC
My Webshots photos
