7 members (baldeagle, Hush, mick53, Southerntruck, SmalltownTRKGuy, Hotrod Lincoln, Gray_Ghost),
102
15
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I was drivin the 53 (3 spd, 216) around today and theres a weird noise coming out from under her. It kinda sounds like 2 pieces of sheetmetal perpindicular to each other screeching against each other.
I crawled underneath it, cant find anything loose. Shes done it in the past and it hasnt effected the drive but Ive never known a screeching to be a good thing? Kinda sounds like it coming from the rear.
No growling, howling, ticking or anything else. Any ideas???
Thanks, Jeff | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Jeff, I had a similar sound this summer.
My problem was front wheel bearings. I would suggest inspecting your wheel bearings.
Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Brand new wheel bearings. I know what they sound like when they go and this isnt close. Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Possibly a flywheel cover rubbing the flywheel. Loose baffles in the muffler? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Maybe it's the muffler bearings. JK. U-Joints? | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Or rustednuts
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Bigmac, you reminded me Ive got to go check my blinker fluid... The mufflers rusted out on the inside so Im pretty sure its not the baffles. The Ujoints dont have that characteristic clunky noise when going from a stop to accel or accel to stopping fast. It also doesnt do it all the time. It almost seems like it does it more when stopped then accelerating and turning, or when upshifting into 2nd while not quite going fast enough. ??? Jeff | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it's repeatable have someone drive the truck over the stretch of road where the noise is heard while you ride in the back listening for the location. Sound can travel and what/where you think you hear may not be the case. Back in the '60s I worked at a dealer who employed a fellow full time to work only squeeks, rattles, wind noise and water leaks. It was amazing how he had the knack for tracking these things down. I remember seeing him hanging out of a car door with his head almost hitting the street trying to locate a sound underneath. Often a customer would complain of a noise "in the dash" that was actually originating somewhere else in the car.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Have someone else drive her, NEVER! Good idea, although the wife is a little scared to learn the 3 on the tree. I guess its time. Bruce K, I checked, and yes my nuts are just fine. I was still hoping someone else had experienced something similar... Thanks, Jeff | | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | Check body mounts. I had to fix a guys F word when the radiator support rotted out at the body mounts. Caused the cab to flex off the frame giving it a sheet metal scraping sound. Only did it going over uneven ground. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | While you're under there, check the bed mounts. I had a similiar noise I tracked back to being a loose bed mount.
It allowed the bed to tweak and squeak in certain situations. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | are your brake backings bent into the drum a bit?
possible you have a loose flywheel?
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Check the belt/belts and throwout bearing. If that doesn't work, drink a 6-pack before you head out. You won't hear a darn thing.
delete my account and pictures
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I had a bad noise going on in my Subaru and I was sure it was the rear diff. So did 2 mechanics. Turned out to be wheel bearings on all four. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Check the pinion bearing. Mine made some noises I might have described the same way as it failed. It quickly got worse.
Hey I'm headed out of town, but you could invite bigmacdaddy over to ride on the back or underneath to listen while you drive it trying to make the noise.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Does this always happen or just over bumps and such? Could it be suspension? I had an elusive noise which ended up being the shackle bolts/bushings. Changed them and it went away. | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Underneath  I better start working out. | | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | check the bearing in the generator. mine went out and it made a similar sound to what you are describing. | | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Well, it could be loose/broken fender supports. | | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | rustednuts, the nut holding the pinion flange to the pinion on my truck had worked itself loose on my '58 and was causing alot of vibration and noise, especially at low speeds while accelerating and shifting. No problem at high speeds. | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | My clutch pedal screeches when it gets used. The pedal is rubbing on the toeboard because my cab mounts are less than ideal.
How are your cab mounts? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | So after tearing apart the tranny and rear end, The pinion bearing is the winner!
Totally and completly shredded to pieces, it only has about 8 ball bearings left. I guess i should be happy it lasted a good 54 years now...
I guess its time to order that 3.55 set of gears and enjoy going more then 50 mph. Darn I have to order more parts.
Jeff | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Glad you finally got it figured out but sorry you had to go to such extremes to find it. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | And I was going to say pinion bearing. | | |
