4 members (Gdads51, KEVINSKI, 2 invisible), 96 guests, and 1 robot.
Topics128,094
Posts1,056,060
Members48,433
#217625 10/12/2006 10:20 PM
I was drivin the 53 (3 spd, 216) around today and theres a weird noise coming out from under her. It kinda sounds like 2 pieces of sheetmetal perpindicular to each other screeching against each other.
I crawled underneath it, cant find anything loose. Shes done it in the past and it hasnt effected the drive but
Ive never known a screeching to be a good thing? Kinda sounds like it coming from the rear.
No growling, howling, ticking or anything else. Any ideas???
Thanks, Jeff
My 1953 Chevrolet
1947.1 Gallery
Jeff, I had a similar sound this summer.
My problem was front wheel bearings. I would suggest inspecting your wheel bearings.
Greg
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
Brand new wheel bearings. I know what they sound like when they go and this isnt close. Thanks
My 1953 Chevrolet
1947.1 Gallery
Riding in the Passing Lane
Possibly a flywheel cover rubbing the flywheel. Loose baffles in the muffler?
1972 Chevy c10 Cheyenne Super
Maybe it's the muffler bearings. JK. U-Joints?
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Or rustednuts eek
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
Bigmac, you reminded me Ive got to go check my blinker fluid...
The mufflers rusted out on the inside so Im pretty sure its not the baffles. grin
The Ujoints dont have that characteristic clunky noise when going from a stop to accel or accel to stopping fast.
It also doesnt do it all the time. It almost seems like it does it more when stopped then accelerating and turning, or when upshifting into 2nd while not quite going fast enough.
??? Jeff
My 1953 Chevrolet
1947.1 Gallery
Ex Hall Monitor
Ex Hall Monitor
If it's repeatable have someone drive the truck over the stretch of road where the noise is heard while you ride in the back listening for the location. Sound can travel and what/where you think you hear may not be the case. Back in the '60s I worked at a dealer who employed a fellow full time to work only squeeks, rattles, wind noise and water leaks. It was amazing how he had the knack for tracking these things down. I remember seeing him hanging out of a car door with his head almost hitting the street trying to locate a sound underneath. Often a customer would complain of a noise "in the dash" that was actually originating somewhere else in the car.
Have someone else drive her, NEVER! eek
Good idea, although the wife is a little scared to learn the 3 on the tree. I guess its time.
Bruce K, I checked, and yes my nuts are just fine. grin
I was still hoping someone else had experienced something similar...
Thanks, Jeff
My 1953 Chevrolet
1947.1 Gallery
Check body mounts. I had to fix a guys F word when the radiator support rotted out at the body mounts. Caused the cab to flex off the frame giving it a sheet metal scraping sound. Only did it going over uneven ground.
1965 Chevy C-10 Longbed Stepside
Jed Offline
While you're under there, check the bed mounts. I had a similiar noise I tracked back to being a loose bed mount.
It allowed the bed to tweak and squeak in certain situations.
are your brake backings bent into the drum a bit?
possible you have a loose flywheel?
Another quality post.
Real Trucks Rattle
Tab Offline
Check the belt/belts and throwout bearing. If that doesn't work, drink a 6-pack before you head out. You won't hear a darn thing.
delete my account and pictures
I had a bad noise going on in my Subaru and I was sure it was the rear diff. So did 2 mechanics. Turned out to be wheel bearings on all four.
My Webshot Photos]
Check the pinion bearing. Mine made some noises I might have described the same way as it failed. It quickly got worse.
Hey I'm headed out of town, but you could invite bigmacdaddy over to ride on the back or underneath to listen while you drive it trying to make the noise.
Does this always happen or just over bumps and such? Could it be suspension? I had an elusive noise which ended up being the shackle bolts/bushings. Changed them and it went away.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Underneath eek I better start working out.
My Webshot Photos]
check the bearing in the generator. mine went out and it made a similar sound to what you are describing.
Well, it could be loose/broken fender supports.
rustednuts, the nut holding the pinion flange to the pinion on my truck had worked itself loose on my '58 and was causing alot of vibration and noise, especially at low speeds while accelerating and shifting. No problem at high speeds.
My clutch pedal screeches when it gets used. The pedal is rubbing on the toeboard because my cab mounts are less than ideal.
How are your cab mounts?
So after tearing apart the tranny and rear end, The pinion bearing is the winner!
Totally and completly shredded to pieces, it only has about 8 ball bearings left. I guess i should be happy it lasted a good 54 years now...
I guess its time to order that 3.55 set of gears and enjoy going more then 50 mph. Darn I have to order more parts.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Glad you finally got it figured out but sorry you had to go to such extremes to find it.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
And I was going to say pinion bearing.
