Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Hotrod Lincoln, ShopRag, 59 fleet, Otto Skorzeny, Gdads51), 58 guests, and 1 robot.
Topics128,009
Posts1,055,291
Members48,419
#211643 07/12/2006 9:10 PM
1 Offline
alright so the frame shop told me my frame on my 63 c10 is toast. i was rear ended a few monhts back and finally got the insurance check and got it to a frame shop. so i need a new frame. id like to know what other frames for my 63 will fit it. i figured it would be 60-66 since basically everything else from those years is interchangeable. also, are there reproduction frames for 63 trucks? anyway thanks in advance for any help.
patrick
63 Chevrolet Short Fleetside
64 Chevrolet Long Stepside
http://community.webshots.com/user/64stepside
#211644 07/12/2006 9:18 PM
Riding in the Passing Lane
No. 60-62 had tortion bars for front springs. 63-66 should fit. There are 2-3 different lengths. You will have to find it in salvage. I dought anyone has a new one.
1972 Chevy c10 Cheyenne Super
#211645 07/12/2006 9:22 PM
The frame is probably the same for the 1960-1966 models, but I am not 100% sure.
#211646 07/12/2006 9:22 PM
1 Offline
hm ok thanks. i know mines the shortbed so wouldnt i just need a frame off a c10 shortbed?
#211647 07/12/2006 10:14 PM
There's some disagreement on whether the front crossmember bolts up the same between torsion bar/spring versions. To keep it simplest, stick with 63-66. Unless you want to switch to torsion bar, but that gets more involved.
Brian
#211648 07/12/2006 10:21 PM
The frames from 60-62 are completely different as are the suspensions on them. They are an "x" style drop frame as opposed the the newer "ladder" style frame they started using in 63. They used that style until 87 or so I've read. The front crossmember on the "x" frame is part of the torsion bar system and is also very different from what's on a truck with coil springs. You should have a lot of years to choose from. Obviously, the best fit will be 63-66.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#211649 07/12/2006 11:32 PM
What bigmacdaddy and others said....
In Addition the frame rails are further apart in 60-62.
Thats why you cant use 60-62 bumpers on a 63-66 truck,Front Or Back
Though they Look the same VISUALLY,
The Bolt holes dont line up wink
#211650 07/12/2006 11:39 PM
1 Offline
ok cool thanks everyone. i found a rolling frame on ebay that will fit but its a longbed, and its in amazing condition the guy sandblasted it and painted it. is it possible to shorten it?
#211651 07/12/2006 11:54 PM
I've got a nice clean long wheel base 63 frame you can have. Long drive, but it's a good frame, and it's bare too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
