Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#205486 04/05/2006 8:46 PM
I wrote a topic once before about my brakes sticking. Since then I have changed all my shoes and pads. I have even changed the front calipers.
After all this I blead the brakes. So now the other day while driving the truck it felt like it was struggling so when I pulled into my drive way I had smoke coming from all four brake....The brakes had tighted up when I was driving it or they did not release the last ime I presses them.
Anyone got any ideas why this is happeneing?
Roger
Roger
http://www.flickr.com/photos/45469713@N00/?saved=1
#205487 04/05/2006 8:48 PM
are they power or nonpower
bill
#205488 04/05/2006 10:21 PM
Riding in the Passing Lane
Check to see if your master cyl. push rod is letting the piston come back all the way.
1972 Chevy c10 Cheyenne Super
#205489 04/06/2006 2:42 AM
You may have adjusted the rears too tight causing the fluid to get too hot and expand, applying more pressure on the brakes. Also may have the pedal pushrod adjustment too tight too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#205490 04/06/2006 10:28 AM
Socket Breaker
Socket Breaker
rogpat,
what year and type of truck? stock? modified?
-W
#205491 04/06/2006 3:26 PM
change the block under master cyc if it is bad it will send and keep fluid at all wheels hapen to me once going about 90 in a vette
bill
#205492 04/07/2006 8:21 PM
I would say to put kits in the master and wheel cylinders. If they sit too long, the DOT 3 fluid will continue to attract moisture. It will build up into a crusty yellow crud inside the master and wheel cylinders.
