| | | Forums66 Topics128,109 Posts1,056,261 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | What kind of vehicle do you use to bring your old bolt home
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
| | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | In my case, I had a 59 1 ton, that was only a few miles from where I live. I had a big wrecker tow it for me. But due to the angle of my driveway, I had to use a come-along (ratched winder) to pull the truck up into the driveway.
I then used the 59 once fixed to tow my 47 jeep home.
On my 72 truck, it was in the neighbor's driveway so I aired up the tires and got a couple of buds to push it into my driveway. So its been pretty easy for me. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've driven several of mine home. Three I've had delivered by a tow truck. Last summer I finally bought a trailer, and since then I've used my own trailer to drag new fun home.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 | I used my '02 Silverado 2500 with a car trailer to bring home the '42 about 170 miles one way. With my '59 Viking, I was planning to use a rented tow bar, because I thought that it would weigh too much for a standard car trailer. But I got lucky and was able to drive it all the way (65 miles) with only adding oil and coolant. When I upgraded trucks a couple years ago, I went from a 1/2 ton to a 3/4 ton (glad that I did) as the difference in torque is like night and day.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2005 Posts: 112 Member | | Member Joined: Dec 2005 Posts: 112 | i've got a 97 Z-71 and a slightly modified( or hacked up)16ft utillity trailer that has made a many project get'n trips,the last trip was just over 600 miles(round trip)and was the first time I had any trouble.I would like to upgrade to a newer 3/4ton like J Lucas but I have a bad habbit of spending the new truck fund on old stuff,example,last trip the typical intake leak on Z-71'S became a bad leak,especially pull'n a loaded trailer,run hot if not pay'n attn.,that was in early Dec. the truck still leaks but I just got two boxes of front end parts for a 49sedan project.This is'nt a hobby,this is a disease!!!!
1949 Styleline Special 1972 K5 Blazer
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I pulled my '66 C-60 home,about 2 miles,then over a summit to a friends place,about 20 miles,behind my '57 GMC half ton,on a tow bar. Later,I towed it back over that summit to my house again with my '62 one ton on the same tow bar.(handled a LOT better that time) Pretty much everything else I've had to move,I've used the '62 for. I used an old U-Haul trailer hitch,the kind that attachews with flatiron hooks and chains and big wing nuts. I welded brackets onto the crossbar and mounted my old tow bar to it,so now I can use it either way,and it connects easily. Works like a champ! Speed | | | | | Joined: Jan 2006 Posts: 8 Junior Member | | Junior Member Joined: Jan 2006 Posts: 8 | After partial disassembly (front clip and doors off) I towed my '51 3100 home with my $75 '77 Datsun pick-up and a tow rope. That had to look funny! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I brought the red58 home on a UHaul trailer behind my 250 powered 67 3/4T - worked fine, but took over 4 hours instead of the 3 the trip takes unloaded - I also dragged in a 58 parts panel w/ the 67 after I put a 327 in it - much better! nowadays a friend has an 03 dually duramax and trailer so I let him deal w/ heavy haulin, but I use red for non-trailer jobs Bill | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | WE pulled mine out of the snow with a bulldozer and draged it thru the fields.I rented a u-haul moving truck and trailer. We brought her home in a snow storm.It was so much fun | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | I drove it home,half way them got a tow truck
dan-pa
| | | | | Joined: Aug 2005 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 73 | I pulled the 38 Chevy dump on a trailer with a 2001 Chevy dump.I'm sure it was the fastest it's ever gone  | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | This is the rig I use Now, its a 1994 GMC 3500 with 1996 28\' Gooseneck trailer . But I did bring my 1965 GMC 2500 Dually home behind the same 1994 GMC with a Tow Bar all the way from Crooked River Ranch in Oregon. and I used the same tow bar to bring home a 1986 Suzuki Samurai (yes it saids 1987 on the album, that is what I was told, on the title its a 1986). But the BIG fun was bring home the 1966 GMC 1500 with bad clutch, I started out on the tow bar, broke a bolt, so we removed the tow bar and I tryed driving it the rest of the way, about 15 miles out the clutch gave all the way out, so we pushed it the rest of the way with the 94 GMC 3500, I forgot to bring a chain, doh! So what have I learned? Use the trailer on bigger trucks, and the tow bar oon the wee little ones..... | | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | I had to go bush for mine. I drove a 4wd Pajero. If the weather had changed i would not be able to get out. It was a 3000km round trip. The tow-ball stripped its nut 600km into the journey. I tied the trailer back on and drove to the next town where i managed to swap 20L of petrol for a tow-ball to a lady who had run out of fuel. A good trade i thought. The rest of the trip was great. Brendon | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Learned my lesson the hard way about 15 years ago -- don't screw around when you're moving old iron. I do my hauling with my '95 Cummins-Dodge 3500 and a 25-foot gooseneck (equipped with a 9,000-lb Superwinch-brand winch). Picture of the rig at work Usually, this rig hauls hay, produce and farm equipment. But sometimes it gets to play! John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | I remember the 61 was an easy move for me,I took some gas,wd40,brake fluid and went to the guys house and took the plugs out sprayed a little wd40 in each cylinder,disconnected the rear brake line from the tee and capped them off,bleed the front brakes added some new brake fluid,bleed the clutch cylinder added more brake fluid.Gapped the plugs and replaced them poured a little gas in the carb and cranked her over a few times waited about 15 minutes and cranked her over a few more times and BAM she started.I loaded her on the old Lowboy behind my Dodge one ton and brought her home (about 75 miles).I was at the guys house about 45 minutes max and the truck had sit for several years without being started but it was driven to where it was parked.
The 60 was a different story,it was in pieces when I went to get it(about 300 miles)all sorts of problems starting with the gentleman was'nt home when I got there,I dont beleave he could tell time,I waited on him for 4 hours and was about to leave when he showed up "drunker than a skunk".Loooooong story short I loaded her on the Lowboy behind the 61 and came home.He did throw in a real nice extra 235 engine and insisted on following me out of the holler so I would'nt get lost.He was a nice guy.
My 61 c60 was a running truck so I just drove it home with no problem. Hobert
"The Lord is my shepherd"
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Grandpa and I drove mine home from the farm.
Well, Grandpa did. He hadn't driven the old girl (or any 'bolt, for that matter) in a long time and I figured that I'd let him drive it again for old time's sake. | | | | | Joined: Dec 2005 Posts: 47 Member | | Member Joined: Dec 2005 Posts: 47 | I bought an old trailer about 5 years ago and have used it to haul several projects. I went about 450 miles to pick up my last project, a 64 chevy stepside. Paid almost as much for fuel as I gave for the truck. James
Heres to us and those like us, theres darn few left.
| | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | All right this is my first attempt at adding a picture so bare with me. Either way go easy on me.... My bolt hauler | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You guys with big goosenecks are making me jealous!
That is until I remember how tough it can be to get my little 18 foot trailer in and out of some of the places where I've found trucks hiding...
I pull my trailer with an '89 K3500 with a 454 and 165,000 miles of experience. I've pulled big loads behind little pickups and the bigger one sure inspires more confidence.
On one trip I paid more for gas than I did for the truck I brought home.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I think gettin' it home is part of the fun.It's like a personal challenge. There's been a couple of times it crossed my mind to call in a tow truck,but I just can't get myself to pay somebody to haul something I can haul myself,and so far I haven't gotten anything I couldn't haul myself. Speed | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | Used to just get em home any way that worked. Drove some. Towed some. Hired a rollback wrecker a couple times. Borrowed and rented trailers a couple times. Finally, I decided I better get a trailer of my own. Bought a tandem axle bumper, pull trailer and put a hand operated winch on it. It works pretty good up to a 3/4 ton truck. Down the road, I would like to get one that would handle a backhoe. I used to use a \'91 GMC dually with a 454 to tow, but it got to be too much to feed it. Last fall I traded it on a \'01 Dodge 2500 Turbo Diesel Tows as good or better with about 1/2 the fuel.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | drove my BABY home (ok it was only 6 blocks)
Cliff59 | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | The way we move our cars and trucks is with a 1979 Ford F-350 Car hauler. About a year ago I got a 1949 Ford F-5 truck complete with no bed. We could not get nobody to move it so my dad hauled it own his car hauler even though I told him he could not
| | | | | Joined: Jan 2006 Posts: 15 Junior Member | | Junior Member Joined: Jan 2006 Posts: 15 | Hey folks. Newbie here. I just had 2 '39 trucks, a pickup and a 1 1/2 ton flat bed, 2 modal A bodies and extra sheet metal hauled from MO to IN. I have no way to haul anything. I got prices from $1200 to $1000 to do it. Then found a feller who bcame a fast friend that did it for $411!! This guy is great!! I'll use'em everytime. Cheaper than a trailer and insurance here! | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | "You guys with big goosenecks are making me jealous!" I had a good reason for buying my Gooseneck Trailer, I figured it would be harder for people to want to barrow then a pull behind trailer..... Also at the time I bought it, I had some extra money kicking around from all the overtime I had to work keeping buses on the road During the 2002 Winter Olympics. I have used it to haul trucks & Tractors, Hey and all those V12s I got from Texas, as well as a load of junk from time to time. Even used it in a $4th of July Parade once as a float. Just incase anyone really cared, I Posted Some More Photos of MY Truck & Trailer <~~~There. | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | dang Jolly thats nice!
Cliff59 | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | I've been lucky and was able to borrow a truck and rent a trailer both times. Truckin.. The run with the Chevy was about 200 miles each way while the run with the Freightliner was 1,000 each way. The Chevy handled well but the Freightliner didn't even know it had anything behind it!
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 | I agree with Speed, getting it home is what makes it an adventure. I like every bit of it, including the part of thinking through all the problems that could occur and being equipped and prepared to handle any obstacle that one might encounter.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: May 2005 Posts: 33 Member | | Member Joined: May 2005 Posts: 33 | In '98 I bought a '82 C20 Chevy and a couple months later a 20' flatbed trailer. Since, I've hauled about 20 different cars/trucks. Some more than once. The 20' trailer was overkill for most of the vehicles, but it was barely enough to pull a '51 4400 w/dump bed from Nebraska to St.Louis. It rode fine but squatted rather low. That opossum on I-70 cleared the truck, but no way it cleared the trailer. Now I pull with my '66 C20. The 283 is no match for the 350 though.
Life is good. Keep on playing.
| | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | well the first truck i got was free and only 3 blocks away. so a chain and a running truck and 5 min and it was done. now my ne old truck im getting is going to turn into a car carrier, the problem is getting it . its a 37 international duel axle. this should prove interesting.  | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | i'm a bit jealous the trailer i've used is borrowed and could really use a re-wire or new bulbs and a trailer brake system (not equiped with brakes) (but none of my trucks are setup for trailer brakes) so far all i've ever used is 1/2 tons 85 Chevy 1/2 2wd has the suspension for it but the 305 and 3.08 rear end make it interesting but a ton of scrap iron in the bed makes it sit 1 in. lower then level, 78 chevy suburban 1/2ton 4x4 has suspension and 4.11s and granny 4speed but the motor could use a tad more power but other then that it works really well and last one was 70 Chevy 1/2 even with 3.08s i could get up and moving fast via somewhat fresh 350 4bolt .030 overbore and other go fast parts but hauled a 68 IH 4x4 1/2ton and that really did a number on my frame cracked and bent it badly 1/2ton coil trucks don't make good tow vehicles and i used my 90 S10 2-dr blazer with a car dolly that wasn't as bad as i thought but kept it around 50-55 i would like to get a 3/4-ton or 1-ton and a gooseneck someday Nate | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I've hauled a 1 1/2 ton home with a tow dolly. Mine can handle a new full size 1/2 ton (by the book). You want to be careful about corners though. A truck on a dolly can push your rear end around if you are not careful. The dolly comes in handy when you are alone and have good tires on the rear of the towed vehicle. You also need to be carefull of your state laws concerning towing a vehicle with the wheels on the ground. It may have to have current license. I also wouldn't tow too far with a dolly when dealing with an old vehicle. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | My brother and I just hauled a 1959 Chevy Fleetside home with a 18 ft trailer and towed it with a 2004 GMC extended cab 3/4 ton with the Duramax Deisel and Allison transmission. What a setup! That GMC never broke a sweat. The transmission breaking worked great in the tow mode. We pulled 70 to 75 mph all the way. That truck didn't even slow down 1 mph going up hills. It is one heck of a truck. | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | From Colorado to Mass? I had her hauled. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | left franklin oh. with a 20ft. trailer in aborrowed chev g20 work van, two breakdowns and 900 miles later was in fletcher oaklahoma only to find my newly purchased 49 3100 wouldnt fit up on the trailer, with some creativity got it loaded as the snow started . drove 900 miles back with the storm front right over our truck. i'm still pulling seat fabric out of my butt cheeks. darn i love old trucks 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The only time I had "trouble" finding a way to get something home was when I bought my Bulldozer. I had a guy in town that hauls farm equipment with his 1 ton Dodge V-10 and a gooseneck dual wheel dual axle trailer. Even though he was lisenced to the max, we were still 5000 pounds over weight. We waited until early evening to haul it to help avoid the DOT, and he hauled it home with the promise that I would pay the fines if need be. I have a triple axle trailer but the truck I used to pull it with is now under construction. I have a ramprod truck project in the works but it's on the back burner so far I can't even see it yet. Depending on how far away it is, I've had them towed home too. I keep friends in all lines of work so I can trade favors with them. Scott | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | now we got an 18 foot car trailer to haul them on and it works really good. It is much easier to load them on the trailer than it was to load them on the car hauler
| | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | Me and dad drove the Green Machine home. It was about a 40 mile trip on the interstate. The only real problem we encountered was 2 weeks later when we learned that there wasn't a nut on the steering column holding the steering wheel on. It would have been interesting if the wheel had come off on the interstate instead of pulling into my driveway.
Drew | | |
