2 members (dt235sd, Sjm),
99
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 26 New Guy | | New Guy Joined: Nov 2005 Posts: 26 | Can anyone tell me the best product to spray on rusted bolts and screws to help loosen them up? Thanks! | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 |
Evan
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | My favourite is called "Fluid Film" and it works really well. It comes in a can with a gold colored background. | | | | | Joined: Mar 2005 Posts: 158 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 158 | Left handed drill bits.
mark. '51 KY 3100 | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | mark, I have tried to spray em..the can keeps plugging. Stuart | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 |
dan-pa
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Years ago I overheard a parts counter clerk tell a customer to slather the bolt head in Hellmans Mayonaise (he said no other brand would work)
After the guy left I asked him, "That dosen't really work, does it?" and he replied, "Nahh.. that guy's just an @sshole."
I don't know if it was related or not, but I saw that sales clerks picture in the paper a week or so later, after he was gunned down outside a bar.
For rusty bolts that are stuck, I use WD40, and when that don't work, I heat 'em up with a MAP gas torch.. it also helps to use a good ratchet and have a 6' length of pipe to put over the handle to increase your leverage!
| | | | | Joined: Jun 2005 Posts: 49 Junior Member | | Junior Member Joined: Jun 2005 Posts: 49 | pb blaster, for 3 days straight... a length of pipe over your rachet adds leverage, but if your bolt isn't loose all you'll do is shear the head off of it and then you're really screwed!! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I spray oxygen and acetylene at them, Scott | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | From my experience Chrysler makes the best penetrating oil bar none. If you use WD-40 make certain it is in a well ventilated area. Had a buddy pass out working in the tail cone of a float plane after using WD on some electrical clamp bolts. | | | | | Joined: Nov 2004 Posts: 2,432 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,432 | "PB Blaster" and another product called "Knocker Loose" I had good results with both. The later was a free sample and have not used it a lot but, when I did, it worked.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I use WD-40 and a product called "Breakaway" which works better than WD-40, but I haven't found it locally in anything bigger than a spray can. WD-40 comes in larger sizes. | | | | | Joined: Mar 2005 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 59 | i use zep 45 nc on all things stuck and hood and door latches and hinges
rh | | | | | Joined: Oct 2005 Posts: 45 Member | | Member Joined: Oct 2005 Posts: 45 | I'm sure there are other penetrating oils that work as well, if not better. But, I use WD-40, followed by a few good whacks with a hammer. If it still won't budge, then use heat. You only need to heat metal up to about 300 degrees for it to expand. If you can get it to turn even a fraction, turn it the other way immediately. Then back, then in, back, etc. More penetrating oil, and work it back and forth, firmly but carefully. If it doesn't break off in the first half-turn, you got it made. | | | | | Joined: Oct 2005 Posts: 45 Member | | Member Joined: Oct 2005 Posts: 45 | Warning! WD-40 is flammable! | | | | | Joined: Oct 2004 Posts: 6 Junior Member | | Junior Member Joined: Oct 2004 Posts: 6 | I recently damaged a ratchet's internals by using a length of pipe on it. Fortunately, it was a Craftsman which was replaced for free. I now use a breaker bar (with pipe if needed) for hi torque application then switch to the ratchet after the bolt is free.
66flwb
| | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Originally posted by 66flwb: I recently damaged a ratchet's internals by using a length of pipe on it. I never use pipe on ratchets, but I have one of those Crafstman 1/2 drive ratchets with the swivel head and 18" handle. The internals are getting loose on it. The mechanism can't take the torque that the handle can deliver. Breaker bars are always a good idea on tough stuff.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | pb blaster is the best stuff | | | | | Joined: Oct 2005 Posts: 37 Apprentice | | Apprentice Joined: Oct 2005 Posts: 37 | | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I have in the past busted ratchet guts by sticking a 6' pipe on a ratchet and hopping up and down on the end of the pipe.. even busted a craftsman and snap-on that way.
Believe it or not, a few years ago I picked up a Stanley 200 some odd piece set from WalMart, and that ratchet in that set is tough as nails.
I've done stuff with that ratchet that would make you cringe even if using a breaker bar.. it's now become something of a game to see if the Stanley even CAN be broken!
| | | | | Joined: Apr 2005 Posts: 23 Junior Member | | Junior Member Joined: Apr 2005 Posts: 23 | | | | | | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | PB Blaster and Jack Daniels.
Two shots of PB Blaster for the nut to be wrenched, and one shot of Jack for the nut with the wrench...
Richard 58 3104
| | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | lets hope he hasn't got too many bolts to undo. I've found the best way to loosen rusted bolts is to add penetrating oil. If you can, tap the head of the bolt to brake the seal the rust has made. With screws, it's the same thing. Use the correct size screwdriver, place it in the screw and tap it with hammer. if all else fails, drill the bolt/screw out and use an esy-out tool. Most engineering shops stock them. | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Yep, pb blaster.
My process is squirt, tap, tap, tap. Wait a day and then squirt, tap, tap, tap. Repeat. Drink some Very Old Barton (JD is ok, but it is made in Tennessee, not Kentucky). Squirt, tap, tap, tap.
I have also found that a hand-held impact socket will work great after the above process if you have room.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | I have used Kroil (made in Nashville Tennessee) and also automatic transmission fluid. Also, I have applied George Dickel (a proper sour mash made in Tennessee not in Kentucky). When none of these worked, I would rely on my 4-1/2 angle grinder with a cutoff blade. Good luck (cheers) | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Jeff, I kinda use the same technique, but am kinda partial to Kentucky Tavern..Maybe we should all get together and discuss the pros and cons of each..I was in Fort Campbell, and if I'm not mistaken, the state line runs through the base | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | but the main trick, which I'm suprised none mentioned, is after the penetrating oil, ALWAYS TIGHTEN sharply first to break the rust, then loosen
Bill | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Some rusted bolts are standard, and can be replaced with new ones..Then it's time for the cutting wheel...Others are unique to the bolt and have to be removed without damage..I guess it depends on the circumstances what I would use.. Pb Blaster Big pipe with broken socket or drive Torch Grinder w/cutoff blade And the BFH
Bandaids come in handy too...Steve | | | | | Joined: Aug 2005 Posts: 125 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 125 | The very best way to loosen rusted bolts/nuts is to heat the nut with a torch, red hot, and keep spraying it with water until it dools down. You may have to do this 2 or 3 times. Do this BEFORE you spray any anything else or it doesn't work as well. This works on tight fittings, pipe plugs or anything that can be safely heated & cooled. I guarantee you that this will be a very good way to get them loose. Use plenty of water in a spray bottle & try to get the water to work down into the threads- that is the trick- flood the heated item with a water spray so the water can get into the rusted threads. Try this first, and you can stop using anything else.Let me know what you think! | | | | | Joined: Feb 2005 Posts: 68 Member | | Member Joined: Feb 2005 Posts: 68 | The answer is all the above.....Ronnie | | | | | Joined: Jul 2005 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 70 | In really bad cases I just click on "Restore your Stovebolt to a previous time." I select a date, say 40 years ago and try that, bolts weren't as rusty in those days and they come out wasily every time. Need a fair whack Bundaberg Rum in the mechanic though.
Zacca Australia
"After you skin yer knuckles, Mr Shifter ain't yer friend any more." 1942 Chevy 3/4 tonIn the Stovebolt GalleryPhoto Site1946 Chevy 5 window coupe/ute (new stray) 2000 Nissan Patrol 4x4 4.5l turbo diesel
| | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | LOL I use used oil and time, it always works for me. If I'm in a hurry, I shouldn't be around my bolt, but heat from a propane torch will do some good. If not, more oil and patience. The accid in used oil will eat the rust, in time.
Richard | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | If PB Blaster dont work,I get the smoke wrench out. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | If PB Blaster dont work,I get the smoke wrench out. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Ilike the answers above but you have the ratio of oil to bourbon way off. I have found theat 4-5:1 bourbon to oil will make you forget which bolt you were trying to remove....
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | I use WD-40 then whack with a big hammer. If that don't work I use heat and then more spray. If I could find some Kroil around here I'd get some, guess I need to do some checking. I use to use it in the factory I worked in, really good stuff! If all else fails I break out the grinder or hot wrench and I have burned them out with my stick welder.  | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I use one of 2 methods as a rule.I either heat it up to a red and then loosen it while still as red as possible, or Iuse a disc grinder. If I use the disc grinder I prefer the zip cut wheel and cut from the outside in careful not to touch the material behind. If I only have a regular wheel ,I grind back and forth near the middle of the bolt, that way I have less chance of ruining the material behind. | | | | | Joined: Oct 2003 Posts: 45 Member | | Member Joined: Oct 2003 Posts: 45 | I've had good luck heating the bolt/nut assembly up to a bright cherry red with an O/A torch, waiting for it to cool to a dull red, and then sticking a candle (or just bar wax) onto the area where nut meets thread. The wax melts into the threads and makes it very easy to turn out. I *highly* recommend doing this from the backside as wax will make the bolt head or stud much more slippery, and harder to grasp with a vise-grip or similar tool.
richard2005, do you actually believe the advice you just spouted about used motor oil? I've torn apart engines that have sat for 20+ years and have not EVER seen the internals of a motor eaten away by anything but rust...used oil protects metals, even if used oil has a PH below 7 (naking it slightly acidic) I have a very, very hard time beleiving that it will actually "eat" anything.
If you want something acidic to take rust off of parts, use a product called "naval jelly" and either mist it with water every few hours to keep it from drying out, or place a sheet of seran wrap over it after applying to trap moisture in the work area. | | | | | Joined: Oct 2003 Posts: 45 Member | | Member Joined: Oct 2003 Posts: 45 | Oh, additionally, I just purchased a Milwaukee model 9079 18V cordless impact wrench, what a wonderful tool, makes dismantling a breeze... | | |
