8 members (Hotrod Lincoln, tclederman, 2-Ton, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom),
167
0
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Mongo's what followed me home post made me jealous. I've been looking for a COE for quite a while. So I closed the loop on one of the two I've been looking at for quite a while. I've committed to buying this one: [img] http://www.oldsub.com/images/2006/04/COE.jpg[/img] I won't be picking it up for a couple weeks, since its a couple hundred miles away. I'm not distressed my the missing tin because I want to build an extended cab dually using a COE. In fact, I think I'll leave the frame and running gear and only drag home the body. Any one have experience taking one of these apart, and able to offer any suggestions of the quickest way?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Make sure you grab all of the stuff that's uniquely cab-over. Get that panel that covers the rear of the engine, just below the rear of the cab. get the radiator baffles, upper and lower and the intake/exhaust manifolds with the carb. Grab the frame extentions that raise the cab up too. Welcome to the COE fraternity Oldsub, Scott | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | How about a crew cab dually COE?
Torch? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Hey steve, feel free to drag the frame and running gear over and drop it off in my yard! As long as shes not all bent and broken anyway...
Let me know if you need a hand.
Jeff | | | | | Joined: Mar 2004 Posts: 49 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 49 | Oldsub that cab would be ideal for the motorhome chassis you have.Good luck on the new project. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Congratulations Steve, The COE Fraternity, is growing. Looks to be a '52, or '53 Chevy COE. What was the previous owner, attempting to do, with it. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Thanks for the kind words guys!
Scott: I'll make sure I get all COE specific stuff! But today I'm thinking maybe I'll drag it all up here since Jeff will take what I don't...
4.3in84toy: How about an extended COE Panel Dually, with a set of Suburban windows behind the doors, providing more passenger glass. 454, turbo 475, and 4.11 gears. 161 inch wheel base means its two feet longer than the donor panel, but being a COE instead of conventional cab, its probably only a few inches longer than the 1-ton panel was stock.
Jeff: First trip will be to scope what's really there, and to actually pay for it. Taht should be mid-May. Perhaps second half of May or early June you and I can run to Portland and collect it?
wingedexpress1: Putting that cab on my P30 frame is exactly what I want to do! Its the 161 inch long wheelbase with 454 and turbo 475.
spanky: From the angle of the only photo I have I can't tell for sure what year or GMC or Chevy. The wing windows say '51 or newer and the split windshield say '53 or older. What do you see that narrows it down for you?
The previous owner used it as a sheet metal donor on a chopped and extended GMC pickup with a Cadillac V-8...
And thanks guys for not giving grief over the hot rod plan on this one. I figure I'm starting with one that's far enough gone bringing it back at all is a good thing...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The style cab grab handles it has, first came out in 1952. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Somehow looking at that grab handle makes me think the rear doors should hinge at the rear. I don't now why.
Thanks!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | Have you got the coe home yet
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its been and gone...
I got it home a week ago yesterday (the Saturday) and then Sunday delivered it to a friends house where he generously offered to let me store it, and where he will claim a few parts off it.
I only wanted the sheet metal and need to get it removed and hauled home soon.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2006 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 17 | It's beautiful!! They are hard to find in our neck of the woods, I guess I am not looking in the right spots. Keep us posted on the progress. Best of luck!
" Oldies but Goodies!" | | |
