| | | Forums66 Topics128,126 Posts1,056,351 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 26 New Guy | | New Guy Joined: Sep 2001 Posts: 26 | What's the best, long lasting paint for my 235 exhaust manifold? Maybe rusty burned off looks original here, but not too pretty. But I have seen stories, and half peeled off fake doesn't look pretty either. Some restorers have worked hard, then manifold paint starts to peel off after a month or a year. I'll paint the intake engine color.
What current product really looks good and stays? How is the best way to clean and prep? Can it be done with a rust remover chemical, if I can't get to a sand blaster.
What about that high heat filler sold by some, to put on first?
Thanks, 'bolters! | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I have used Eastwood Co. factory gray high temp coating with good results. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Same here i did mine with eastwoods High Temp S.S. , havent fired it yet to let ya know how it performs ....hope it holds up to its rep. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Here too on Eastwoods manifold paint. Looks great. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I'll used Eastwood hi-temp paint for a numbers of years. While it looks good at first, after a hard run in the rain the paint is gone and I have to recoat. If one were to media blast the pipes before painting it might last longer, I didn't. Note...when you start the truck after painting the pipes BE SURE to do it outside, That caution on the can is for real.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Have it ceramic coated if longevity is your biggest concern. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | por 15 also makes manifold paint.....dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | i fired the ol gal over the weekend ...an yes on the fumes, i Media blasted mine prior to coating got her pretty hot runnin it in an settin timin etc ...NO change in color or surface texture on the SS Eastwood manifold paint will keep ya posted as to how it lasts | | | | | Joined: Sep 2001 Posts: 26 New Guy | | New Guy Joined: Sep 2001 Posts: 26 | Thanks, keep up the in-use progress reports.
Doug | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I Cleaned mine vigorisly with Laqure thinner...It brought it down to the origanal silver type color..It looked pretty good so I left it like That,,But i wouldnt mind useing that eastwood stuff..sounds like everone likes it. I have to get some pics of at least my engine to post...It looks real good.
HURRY UP AND WAIT 55 235 3/4
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Last year I needed to do a lot of things under the hood. One of the things I did was replace the manifold gasket. I sandblasted the intake and exaust. Then I coated it with a rattle can of S.S. wood stove/ BBQ paint. Looks very close to the right color. I have about 500 miles on it, and it looks fresh and clean. It is somethig to consider, Jimmie. | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Another quality source is Bill Hirsch | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | http://www.imperialrestoration.com/products.php?category=4 por 15 also makes manifold paint ''''' This Aluminum high temperature paint is capable of withstanding temperatures up to 1400° F, POR-20® is also extremely weather, salt and moisture resistant. Helps prevent cracking, chipping, and peeling. You will be excited by its performance and beauty. We guarantee this to be the most brilliant, uniform heat resistant coating available anywhere. ''' i use the silver and (also the gray) it's good (they say) to 1400 degrees. the black is 1200 degrees
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
