3 members (3B, 55shaker, Gdads51), 103 guests, and 1 robot.
Topics128,130
Posts1,056,367
Members48,441
#126891 06/22/2007 5:45 AM
What's the best, long lasting paint for my 235 exhaust manifold? Maybe rusty burned off looks original here, but not too pretty. But I have seen stories, and half peeled off fake doesn't look pretty either. Some restorers have worked hard, then manifold paint starts to peel off after a month or a year. I'll paint the intake engine color.
What current product really looks good and stays? How is the best way to clean and prep? Can it be done with a rust remover chemical, if I can't get to a sand blaster.
What about that high heat filler sold by some, to put on first?
Thanks, 'bolters!
1947 1st Series Chevy One Ton Panel
More pix on Photobucket
#126892 06/22/2007 1:45 PM
I have used Eastwood Co. factory gray high temp coating with good results.
Steve
'49 3800
'52 3600
'57 3100
#126893 06/22/2007 2:31 PM
Same here i did mine with eastwoods High Temp S.S. , havent fired it yet to let ya know how it performs ....hope it holds up to its rep.
1952 Chevy Shortbed
Photos in Photobucket
#126894 06/22/2007 4:13 PM
Here too on Eastwoods manifold paint. Looks great.
#126895 06/22/2007 6:19 PM
I'll used Eastwood hi-temp paint for a numbers of years. While it looks good at first, after a hard run in the rain the paint is gone and I have to recoat. If one were to media blast the pipes before painting it might last longer, I didn't. Note...when you start the truck after painting the pipes BE SURE to do it outside, That caution on the can is for real.
#126896 06/22/2007 7:16 PM
Have it ceramic coated if longevity is your biggest concern.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#126897 06/25/2007 1:15 PM
por 15 also makes manifold paint.....dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
#126898 06/25/2007 1:56 PM
i fired the ol gal over the weekend ...an yes on the fumes, i Media blasted mine prior to coating got her pretty hot runnin it in an settin timin etc ...NO change in color or surface texture on the SS Eastwood manifold paint will keep ya posted as to how it lasts
1952 Chevy Shortbed
#126899 06/26/2007 2:01 PM
Thanks, keep up the in-use progress reports.
Doug
#126900 06/26/2007 9:32 PM
I Cleaned mine vigorisly with Laqure thinner...It brought it down to the origanal silver type color..It looked pretty good so I left it like That,,But i wouldnt mind useing that eastwood stuff..sounds like everone likes it. I have to get some pics of at least my engine to post...It looks real good.
HURRY UP AND WAIT 55 235 3/4
#126901 06/26/2007 9:50 PM
Last year I needed to do a lot of things under the hood. One of the things I did was replace the manifold gasket. I sandblasted the intake and exaust. Then I coated it with a rattle can of S.S. wood stove/ BBQ paint. Looks very close to the right color. I have about 500 miles on it, and it looks fresh and clean. It is somethig to consider, Jimmie.
#126902 06/27/2007 12:52 AM
Another quality source is Bill Hirsch
#126903 06/27/2007 1:08 AM
http://www.imperialrestoration.com/products.php?category=4
''''' This Aluminum high temperature paint is capable of withstanding temperatures up to 1400° F, POR-20® is also extremely weather, salt and moisture resistant. Helps prevent cracking, chipping, and peeling. You will be excited by its performance and beauty. We guarantee this to be the most brilliant, uniform heat resistant coating available anywhere. '''
i use the silver and (also the gray) it's good (they say) to 1400 degrees. the black is 1200 degrees
Jim & Caroline
