0 members (),
100
Mod | | | Forums66 Topics128,261 Posts1,058,346 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | Back in the late 70's, I used to buy wheel blanks without centers from a place in Fresno, California and fabricate my own wheel centers out of flat steel plate for my dirt track car. I used a triangular gussset plate between each lug bolt hole for reinforcement. Ugly, but effective, and I could use any offset I wanted.
I've also fabricated rims using different centers, as you've suggested. The older centers for tube-type wheels are riveted, not welded, and they're relatively easy to remove by drilling out the rivets. Waaaaay back in the 40's and 50's, hotrodders used to "reverse" wheels by simply knocking out the rivets, and re-riveting the centers with the long offset toward the outside of the vehicle. That put the valve stems to the inside, so the wheels were smooth-centered.
Lathe-turn or grind the centers to fit your replacement wheels, and build a jig to support the center at the right height with the assembly set up on a flat workbench or a smooth shop floor. Tack-weld the center in place, and check for runout by mounting the wheel on a front spindle with a dial indicator on the flange. Adjust the runout as necessary before completing the weld. A brake lathe or a wheel balancer also works for this step. I used to stick-weld my wheels, but a MIG is probably a better idea.
Balance the wheels without tires on them, adding weight where necessary with the MIG to get as close as possible to perfect balance before mounting the tires. Good luck! Jerry
Entire Thread
1950, 3604 - My old gal is bouncing her back end around!!!
| Denny Graham | 07/31/2007 3:26 PM |
Re: 1950, 3604 - My old gal is bouncing her back end around!!!
| Grigg | 07/31/2007 3:52 PM |
| mike1951 | 07/31/2007 4:25 PM |
| Builder | 07/31/2007 5:53 PM |
| hotshoe36 | 07/31/2007 6:17 PM |
| Hotrod Lincoln | 07/31/2007 6:37 PM |
| mike1951 | 07/31/2007 6:54 PM |
| Denny Graham | 07/31/2007 10:54 PM |
| BIG CHEVY 3600 | 08/01/2007 12:13 AM |
| 1958GMCnut | 08/01/2007 2:46 AM |
| hotshoe36 | 08/01/2007 2:55 AM |
| Achipmunk | 08/01/2007 3:05 AM |
| Grigg | 08/01/2007 3:44 AM |
| Denny Graham | 08/01/2007 6:27 AM |
| Grigg | 08/01/2007 6:36 AM |
| 1958GMCnut | 08/01/2007 7:55 AM |
| Denny Graham | 08/01/2007 11:31 AM |
| Grigg | 08/01/2007 1:49 PM |
| Shellology | 08/01/2007 3:40 PM |
| Denny Graham | 08/02/2007 4:22 AM |
| 10 micron | 08/02/2007 6:17 PM |
| Denny Graham | 08/03/2007 3:21 AM |
| bigmacdaddy | 08/03/2007 3:25 AM |
| Denny Graham | 08/03/2007 12:09 PM |
| Hotrod Lincoln | 08/03/2007 3:31 PM |
| hotshoe36 | 08/04/2007 8:30 PM |
| Denny Graham | 08/05/2007 4:10 AM |
| hotshoe36 | 08/05/2007 6:21 AM |
| Denny Graham | 08/05/2007 2:00 PM |
| Hotrod Lincoln | 08/05/2007 2:54 PM |
| hotshoe36 | 08/05/2007 4:09 PM |
| Denny Graham | 08/05/2007 7:44 PM |
Anonymous
| 08/05/2007 8:32 PM |
| Grigg | 08/05/2007 9:26 PM |
| Hotrod Lincoln | 08/06/2007 4:13 PM |
| hotshoe36 | 08/06/2007 4:25 PM |
| Builder | 08/06/2007 4:26 PM |
| 641Workmaster | 08/06/2007 4:42 PM |
| Hotrod Lincoln | 08/06/2007 9:00 PM |
| Denny Graham | 08/06/2007 9:44 PM |
| hotshoe36 | 08/06/2007 10:49 PM |
| Hotrod Lincoln | 08/06/2007 11:03 PM |
| 641Workmaster | 08/07/2007 12:32 AM |
| Denny Graham | 08/07/2007 2:16 PM |
| Hotrod Lincoln | 08/07/2007 3:35 PM |
| tlorber | 08/09/2007 6:40 PM |
| Denny Graham | 08/10/2007 3:20 AM | |
