7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP), 111 guests, and 3 robots.
Topics128,185
Posts1,057,203
Members48,465
Page 1 of 2 1 2
My old gal is bouncing her back end around, and I’m not talking about my “Big old wife this time”!!!
I’m in need of some advice from some of you tar experts out thar. My old girl has a bounce goin for her in her rear end and it’s not to appealing on her.
I’m addressing my 1950, 3604 and last weekend was the first I’ve had her on the road since I bought her last September. This is really a two part question.
Part one; I’m running stock slit rims all round (good ones, no rust) with brand new, zero miles (Chin made) Power Master 7.00-15 LT, Bias 4 ply rated 6 ply tires on the front.
On the back are two Mohawk, Motrac Chief 7.00-15 M/S, Bias 4 ply rated 6 ply. These were on the truck and I’m not sure how old they are but they’re in good shape, no checking or cracking of the side walls, tread is like new and the rubber is not hard but still supple. I attribute this to the fact that it was kept in the fire shed most of her life up until a couple of years ago.
Before putting her on the road, I balanced all four tires myself here at home with a good bubble balancer, then to verify my findings took then to a tire shop just up the street and spun them up on their dynamic balancer. I was real close, within a 1/2 oz on all four.
She a 3/4 ton so I expected her to be kind of a rough rider, but at around 45mph a real bad bounce in the rear develops, bout shakes your teeth out, it gets a little better at around 50 (that’s top end) and diminishes when you let up on the loud peddle (figure of speech, shes a 216) and drift below 45mph. My first thought was the M/S tires were out of round, I checked the rim with an indicator and only have around .050 runout and the tread outside runs out roughly an 1/8”, I’ve seen worse and not noticed this bad of a bounce.
So yesterday I took the rears up to my favorite tire shop that I have been using for 25 years. They’re located out in the middle of the Illinois farming community and service a about every type of commercial vehicle there is. We spun them up on their machine (a Coats) we came up with about the same weight and location (around 7oz. on both). Problem was we worked for 30min trying to get them to 0.00 but ended up putting 1oz. opposite the 7oz. to get them in balance, not the best practice but it was the only way. On the machine the tread run out was about the same as what I saw at home and they didn’t seem concerned about it.
Well back on the road and at 45mph the rear starts into harmonics again, no change. My conclusion, get those da&$ snow tires off the back end!!! Unless of course someone has another idea.
Second part is; I have a set of 16.5 rims from an early 70’s 3/4 ton 4/4 that my nephew scraped out. They fit the rear OK but of course hit the stock tie rods on the front. So, my plan is to mount up some tubeless radials on the back and leave the 7.00-15 Bias plies on the front.
I’ve heard rumors against mixing radials and was wondering if it was urban legend, just a plot to sell more tires or if there is any science to it.
Also can any one suggest a 16.5 tire that would look similar to the 7.00-15 Bias plies that were originally on the ’50, 3/4 ton trucks? The China made Power Masters that are on the front look very original.
Oh one other thing, new gas charged heavy duty shocks all round, all the springs take grease and they and the shackles appear to be in good shape, no play. All new (rebuilt) steering linkage and all new bearings front and rear, drive line all new bushings, center bearing and rubber, three new U-joints and drive shaft and yokes striped to bare metal and re-sprayed with Rustolium.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
When I had bias ply tires, 8X19.5, on my 1 ton it would often take several miles for them to "round up" again. When it was cold out It was really bad even from just sitting overnight, would take 5 or 10 miles before they felt smooth again.
The 78 GMC dump truck I bought had bias ply tires on it. I paid the guy for it and proceeded to drive away, had to stop within a mile, as I was sure I had a flat tire or two. Got out and checked, all had air, then I remembered about bias ply tires and sitting for a while...
They were so out of round / bumpy it was almost unbelievable, and after 20 or 30 miles they were fine.
How long have your test rides been?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
i vote for getting the bias plys rounded...
I had this issue in my 51 til I copped out and got radials... But I only have a 51 truck to drive
"I'd rather have a bottle in front of me than a frontal lobotomy."
-D. Parker
1951 Chevy 3100
My dad mixed radials and bias on his car. I thought it was terrible handling. The thing would bounce in all different directions. Another thing that will effect handling is the shocks. If they are worn out they just won't help the vehicle handle well.
Yesterday's tires on yesterday's rims were sufficient for yesterday's speeds on yesterday's roads. This is today.
[img]http://thumb11.webshots.net/t/64/464/6/3/64/2252603640096215731mOZawt_th.jpg[/img]
You didn't mention if you had run those tires long enough to warm them up. Bias ply tires have a very defined operating temperature range, outside of which they are not at all happy. Also, Chinese tire manufacturers have not yet, in my opinion, progressed to the point that the purchase of their product is anything more than a crapshoot. Sorry. You might be one of the lucky ones.
On heavy trucks back in the 70's, we routinely ran bias on the steering with radials on the drives to achieve the longest wear, without any ill effect. I think, though, that there's a chance your truck could transmit vibrations through the frame to the tires at the other end when it is empty. I'd go with tubeless radials all 'round, as you can see.
1951 3800
-hotshoe
Mixing radial and bias ply tires on the same axle is a no-no. As long as both sides of the axle have the same type of tire, you're probably OK.
I've got an old Dodge 1-ton chassis 24-foot Banner motorhome with bias ply tube type tires all around, and it will rattle my teeth for the first 20 miles after it's been sitting unused for a few days. If the ply material is nylon, that's definitely your problem. We used to call it "nylon thump" 40 years ago. As the tire warms up and gets flexible, the flat spots will go away and the ride will improve. It gets worse in cold weather.
16.5's were designed to have the same overall height as tube-type 15" tires, but I'm not sure how the sizes interchange. We used to use 11-22.5's on the same hub as 10.00-20's, with no tire height problems, IIRC.
I went radials all round and I am totally happy...
though I must admit my old bias plys drove with a tear in the sidewall..I was able to get to the tire shop on them... the tubes were still holdin air
-D. Parker
1951 Chevy 3100
I know it's a lot to swallow, I'm kind of long winded, don't like to leave any thing out Builder, so I'll say it again,"new gas charged heavy duty shocks all round".
The rounding out, most of the trips have been around 20 miles. Started driving in '57 and spent my first 25yers of live living in the garage with dad, brother and all my friends. All we had back then were bias ply tires and of course there was the thump, thump for a few miles but only a few miles. I never remember them taking twenty or thirty miles to round out, if that were the case everybody in town would have been all shook up as a 20 mile trip was a trip to the next town and we just dint travel that far that often in a small town.
Don't forger we're talkin 3/4 ton here. I'd Love to put radials all round but I can't find an eight lug wheel that looks original and that will clear the tie rods with out having them custom made or stuffing an adaptor behind it. That's still a litte out of my price range right now anyway. Besides the new Chin made bias plies on the front aren't the problem, I could leave a glass of water on the front fender and it wouldn't splash out, that is unless I hit a bump, it's the rear tires the are hopping round and when you hit just the right harmonic where the natural frequency of the frame is at that of the rear tire it starts the frame to vibrate also.
Denny G
Denny G
Sandwich, IL
Sounds like a suspension problem. My rear end would bounce around on my 51 Fleetline when I chocked up the rear springs for a "rake" effect... at age 18.
~Jim
any chance the driveshaft is out of phase/balance/bent? run on jackstands to see if shake occurs...my 2 cents
GMC: Get More Cash...
1958 GMC
My Webshots photos
That's not a bad idea, come to think of it. They have a steady bearing.
1951 3800
-hotshoe
Put the mud and snow on the front, and the front tires on the back...take it for a spin and see what happens.
Next would be to put a decently heavy load on it (stack of block or something) and take off down the road for a while and REALLY get the tires hot and run it for a while with the load on it. Then report back grin
I am starting to think your tires are not your problem. Not sure if this is your problem, but I have had the driveshaft center bearing mounting bolts loosen and cause a bad vibration, bad enough that I pulled over about the instant it happened to see what it was.
On another truck I had the rubber part of the bearing fall out, it had a little vibration, but not really bad. In this case I was able to still drive the truck home about 40 miles with no problems, I bought the truck just for the engine, so I was not concerned with the damage I may have caused to the driveshaft, so long as it got it's self home...
I ran 8X19.5 bias tires on my 1 ton, after about 8,000 miles I put radials on the rear only.
I did notice that they rode much smoother in general compared to the 7.50X17 trues I was running. A hole or bump in the road felt much softer than with the old 17" tires.
You can find used or new 19.5 wheels to fit your 3/4 ton, and I highly recommend the upgrade to 8R19.5 tires for a working truck. The wheels will clear the tie rods.
Grigg
---All pictures---
“Run it up on jack stands”, did that yesterday after I brought the tires back from the second balancing act, and before I let it down for the test run, it ran as smooth as silk.
That’s exactly what I was thinking bout doing Munk after finding the bounce was still there yesterday. I got off on this tangent thinking about tubeless rims and radials again.
That’s all new under there Grigg, only got 83 miles on it and was under last night checking things out, take a look: http://rides.webshots.com/photo/2421733140098611668UuEbDZ
http://rides.webshots.com/photo/2872219070098611668JmjLaJ
U-joints are in phase, and shaft cleaned up like brand new, didn’t even have any rust on it when I washed it and cleaned it up.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Nice work, pretty soon you will have a completely restored truck if you keep at.
Did you forget the cotter key in the parking brake linkage shown in the second link?
With everything in the driveline rebuilt it must be bad tires then? Do you have some different wheels and tires you could try?
Grigg
---All pictures---
just for a giggle, try reassy driveshaft 180* out, have seen balance issues in driveshafts even in phase can be out of balance as an assembly. will take little time and could fix it. ohwell
1958 GMC
My Webshots photos
Ya know, ya did make me go out and crawl under just now to make sure Grigg, yes it's there, and the pic was taken before everything was finished because one of the members had a question about how the spring was located. I'm gonna swap the fronts and the backs today if I get a chance like Fred suggested, that should nail it down, I was thinking of doing that the other day but didn’t have time. Got no other tires right now, I think I'm gonna break down and spring for a couple of tubeless rims. If I remember correctly they wanted around $150 to make up a wheel with zero offset. Another concern is with clearance of the rear hubs. The '72 Chevy rim that I have is to shallow and the hub caps are about 3/8" shy of touching the wheel center when it's installed. I’m afraid I’ll have the same problem even with custom made wheels. The ideal solution would be to use the center out of an original split rim and have a late model rim mounted to it but I had one hell of a time finding split rims last winter. I ended up buying four from a guy and only one was good enough to mount a tire on. Ya get most of them apart and find the rim is all rotted away around where the stem opening traps water. My rims are real nice, no rust and they aren’t beat up to badly. I want to keep a set of bias plies mounted up on them just in case I ever get it to the point of showing it.
I might try the drive shaft as a last resort Dave, but like I said, with it up on the jack stands at 45mph indicated, there was no shake-em-up.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I heard a story of someone buying a military truck at auction. Drove it home, but had a terrible vibration. come to find out one of the rear tires had a new flap in it... still packaged up and just tossed in the tire loose.
Probably not your problem, but interesting.
Grigg
---All pictures---
Don't know if my experience can relate but maybe some one will find it interesting.
I had a F150 that was doing exact same thing.
Replaced every thing we could think of. Spent about 1000 dollars working on it. Finally a mechanic that I had not used before took my brake booster off the master cylinder and adjusted the linkage inbetween them. Put booster bake on and the truck never did it again. He didn't charge me a dime.
Some how the booster was causing a slight rear wheel drag after I reach a certain speed or temp. This resulted in the rearend bouncing and shaking all over the road. It was wearing my brakes out faster but not so that i could really notice.
Strange,,,,,i know.
Nope these are old bias plies with a tube, they'd nave a hard time getting the flap in the tube.
I'm pretty much convinced it's the old snow tires being slightly out of round. I have two more of the same tires I have on the front coming for the back, hope to have them by the end of the week.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
1 Offline
does anything change with a small load in the back of the truck? i take it you have rotated the tires with no change.
My minds made up, got new tires coming for the back.
Denny G
Denny G
Sandwich, IL
Since I got my truck, I've added an O.D., dual exhaust, HEI, radial tires and new shocks. I also lined the cab under the original floormat with dynomat. The change that made the most noticable and significant difference was definately the radials. It really helps the truck move around with todays traffic and with a lot more comfort. So much so it blew my mind. Keep in mind that the 1st thing I did when I drove it home was to take it to Les Schwab to put put new tubes and tires on the original split rims. Pretty much the same size/look as original. That helped a little, but nothing compared to the radials I added a couple years later. Food for thought. I know it can be expensive, but for me it was SO worth it.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
I started out this venture last September with the intention of restoring this as close to factory original as I could. So far I've been holding pretty true to the course. I’ve had to redo many of the replacement parts that I have bought and I’ve made my own parts in some cases that were exact copies where I wasn’t satisfied with the repro parts.
It was not in the plan to show the truck or crown her a trailer queen, with that in mind I took her for a jaunt down a couple of dusty old gravel roads on my outing yesterday. I did however feel somewhat reluctant since I had put many hours and a lot of care into striping, repainting and baking everything that could be unbolted on the under carriage.
After attending a few car shows this summer the thought has occurred to me to bolt the fire extinguisher on the kick panel and take her to the dance. Her dress is kind of tattered, (I’m planning the body work this coming winter) but I think she’s a real good example of an original 1950 work truck and might be of some interest to the onlookers.
So, this is why I’m so adamant about keeping the original 15” split rims and 7.00-15 bias plies.
Now all that is just fine for the ball but Monday morning I am not opposed to fitting her up with work shoes. I would like to find a set of stock looking 15”x 6” eight lug, tubeless wheels with a 3” offset so I don’t have to run adaptors and a deep enough center that I could use the original hub caps on the rear, remember we’re looking at a 3/4 ton here with those big old hubs sticking out the back. I would like to find a radial tire that was the same height and maintained the stock appearance. I would like to have a smooth ride on a daily basis and not have to chase the road with the steering wheel, I’d like all of this and would even dip into my pension to pay for it if I could get some pictures, names, styles, series, models, manufactures, sizes, etc., that would get me there.
I’ve seen many pictures posted here of 1/2 tons, (their easily fixed) and 3/4 tons with fancy aluminum or mag wheels. I’ve heard a half dozen stories about finding wheels for trailers that will work but haven’t been able to find any thing like that around here even though I live in a heavily industrialized hub of the Midwest. The only trailer wheels I have seen round here are the flat spoked style.
ENOUGH BS for one session, I gota go make lunch for my Big old wife and get her off to work!
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny, one thing you might want to consider is the diameter of the brake drums. When I was running the 59 model 3800 with 18" tube type tires and split rims, drop-center wheels would not fit over the rear brake drums. I would have had to go to a 19.5" tubeless wheel for brake clearance, so I just stayed with the 18's. On your 3/4 ton, you might need to swap to a 16" wheel, or possibly a 16.5" for brake drum clearance when you consider the drop center wheel necessary to mount a tubeless tire. Finding stock-appearing 15" 8-lug wheels might be a challenge, too. 16.5's are a direct swap height-wise for 15" tube-type tires.
[img]http://thumb11.webshots.net/t/52/452/5/7/74/2835507740096215731EDCLJS_th.jpg[/img]
Work shoes, as you say. This is a one-ton truck. The rims are from a used-parts place, 16 x 6, and I am well pleased with the fit and the way they work. click on the pic and take a close look. This is a solution to your problem.
1951 3800
-hotshoe
Now see mark, that's the point I'm trying to get across, where can I find this used parts place so I can get a set of rims for my 3/4 ton. Are you talking about what we call a junkyard? What make of vehicle did they come from? What year was it, what model? I’ve been asking at swap meets, friends, all around the junk yards round here all summer without success.
Denny G
Denny G
Sandwich, IL
These were ff a '78 GMC 3/4-ton 4x4, acquired from a used-wheel and tire merchant. Guy assured me that any stock (and some aftermarket) 8-hole 16" wheels would fit Dodge or GM to '87. Go prepared to knock one of your front wheels off and try it. If it seats against the drum, and misses your tie-rod ends, yer in!
1951 3800
-hotshoe
Thanks Mark, I picked up a set from a 77 Chevy 3/4 ton 4x4 pickup that my nephew just scraped out and here’s some pictures of them for comparison. They are 16.5” x 7”, and they rub on the stock tie rods and the tire scrapes the frame in the rear. The center spider is shallower than the original split rim and the stock hubcap will not fit because of the way the rear hub sticks out. It holds the cap away from the edge of the center about 3/8". With out using adaptors or having the off set changed on these wheels there is no way they could be used on my 1950, 3/4 ton.
Pictures--
The 16.5” x 7” tubeless shows no frame clearance;
http://rides.webshots.com/photo/2080928720098611668QKljsR
The 15” x 5.5” split rim with frame clearance;
http://rides.webshots.com/photo/2539948970098611668CQNynL
A side-by-side width and profile comparison of the two;
http://rides.webshots.com/photo/2931165220098611668HyNEMA
The center hubcap mounting depth variation;
http://rides.webshots.com/photo/2145546510098611668iseVbN
I’m still in search of a practical answer. And I still think the best option would be to gather up four old split rims and have the centers mounted with a 3” back clearance to newer style tubeless rims, if that is possible.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Back in the late 70's, I used to buy wheel blanks without centers from a place in Fresno, California and fabricate my own wheel centers out of flat steel plate for my dirt track car. I used a triangular gussset plate between each lug bolt hole for reinforcement. Ugly, but effective, and I could use any offset I wanted.
I've also fabricated rims using different centers, as you've suggested. The older centers for tube-type wheels are riveted, not welded, and they're relatively easy to remove by drilling out the rivets. Waaaaay back in the 40's and 50's, hotrodders used to "reverse" wheels by simply knocking out the rivets, and re-riveting the centers with the long offset toward the outside of the vehicle. That put the valve stems to the inside, so the wheels were smooth-centered.
Lathe-turn or grind the centers to fit your replacement wheels, and build a jig to support the center at the right height with the assembly set up on a flat workbench or a smooth shop floor. Tack-weld the center in place, and check for runout by mounting the wheel on a front spindle with a dial indicator on the flange. Adjust the runout as necessary before completing the weld. A brake lathe or a wheel balancer also works for this step. I used to stick-weld my wheels, but a MIG is probably a better idea.
Balance the wheels without tires on them, adding weight where necessary with the MIG to get as close as possible to perfect balance before mounting the tires. Good luck!
Sorry, Denny. Sounds to me as if I hit the jackpot, although this guy also had 16x6" steel wheels. I also thought I'd need 225 tires, but he assured me the 235/85R16's would fit. So I told him he could try it on his nickel, and when they went - smooth as silk - I paid the man.
Should you be looking at 16x6 instead of 16.5x7?
1951 3800
-hotshoe
That’s right along the lines that I was mulling over in the old head Jerry. I have a Miller Tig welder and would probably Tig weld through the rivet holes of I did try it. Also have a couple of Bridgeport’s, and a 6” and a 16” lathes so fixturing it wouldn’t be a problem. I am worried about getting it dead true, might not be to noticeable while beatin’ around on the old dirt, but at 55 on a smooth paved highway it would have to be pretty true. When we were running the midgets and sprint cars on the pavement 120 or 130mph was not to unusual and the rims needed to be pretty true, of course magwheels not steel.
If you looked at the pictures you would have seen that I already have drilled out one center to see how it would fit one of those 16.5” rims. Both centers are 14.125” out side dimension, don’t know if that is standard for Chevy 3/4 ton 8lug wheels but like I said before what I would need are some decent old 15” split rims that aren’t all rusted out to get the centers out of and I could either buy new rims somewhere or find junkers like I have off the ’77, 4x4 and drill out those centers. The old rivet holes could be filled very easily. On the same note, anybody know how they seal the rivets in the tubeless rims like the one that’s in the pictures above? Or does anyone know of a wheel maker around Chicago, IL that could supply new rims or maybe even swap out my old centers in their jigs and re-drill and rivet them?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Anonymous
Unregistered
Anonymous
Unregistered
Hey Denny if you can't find anyone you may want to give these guys a call http://www.rallyamerica.com/ from what I have seen & read they must have their stuff together unlike some of the other wheel guys && really treat folks right...
The rivets themselves, if tight will seal. Paint inisde and out may help too.
---All pictures---
I ran some hand-built wheels on a Sunbeam Tiger at 160+ MPH without any problems. They were fabbed up on a big lathe at the US Army auto hobby shop on Okinawa in 1971. That car, with one of my engines in it, competed in the Macau Grand Prix the following year, after I headed back to the USA. I was a USAF electronics tech back then.
Macau. Is that the one which goes up the side of a mountain and then back down?
1951 3800
-hotshoe
45 on a back road with that truck will probably handle much better with a load also.
I'm not sure if this would be the same application for your AD, but you can look into it.
I have a '46 3/4ton with the 15" 8-lug split rim. I was told to look for a mid-80's K20 Chevy 16" rim. So I stopped at the local junkyard and they had a set. Most yards have them in a wheel rack or you can unbolt them off the junker. I paid about $30/rim. The look is almost identical to my originals except for a few buldges in the hub for the newer style hubcaps. They have a 4" backspace and are 6.5" wide. I've mounted one up to both the front and rear and have no clearance problems with a 235/85/16 over the rear brakes or the front tie rod end.
To me, it's an easy and cheap update. Locate one at a yard, drive over, and see if they'll let you fit one up to your truck so you're not out $30. I wouldn't think it would be to hard to find one rim and try it.
As a side note, I've priced both bias and radials. I thought a no-name bias would be cheaper but in the end a name brand radial is the same amount.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Hotshoe, Macau was a Portugese colony on the coast of mainland China, so there aren't any mountains to speak of in the area. Most of the course is run through relatively narrow city streets, with some high-speed straightaways along the sea wall, and elsewhere there's room to stretch a car out. It's a 6.2 Kilometer closed course.
I worked with a couple of Department of Defense civilian employees in the Okinawa Sports Car Club while I was stationed there, building engines and doing chassis setup in the early 70's. Two of the cars I worked on got flown to Macau on a C-130 and competed in the race. Don't know how that happened, but some strings got pulled, I'm sure! We had some wealthy, high-ranking GS civilians in the club. I crashed a brand new Mazda RX-2 in the 1972 OSCC hill climb, broke it in half, and broke my neck. That ended my driving career, as I decided it would be nice to see my 1-month-old daughter grow up!
USAF, TTY maintenance ’64-’68, Philippine islands and Viet toward the end, some good times back then, some bad!
I tried Jerry, but I couldn't break my neck in the midget or a sprint car so I switched to Aerobatics in a Pitts Special biplane. I'm to dam% old and broke to do any of it now days so all I can do is talk about it. At least I kept the biplane, sits in the hanger with a couple of hundred hours of time on it, taint turned a prop in 20 years. I just can't bring my self to get rid of that one, took me 5000 man hours to build it.
So you’re saying that you welded the wheels while mounted in the lathe, or did ya turn them out of a billet??
Thanks for the tip workmaster, can’t find your real name! Nice restoration job. Since the 46 was the old style 3/4 ton I’m wondering just how much different the suspension is from the AD as far as the clearances. I see from your pics that the rear hub looks very similar to the AD.
That ’77, 4x4 16.5” wheel in the picture has a 5” offset, 2” more than the stock split rim.
Lets see if I got this right, the K20 was a 3/4 pickup and the C20 was a Suburban, zat right???
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Page 1 of 2 1 2
