| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | Jon, if you have access to a lathe, it would be very simple to bore that HEI housing for a lip seal on the shaft. That would absolutely prevent oil from migrating up into the pickup coil area. I'd also suggest installing a Torrington needle bearing below the seal while the housing is in the lathe. Jerry
