7 members (3B, Bill Hanlon, TooMany2count, Otto Skorzeny, Peggy M, GDW, 1 invisible),
114
2
Mod | | | Forums66 Topics128,139 Posts1,056,460 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,502 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,502 | These GM steering boxes are the recirculating ball type. They use a lighter weight grease than some others such as cam-and-lever. Make sure you sue the specified grease. As I recall cornhead grease comes in several viscosities; the heavier ones not only won't run out of the box through leaking seals, they won't lube the balls in the recirculating mechanism. What Tommy said is correct. I mix cornhead grease and 90 weight oil until I get something that resembles Jell-O before it sets up. That way the balls all get lubricated and there's no chance of the grease channeling in cold weather. If the grease is too thick to pour into your steering box (through the hole designed for that) it isn't going to distribute correctly inside your box. If you will replace the pitman seal and the thin gasket on the adjustment plate and use some Permatex on your worm shaft nut these won't leak at all.
Entire Thread
Steering Wheel Slop, where do I start
| JoeDude | 11/16/2023 4:24 PM |
Re: Steering Wheel Slop, where do I start
| WICruiser | 11/16/2023 8:52 PM |
| Wrenchbender Ret. | 11/16/2023 9:08 PM |
| JoeDude | 12/02/2023 10:44 PM |
| Otto Skorzeny | 11/16/2023 11:07 PM |
| Guitplayer | 11/17/2023 11:57 AM |
| JoeDude | 11/17/2023 5:36 PM |
| hcb3200 | 11/20/2023 8:02 PM |
| MNSmith | 11/17/2023 6:04 PM |
| Guitplayer | 11/17/2023 7:17 PM |
| Fibonachu | 11/17/2023 7:30 PM |
| Hanks custodian | 11/17/2023 7:33 PM |
| 52Carl | 11/21/2023 1:41 AM |
Re: Joe dudes issue.
| Guitplayer | 11/26/2023 3:38 PM |
| 1Ton_tommy | 12/01/2023 8:47 PM |
| Hotrod Lincoln | 12/01/2023 9:25 PM |
| klhansen | 12/01/2023 11:58 PM |
| Hanks custodian | 12/02/2023 3:08 AM |
| Phak1 | 12/02/2023 3:18 AM |
| klhansen | 12/02/2023 3:56 AM |
| Hotrod Lincoln | 12/02/2023 5:37 AM |
| Phak1 | 12/02/2023 1:24 PM |
| Otto Skorzeny | 12/02/2023 11:55 PM |
| Fibonachu | 12/03/2023 12:59 AM |
| 1Ton_tommy | 12/05/2023 6:19 PM |
| Jon G | 12/05/2023 10:35 PM |
| Jon G | 12/05/2023 11:43 PM |
| JoeDude | 12/06/2023 12:14 AM |
| Jon G | 12/06/2023 12:38 AM |
| JoeDude | 12/07/2023 5:48 PM |
| Jon G | 12/06/2023 1:41 AM |
| Mike B | 12/06/2023 1:58 AM |
| klhansen | 12/06/2023 2:21 AM |
| JoeDude | 12/06/2023 5:59 PM |
| klhansen | 12/06/2023 8:53 PM |
| JoeDude | 12/06/2023 9:03 PM |
| Mike B | 12/07/2023 3:35 AM |
| JW51 | 12/07/2023 6:16 PM |
| klhansen | 12/07/2023 7:59 PM |
| Jon G | 12/07/2023 8:19 PM |
| Jon G | 12/07/2023 8:39 PM |
| JoeDude | 12/08/2023 2:50 AM |
| Jon G | 12/08/2023 2:59 AM |
| 1Ton_tommy | 12/08/2023 6:20 PM | |
