| | | Forums66 Topics128,139 Posts1,056,448 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | The correct method of adjusting sector gear preload is to use an inch-lb. torque wrench on the steering wheel center nut and measure the increase in turning torque WITH THE PITMAN ARM DISCONNECTED as the wheel crosses over the center point. I've outlined the procedure many times in the 20-something years I've been on this site, and to the best of my knowledge, nobody has ever done it that way. Good luck! Jerry Yep. The equivalent of the torque wrench is using a fish scale at the outside of the steering wheel. The spec in the service manual is based on using a fish scale. If you use a torque wrench, you need to do a little math to get the right number, taking the radius of the steering wheel into account. Either fish scale or torque wrench can be used.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | |
Entire Thread
Steering Wheel Slop, where do I start
| JoeDude | 11/16/2023 4:24 PM |
Re: Steering Wheel Slop, where do I start
| WICruiser | 11/16/2023 8:52 PM |
| Wrenchbender Ret. | 11/16/2023 9:08 PM |
| JoeDude | 12/02/2023 10:44 PM |
| Otto Skorzeny | 11/16/2023 11:07 PM |
| Guitplayer | 11/17/2023 11:57 AM |
| JoeDude | 11/17/2023 5:36 PM |
| hcb3200 | 11/20/2023 8:02 PM |
| MNSmith | 11/17/2023 6:04 PM |
| Guitplayer | 11/17/2023 7:17 PM |
| Fibonachu | 11/17/2023 7:30 PM |
| Hanks custodian | 11/17/2023 7:33 PM |
| 52Carl | 11/21/2023 1:41 AM |
Re: Joe dudes issue.
| Guitplayer | 11/26/2023 3:38 PM |
| 1Ton_tommy | 12/01/2023 8:47 PM |
| Hotrod Lincoln | 12/01/2023 9:25 PM |
| klhansen | 12/01/2023 11:58 PM |
| Hanks custodian | 12/02/2023 3:08 AM |
| Phak1 | 12/02/2023 3:18 AM |
| klhansen | 12/02/2023 3:56 AM |
| Hotrod Lincoln | 12/02/2023 5:37 AM |
| Phak1 | 12/02/2023 1:24 PM |
| Otto Skorzeny | 12/02/2023 11:55 PM |
| Fibonachu | 12/03/2023 12:59 AM |
| 1Ton_tommy | 12/05/2023 6:19 PM |
| Jon G | 12/05/2023 10:35 PM |
| Jon G | 12/05/2023 11:43 PM |
| JoeDude | 12/06/2023 12:14 AM |
| Jon G | 12/06/2023 12:38 AM |
| JoeDude | 12/07/2023 5:48 PM |
| Jon G | 12/06/2023 1:41 AM |
| Mike B | 12/06/2023 1:58 AM |
| klhansen | 12/06/2023 2:21 AM |
| JoeDude | 12/06/2023 5:59 PM |
| klhansen | 12/06/2023 8:53 PM |
| JoeDude | 12/06/2023 9:03 PM |
| Mike B | 12/07/2023 3:35 AM |
| JW51 | 12/07/2023 6:16 PM |
| klhansen | 12/07/2023 7:59 PM |
| Jon G | 12/07/2023 8:19 PM |
| Jon G | 12/07/2023 8:39 PM |
| JoeDude | 12/08/2023 2:50 AM |
| Jon G | 12/08/2023 2:59 AM |
| 1Ton_tommy | 12/08/2023 6:20 PM | |
