| | | Forums66 Topics128,090 Posts1,056,368 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | Do to a up coming medical operation that will put me down for 3 or 4 months maybe longer,i need to put betsy away for the winter.What would any of you guys do ,Drain it or Stabil it. FEED BACK PLEASE. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I use Stabil every year during the 2-3 months of winter down time & have never had an issue with gas going bad.
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I also have never had an issue using stabil. 2-3 months is not that long of time. | | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | STABIL IT IS,did not need the extra work in the spring. THANKS | | | | | Joined: Jul 2004 Posts: 2,988 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,988 | | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | And best wished for your 'other' project (medical).. Hope things trun out great!@ | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | I keep Stabil in the tank the whole time we are restoring. Never had an issue with carbs sitting way longer than 3 to 4 months. Good luck with the operation.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | STABIL IT IS,did not need the extra work in the spring. THANKS One additional thought. After dumping in the Stabil run the engine for a few minutes to get it in the lines, fuel pump and carburetor.
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | STABIL IT IS,did not need the extra work in the spring. THANKS One additional thought. After dumping in the Stabil run the engine for a few minutes to get it in the lines, fuel pump and carburetor. Also keep your fuel tank full to the top to prevent condensation, And crack the cap so she'll breath/vent. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | My pops has put Stabil in all his fuel for his small engines(lawn mowers, weed eater, etc..) for years and years.
That way when he put 'em up or doesn't use 'em every week, they don't gum up with this 'modern gasoline'.
Good stuff.
-W | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Use Stabil on stored units up to 6 mos+ | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | some two stroke oil works wonders...my dad used to only use mixed gas in the lawn equipment to simplify things, and it seemed to completely eliminate rusted through gas tanks. | | | | | Joined: Jun 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 51 | My truck had been parked in a barn by the previous owner for many years. When I got it home, I did the MMO thing (down all 6 cylinders) turned it over by hand with the old plugs out, put the plugs back in, cleaned the points, poured some fresh gas down the carb, and she fired right up, and ran off the old gas!! It had been treated with Stabil, and I was mighty impressed!!
Love that old 6!! :) | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | some two stroke oil works wonders...my dad used to only use mixed gas in the lawn equipment to simplify things, and it seemed to completely eliminate rusted through gas tanks. Two stroke oil is not a stabilaizer and will knock down the octaine rating very quickly leading to engine knock.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | No one said it was a fuel stabilizer, if you read what I wrote and what you quoted, it says "seemed to completely eliminate rusted through gas tanks" I hardly think it would have any effect in an engine that at the height of its development achieved what, 7.5-1 compression? And it would only be in the one tank that has set through the winter, I never said to use it on a steady basis. I also never said to NOT use stabil, I use both if it will be sitting for a long period.
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Do to a up coming medical operation that will put me down for 3 or 4 months maybe longer,i need to put betsy away for the winter.What would any of you guys do ,Drain it or Stabil it. FEED BACK PLEASE. The thread is about adding stabilizers or not. 2 stroke oil is not hydroscopic so will not absorb any water in the fuel tank - which causes rust. The best advise to prevent tank rust as has been mentioned already is to keep the tank full so the air doesn't condensate and form water droplets that sink to the bottom of the tank and cause rust.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I know what you meant brokenhead  I'm all the time putting "mixed" gas in what ever needs it.....my lawn mower, my tiller, my 37pickup if I need it to get to the gas station. I understood what you meant.....and yes, I like stabil to. I've used it for many years. | | |
