Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#94464 01/31/2006 11:02 AM
Hey Guys, I have been having trouble with my speedo so I broke down a bought a new one from ChevyDuty. My question is... are these things calabrated How do I know if I am really going 55 ?
cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#94465 01/31/2006 2:52 PM
you could check it against how long it takes you to go a mile,,dont know if it is calabrated or not,,,good luck ,,,,Fred
Redryder pix
My Hotrod
#94466 01/31/2006 8:17 PM
I check mine against a GPS while I'm driving. Probably not accurate down to fractions of a mph, but good enough for me to get an idea of how accurate my speedo is.
Daily Driver 63 C-10 LWB Fleetside
#94467 01/31/2006 8:34 PM
A rebuilt speedo had better be calibrated... Use a stopwatch and time it off mile markers on the highway - good way to tell if you're close.
1954 GMC De Luxe COE
#94468 01/31/2006 11:11 PM
Riding in the Passing Lane
The speedo head is usually calibrated. Sometimes the trans. drive is off. Check the odometer against the mile markers on the freeway.
1972 Chevy c10 Cheyenne Super
#94469 02/01/2006 12:21 AM
Speedometer heads should be calibrated to read 60 MPH at 1000 rpm on the cable.
Paint & Body Shop moderator
#94470 02/01/2006 12:55 PM
Ok, I bet the trans. drive IS off.....So how do I fix it? I bet Im gonna have to go to another section of the forum!
Cliff59
#94471 02/01/2006 2:08 PM
there is a company that offers a trans adapter but i can't find the name. someone on the site has it or go to search and find it. not cheap i think about 150.00. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#94472 02/01/2006 3:56 PM
Ron, I may be incorrect but I think that adapter is for converting electronic to standard,,your s-10 transmission may need one, that is why I went to earlier s-10,,, at any rate , I may be total off base and if so,, just over-look it grin Fred
Redryder pix
My Hotrod
#94473 02/01/2006 6:30 PM
Cliff, it is calibrated to the truck by changing the drive gear in the transmission. There are several speedometer shops listed in the Ft. Worth yellow pages.
#94474 02/02/2006 12:14 AM
2 Offline
I have been told that the speedo head can be calibrated to the speedo gear at the transmission. Just had mine done but haven't checked it yet.
Tom
#94475 02/02/2006 7:44 AM
Hey Cletis,Joker and Fender I will ask you about this again when I see you and the rest of the TX Connection at Decatur!
cliff59
#94476 02/02/2006 3:49 PM
by then we will forget what lie we told you grin Fred
Redryder pix
My Hotrod
#94477 02/03/2006 10:14 AM
Stop Fred grin you are killing me grin
Cliff59
#94478 02/03/2006 11:16 AM
Where can you get different drive gears for the transmission, and how would you know what you need?
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#94479 02/04/2006 2:19 PM
2 Offline
I would think that any good speedo shop would be able to calibrate the unit.
Tom
#94480 02/05/2006 6:40 AM
There's an adapter with easily changeable gears that fits between your speedo cable and your tranny. Chevy used 'em on a lot of their 4X4's through the 60's and 70's. Once you hit the wrecking yard and find one,(you might get lucky and find one with the right gears) you can either get replacement gears from a speedo shop or from GM. I have one out in the shop somewhere...
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
