8 members (JoeDude, dt235sd, Peggy M, Hotrod Lincoln, Perro, 48jim1ton, Shaffer's1950, 1 invisible), 72 guests, and 3 robots.
Topics128,032
Posts1,055,516
Members48,425
#937349 04/21/2013 12:03 PM
I am posting this question here, because I don't think this is an electrical issue.
Is there a way to repair or replace the copper line from the temperature sensing unit to the gauge?
I have a couple of the gauges from my collection of 41-46 parts with the copper line cut off. I was just wondering if there was a fix.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #937352 04/21/2013 12:08 PM
No, there is a gas inside the tube that is on the temp gauge that cannot be replaced once it is released.
Pete
MikeE #937363 04/21/2013 12:58 PM
Get a hold of these guys and see if those type of gauges can be fixed.
http://www.bobsspeedometer.com/1/120/index.asp
Brian
1955.2 3100 Truck
MikeE #937371 04/21/2013 1:33 PM
I know this has been discussed before but here's what I remember.
The tube has a bulb on the end filled with ether (I believe) and some of the vendors offer repair services for the gauges and can also change the length of the capillary tube if needed.
Who does it? A search on this site could probably find the names of repair shops.
Jeff
My 1953 Chevrolet
1947.1 Gallery
MikeE #937509 04/21/2013 10:05 PM
A fellow over in Greenville can do it but I think the charge is around 90 bucks. Heck, you can probably buy a repop for that!
MikeE #937607 04/22/2013 10:48 AM
Google "capillary temperature gauge repair" Many options.
Ed
MikeE #937624 04/22/2013 11:56 AM
Check Ebay their are a couple of vendors who have them NEW for around $ 70. Jim Carters Truck Parts on ebay.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
MikeE #937648 04/22/2013 2:40 PM
Sir Searchalot
Sir Searchalot
Don't need no stinking gauge, Just plumb in a pressure pop off valve from your water heater. chug
MikeE #937659 04/22/2013 3:25 PM
That is a ridiculous idea. I hope no one takes you seriously. This site is for real ideas, not jokes.
MikeE #937677 04/22/2013 4:32 PM
Sir Searchalot
Sir Searchalot
Sorry to all those who would plumb in a water heater pop off. That was a joke. I will go back to my serious mode. My "real idea" is to buy an aftermarket unit.
MikeE #937797 04/22/2013 10:32 PM
You could give the information in the attached a try, your gage is already bad so what's to lose?
www.29buickphotos.com/Repairs/Temp-Gauge-Repair/7802526...
