Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 146 guests, and 3 robots.
Topics128,290
Posts1,058,565
Members48,492
Page 79 of 177 1 2 … 77 78 79 80 81 … 176 177
Hauled trash.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Originally Posted by Chooglin
Just got The Old Man outta storage and into my new garage to work on this winter. Looks like itll be a cold one here in MT... boy i love only being able to work on it in the winter.
is
Hope to have it running and rolling by spring!
Chooglin
I saw your pics, the old man is looking younger
~Jim
I bought a 35.00 timing light then remembered there was no positive connect under the hood. Make note: route a + contact to firewall. Luckily I have a stack on batteries on a tender a few feet from the truck.
~Jim
Pulled the gearshifter and make new pivot pins for the top of the 'box.
Finally shot a coat of gloss black on the original 6v horn.
Got it running after sitting for 20 years!!!
sprayed everthing thats supposed to move with penetrating oil
sanded j b weld repairs to cracked steering wheel, looking a lot better, primer tomorrow.
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
GOT IT FINISHED!!!
Just a month shy of 6 years since I rolled it off the trailer. She's "coming out" today for a ride to town and my appointement with the Dr. Make some errand stops for a chance to show it off, burger for lunch,and back in the shop for some more waxing. Not really rubbing on it, more like caressing it.
I need to take some time and learn how to load the pictures I've taken, but you can take my word for it, I'm one happy camper!
Tramp
dj durant
More pix on Flickr
Sorry Tramp but the guys hare are a "hard nose" lot and without pics they will doubt you're finished. pix
~Jim
got brakes & wired ignition....with a little luck it'll fire in the morning
I re wired the brake lights/turn signals on the Suburban. I had a nasty little intermittent short that blows a fuse every 300-400 miles but I can't find in the shop with a meter. I hope that fixes it.
Chipped my freshly painted 6v horn, cussed a bit then sanded and reshot.
http://rustyfiftyone.com/2012/11/17/honk-honk/
Replaced the guages in the 48. Was going to just replace the 30lb oil guage with a 60lb unit. Had a extra guage cluster with better kooking gauges so moved the ammeter and fuel gauge as well.
Don't I know it? After hanging around this circus for the past 6 years, I've learned to just stand around with my mouth open and agape in awe and amazement. Bunch of good people, but I've had more than a couple of "headscratching" moments. I don't mess with the TV remote and have trouble setting the clocks in the hosue, but I'm determined to figure out this photo posting thing sometime. Guess I should just give up and call my 9 year old grandson to come show me how to do it. Bear with me and we'll get it done.
dj durant
More pix on Flickr
dj, I've seen a couple of your finished pics but as you can see these guys want proof to smile but I know you got'um if you need a witness. LOL
Gas tank out and ready for the vat. windshield rolls out and back
cowl vent the same.ordered drivers for those crazy fasteners
OK Alvin, if you'll sign the affidavit swearing to the work done we'll pass it through. grin
~Jim
Well, I finally got the seats bolted down permanently.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Panelseatsect097.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Panelseatsect098.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Panelseatsect099.jpg
Cletis, I posted these in the Burbs & Panel for those guys to so if you want to delete one of them just take your choice.
Jim, I'll give you a hint on Tramps truck.....its White smile
Muen buen senior.
~Jim
Removed the front brakes and found the rt spindle at some point spun the outer wheel bearing. Will need rt spindle along with brake drums, shoes,seals and cyl.s It is a money pit but so is doing anything else.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
On my '51, removed steering column and then lifted cab off frame to be able to work on underside easier. First tilted cab on its back using an engine hoist. Once i had it on its back, then rotated the cab so that the floor area is under my lights. Had my 12 yr old helping me, and it took a couple of hours with having to support the cab and re-arrange the hoist a few times. A very productive day. Uploaded some pics.
http://s848.beta.photobucket.com/user/malibu67/library/1951%20Chevy%20Truck
1951 Chevy 3100
I just got done putting a new wiring harness in my '59. Had to alter it a little as it was for a key start and an electronic ignition. This was my first time to do something like this so I was pretty nervous about hooking up the battery. It worked! I have a 235 with points and a foot starter but I figured out how to alter my harness to make it work. It didn't even drain my battery over night. Now I just need to swap the engine and I should have a new truck.
Gene
1959 Apache
This is my first post to this forum but have been using advice and guidance provided by "Stovebolter's" for about 6 months. My son and I installed the front spindles, the kingpins and bushings are new and next is the brakes and a new dual res. master cylinder.
1958 Chevy 3604
Welcome to the stovebolt Gary. Drop by the Welcome Centre and say hello there. (A moderator of this forum may move it for you)
Sounds like you are well into your project. As you have seen there is tons of knowledge here and lots of nice folks. Let us know how we can help.
Hello Gary and welcome. Good luck with your 58.
~Jim
Installed my headliner and both inside visors yesterday. Piece of cake. Also replaced the thermostat and found out my heater realy does work. Today I'm going to DRIVE IT! smile
Iowa? Yeah you're gonna need that heater.
~Jim
ten Offline
body finishing ! my 4 fenders is pratically done,and initially was in very bad shape, some patches was needed, a lot of welding,hammering,fitting, sandblasting,finishing,priming...well about 40-50 hours each...
Ten,
Where are the pics?
~Jim
Took the bucket seats out of my Apache and put an original bench seat back in. Definitely looks alot better.
ten Offline
i ve put a link in my profile, some photos of my hobbies,it needs an update i know, i m working on it too !
Jim, I use the 12v off the back of the alternator for the 12V positive on my '53
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I've been re-wiring the '59 for what seems forever. Just about done replacing every stich of wire on the truck with new.
Took a weekend off to take the '53 to the big car show in Lakeland - came home with the blue ribbon drive
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
We have ignition! Last time this SBC ran was when I bought the Camaro from a tow yard and had it towed to my house in 1995. Yesterday after hooking up the throttle cable and shift linkage I fired it up. Drove it out of the shop and back in just to see if the gears worked.
http://img.photobucket.com/albums/v518/Blacktailer/1949%20Chevy/IMG_5415.jpg
Thanks John,
I will use that contact next time. I do wonder what I will do if I need to jump start as my battery cover is under carpet.
It would be a real hassle to drop the battery.
~Jim
I went to a pull a part. Took the steering column out of a 1988 chevy 2500 pu removed the lower half steering kunckle and then bolted right in for 44.00 I got a tilt wheel with key and shifter......SCORED then removed both rear fenders.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
John, your a better man than I am. I chickened out and let my nephew wire my panel.
....I picked up the lower cab windlace retainers from the powder coater today for my panel. They blasted and powder coated them for 20 bucks. They look nice and will match my seats and trim.
Got the headliner, door panels and LED dome light installed
Robert C.
I'm a Genius in the making.
1950 3600
