BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,780 Posts1,039,291 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Dec 2010 Posts: 9 New Guy | New Guy Joined: Dec 2010 Posts: 9 | is there a scorce for long mirror arms to fit 46 1 1/2 ton thanks for any help | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | Shop Shark Joined: Dec 2003 Posts: 2,733 | If your thinking of WestCoast mirrors with 16.5x7 heads then those can be purchased thru many automtive(truck)lighting delaers or from Velvac in Milwaukee. You can find their website. | | | | Joined: Dec 2010 Posts: 9 New Guy | New Guy Joined: Dec 2010 Posts: 9 | looking for single arm type simular to orignal | | | | Joined: Nov 2011 Posts: 1,608 'Bolter | 'Bolter Joined: Nov 2011 Posts: 1,608 | Sawdust46, Good to see another Deco era bolter in NC, welcome. I searched the Chevy aftermarket suppliers for mirror arms as well and came up with nothing. It appears that the vendors only focus on 1/2-3/4 ton trucks. The arms are not the same. My sugestion is to look into military vendors or other makes such as: http://www.vintagepowerwagons.com/pdf/parts/18body.pdfOkay folks, please don't attack me for suggesting to put Dodge parts on a Chevy. I think that most remanufactored mirror arms are based on the King-bee originals and they were fairly standard issue for most truck makes. Do your mirrors mount on the upper door hinge? I hope this helps in your search. Paul | | | | Joined: Dec 2010 Posts: 9 New Guy | New Guy Joined: Dec 2010 Posts: 9 | i have short mirror arms mounted to door hindge with homemade extendions one has broken above hindge. thanks for the website.i might try something homemade and mount to cowl. | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | Wrench Fetcher Joined: Mar 2010 Posts: 66 | | | | | Joined: Dec 2010 Posts: 9 New Guy | New Guy Joined: Dec 2010 Posts: 9 | fixed , i driled two holes in the broken hindge mount added some tubing flatten the end put on my mirror. it looks good enough i will do the other side the same. | | | | Joined: Oct 2012 Posts: 60 Shop Shark | Shop Shark Joined: Oct 2012 Posts: 60 | Enter this into an Ebay search.NOS Telescopic Mirror Bracket Jeep Willys MB Ford GPW Dodge WC CCKW WW2 Truck.
I've had my eye on for awhile. Out of my price range mjl | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | 'Bolter Joined: Apr 2005 Posts: 1,107 | ive bought from grote for some items ive also bought from berubes. http://www.berubes.com/index.html | | | | Joined: Aug 2006 Posts: 129 Shop Shark | Shop Shark Joined: Aug 2006 Posts: 129 | I have been looking for the optional style that Chevy used on the 1-1/2 Ton trucks, at least through the '40's, that had two arms mounted to the top portion of the door and the mirror hung down under the arms. This is the style my 1940 1-1/2 Ton had from the factory when my grandfather bought it new. They did not like them as they bounced around too much and were removed, leaving two 1" diameter or so holes in the top of the driver's door. Would like to put it back original if I could locate the arms. | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | alkay3,
I think that was option number 210 (used through 1946 truck models).
If someone can find a part number, you could place a want at in the swap meet and/or look on eBay.
| | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | Shop Shark Joined: Nov 2010 Posts: 1,159 | Try Accessoryland. Bob's got a 35-year collection of parts for the '41-59 Chevy/G.M.C.'s.E-Mail:chevygmcparts@aol.com. Phone or fax:(563)556-3482. www.accessorylandparts.com. Address:Bob Birch 10793 Route 61 South Dubuque,Iowa 52003. Hope this helps. I installed west-Coast mirrors on my '55 2nd-Series 6500,but I have both the single mirror stalks/w/heads,if interested.Really in no need to sell them,that's why they're not posted under "parts for sale". Hope this helps. | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | 'Bolter Joined: Dec 2003 Posts: 1,144 | Unless he has come up with something different, His are extentions that hook around and bolt to the short mirror brackets designed for small trucks. Functional but I personally don't care much for the look. The small truck brackets used for these extensions attach to top door hinge.
| | | | Joined: Oct 2008 Posts: 126 'Bolter | 'Bolter Joined: Oct 2008 Posts: 126 | I still have a large set that mounts above & below the window, with cross brace, these came off my 1939 1.1/2 ton COE tow truck. I would need to go measure but they are long. It's been a while, but there must be 5 or 6 pieces to each side? I won't be using these on my project.
Darrell, W.L. 1939 Chevy COE tow truck/My Stubbed toe 1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation. I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
| | | | Joined: Apr 2005 Posts: 926 Shop Shark | Shop Shark Joined: Apr 2005 Posts: 926 | If they aren't spoken for,I could sure use those mirrors on my '54 2 ton. What would you need for 'em? Speed | | | | Joined: Oct 2008 Posts: 126 'Bolter | 'Bolter Joined: Oct 2008 Posts: 126 | speed, My brackets are not the original ones for my 39. COE. My driver door also have two holes above the window. These are like ones from a Simi truck. Holes were drilled in my doors to mount them. PM me if you think you are interested in them?
| | | | Joined: Oct 2008 Posts: 126 'Bolter | 'Bolter Joined: Oct 2008 Posts: 126 | There is a adjustable extension mirror & bracket on eBay right now.12/10/12.
| | | | Joined: Aug 2006 Posts: 129 Shop Shark | Shop Shark Joined: Aug 2006 Posts: 129 | Oldschool, I sent you a PM. Do you still have the mirror brackets? Are they the ones that were mounted on your truck above the window in the two round holes? That is what I am looking for. Please let me know. Thanks, Al. | | |
