5 members (51sub, 48jim1ton, Otto Skorzeny, walter74, Gdads51), 82 guests, and 1 robot.
Topics128,041
Posts1,055,593
#892514 10/27/2012 3:56 PM
is there a scorce for long mirror arms to fit 46 1 1/2 ton thanks for any help
sawdust46 #892522 10/27/2012 5:02 PM
If your thinking of WestCoast mirrors with 16.5x7 heads then those can be purchased thru many automtive(truck)lighting delaers or from Velvac in Milwaukee. You can find their website.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
sawdust46 #892528 10/27/2012 5:33 PM
looking for single arm type simular to orignal
sawdust46 #892628 10/28/2012 8:38 AM
Sawdust46,
Good to see another Deco era bolter in NC, welcome.
I searched the Chevy aftermarket suppliers for mirror arms as well and came up with nothing. It appears that the vendors only focus on 1/2-3/4 ton trucks. The arms are not the same.
My sugestion is to look into military vendors or other makes such as:
http://www.vintagepowerwagons.com/pdf/parts/18body.pdf
Okay folks, please don't attack me for suggesting to put Dodge parts on a Chevy.
I think that most remanufactored mirror arms are based on the King-bee originals and they were fairly standard issue for most truck makes. Do your mirrors mount on the upper door hinge?
I hope this helps in your search.
Paul
Lots more pictures
sawdust46 #892657 10/28/2012 10:55 AM
i have short mirror arms mounted to door hindge with homemade extendions one has broken above hindge. thanks for the website.i might try something homemade and mount to cowl.
sawdust46 #892660 10/28/2012 11:10 AM
Did you try Jim carter
sawdust46 #892725 10/28/2012 3:37 PM
fixed , i driled two holes in the broken hindge mount added some tubing flatten the end put on my mirror. it looks good enough i will do the other side the same.
sawdust46 #896344 11/12/2012 10:32 PM
Enter this into an Ebay search.NOS Telescopic Mirror Bracket Jeep Willys MB Ford GPW Dodge WC CCKW WW2 Truck.
I've had my eye on for awhile. Out of my price range
mjl
sawdust46 #896381 11/13/2012 8:15 AM
How long an arm do you want?
Does it have to be an original part?
I will be using telescoping stainless steel arms such as ones you can find on eBay by searching: stainless steel bracket mirror
Here are other possibilities:
http://www.grote.com/product.php?product_number=10002
http://www.grote.com/product.php?product_number=10025
http://www.bigrigchromeshop.com/Merchant2/merchant.mvc?page=BRCS/PROD/UEMB/UP60021P
sawdust46 #896414 11/13/2012 10:44 AM
ive bought from grote for some items ive also bought from berubes. http://www.berubes.com/index.html
51 ashton #896441 11/13/2012 12:43 PM
I have been looking for the optional style that Chevy used on the 1-1/2 Ton trucks, at least through the '40's, that had two arms mounted to the top portion of the door and the mirror hung down under the arms. This is the style my 1940 1-1/2 Ton had from the factory when my grandfather bought it new. They did not like them as they bounced around too much and were removed, leaving two 1" diameter or so holes in the top of the driver's door. Would like to put it back original if I could locate the arms.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
sawdust46 #896462 11/13/2012 2:35 PM
alkay3,
I think that was option number 210 (used through 1946 truck models).
If someone can find a part number, you could place a want at in the swap meet and/or look on eBay.
sawdust46 #896621 11/14/2012 1:28 AM
Try Accessoryland. Bob's got a 35-year collection of parts for the '41-59 Chevy/G.M.C.'s.E-Mail:[email protected]. Phone or fax:(563)556-3482. www.accessorylandparts.com. Address:Bob Birch 10793 Route 61 South Dubuque,Iowa 52003. Hope this helps. I installed west-Coast mirrors on my '55 2nd-Series 6500,but I have both the single mirror stalks/w/heads,if interested.Really in no need to sell them,that's why they're not posted under "parts for sale". Hope this helps.
Mo' Tater
Glen M #896641 11/14/2012 7:29 AM
Unless he has come up with something different, His are extentions that hook around and bolt to the short mirror brackets designed for small trucks. Functional but I personally don't care much for the look. The small truck brackets used for these extensions attach to top door hinge.
sawdust46 #898077 11/20/2012 6:33 PM
I still have a large set that mounts above & below the window, with cross brace, these came off my 1939 1.1/2 ton COE tow truck. I would need to go measure but they are long. It's been a while, but there must be 5 or 6 pieces to each side? I won't be using these on my project.
Darrell, W.L.
1939 Chevy COE tow truck/My Stubbed toe
1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation.
I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
If they aren't spoken for,I could sure use those mirrors on my '54 2 ton. What would you need for 'em?
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
sawdust46 #899338 11/25/2012 10:43 PM
speed, My brackets are not the original ones for my 39. COE. My driver door also have two holes above the window. These are like ones from a Simi truck. Holes were drilled in my doors to mount them.
PM me if you think you are interested in them?
Darrell, W.L.
sawdust46 #902575 12/10/2012 2:18 PM
There is a adjustable extension mirror & bracket on eBay right now.12/10/12.
Darrell, W.L.
Oldschool, I sent you a PM. Do you still have the mirror brackets? Are they the ones that were mounted on your truck above the window in the two round holes? That is what I am looking for. Please let me know. Thanks, Al.
