3 members (Bill Hanlon, J Lucas, Steve_H), 122 guests, and 5 robots.
Topics128,186
Posts1,057,211
Members48,465
Page 78 of 177 1 2 … 76 77 78 79 80 … 176 177
I'll need to find hardware to hide the wire running off the light.
Maybe something like THIS ?
Thanks Jerry.
~Jim
Filled and bled the brakes then took a 200mi back road, road trip to pick up a Wankel rotary and transmission for a buddy. IT WAS AWESOME! No issues whatsoever and the 216 w/ 3OTT, 4.11 and 16x7.50 tires did just fine at 55-60mph on some of the larger rural roads.
Got my drums and shoes back today from turning and re-shoeing ,the part house call me and said my wheel bearings,races and seals were in, went and pick them all up and installed the bearings,races and seals and put them back on my '36 1 1/2 ton wrecker,finished the king pins last week and it will be on the ground tomorrow.Steers like new now! even with my neckers knob on.
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
...finally founmd a set of seats like I want and picked them up today. Buckets came out of a '03 Chevy extended cab. I have them ready to set in the panel maybe tomorrow.....I'll take a pic or two.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/PanelSeats002.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/PanelSeats003.jpg
sealed my cab completely with dynamat like material …took me 5 hours~! Carpet is next! By the way, do you guys know which bench-seat(s) fit our pickups? well other than the OEM of course…I cant seem to find one..
Check the archives here. There are a lot of articles on that subject. Take your questions on this over to the interior forum for more exact information. I spent almost a year earching for this. I didn't want bucket seats because I figured i might need to transport a third person. I bought Suburband 2nd row seats but they were about 2" too wide. I finally gave up and bought these seats
~Jim
New tires all the way around and fresh paint on the wheels!
Last weekend I repainted the old dash to look new again. I smoothed over the hole where the radio went. It looks better. Refaced my old gauges (before) and installed them.
Put new windshield in yesterday and was very disappointed to see that the rubber sat way too low in the upper outboard corners of the windshied opening and barely covered the metal lip of the cab. Then after work today while trying to figure out what the heck I was going to do about the windshield, I noticed that the new rubbers I went to all the work to put on the wing windows in June are completely rotten. They almost look as bad as the old ones I removed. Thats the last time I buy rubber products from LMC. Now I'm worried about my freshly painted dash frown
Your dash looks good. One word on rubber, Steele Rubber. There are few parts on the AD that one probably should seek professional help. One of those areas is the windshield and rear window/windows.
~Jim
Testing my old man blinker fix
...click...
Thanks BIG CHEVY. I hate to think I'm going to have to remove my new widshield AND the vent windows. I'm trying to get this thing buttoned up before it gets too cold and I'm doing everything in my driveway, no garage.
The vent windows are not hard to rebuild, just use a quality rubber, in fact there is a serise of pictures of the steps to take rebuilding them. If you need it let me know.
~Jim
...click...
So much of what we do can be done in several different steps. Do I install gauges before I run my wiring or after. I thought about putting my turn led's somewhere in the gauges but by the time I was ready for that I had already installed everything (radio, air cond. and vents) under the dash. So I drilled the dash and installed them there.
Yours looks really good.
~Jim
BIG CHEVY, I rebuilt my vent windows back in June-before, I took great pride in doing the job right-after. I thought the rubber parts from LMC installed well and looked good. Oh well, lesson learned.
DADS50, that's brilliant! I was trying to figure out a good way to incorporate turn indicators into my speedo but gave up and installed it without. Now I will have to pull it back out again. Hope you don't mind me copying you.
I got the idea from a member here who installed them in his speaker grill.I decided to put them in a gauge cluster because for me its more noticeable.
The speedometer is also a good spot and will be easier to work.
here is the test in the truck.
...click...
...click...
I didn't want the LED's to be to obvious when off.
...pic...
The pilot light in the switch wasn't cutting it. Most the time I couldn't see the light flash because it was blocked by the wheel. The flasher is not loud enough.
I became the old man driving with the blinkers on.
Good luck
Neat flashers....neat idea!
I finally figured out how to attach my e-brake cables. Before coating the frame I had welded tabs, and used large e-clips to hold the cable sheaths. I used 75 camaro cable connectors, and the bolts are spring pack bolts. I opened up 1 end so the bolt would slide in, and they are threaded most of the way. About a $10 setup. Pics in my photobucket.
http://s960.photobucket.com/albums/ae90/scrambler45/
Well I finished up welding the floor pans yesterday. Now I am going to tackle the lower hinge pillars.
Mike
http://www.facebook.com/54bigbolt?ref=hl#!/54bigbolt
I replaced the rear sill, still have some work to do, but it's on there. BTW, I don't recommend doing this with the bed on the truck. Live and learn...
Still, it was nice to get something accomplished and learn something new in the process!
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
Wanted to get the rear speakers off the floor, so I cut the box down so that it would fit in the cab corners.
Robert C.
I'm a Genius in the making.
1950 3600
...click...
Thanks BIG CHEVY 3600
Do you have a pic of your Dash?
I clicked the link in your signature line but only got a log in request.
...click...
I like that!! thumbs_up
Robert C.
1950 3600
Here you go.
Dash
It's not a close-up but...
~Jim
Here you go.
Dash
[url=http://s729.photobucket.com/albums/ww296/BIGCHEVY3600/[/url
~Jim
thanks mobileortho
BIGCHEVY 3600, nice interior
I swapped the internals from my driver's door - which was badly dented - to another donor door, and mounted it on the truck.
Still needs alignment, but I'm pleased to have done it. smile
1950 Chevy 3100 short bed
1951 GMC 3/4 ton long bed
put $123 fuel in the tank ..... (:
dang How much is fuel there?
Finally getting back to work on the '59 after foot surgery laid me up for a couple weeks. I got the a/c unit installed and all plumbed up. I'll finish the vents once I finish re-wiring the cab.
Bypass valve:
http://s783.photobucket.com/albums/...=view&current=heaterbypass102212.jpg
A/C lines:
http://s783.photobucket.com/albums/...tion=view&current=achosesA102912.jpg
Engine compartment:
http://s783.photobucket.com/albums/...ction=view&current=achoses102912.jpg
Build so far:
http://s783.photobucket.com/albums/...pick%20up%20project/?albumview=slideshow
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I bought me a cheap timing light. Next week I'll be taking her to the alignment shop.
~Jim
back yard wrench turner
I recommend that you have your tires trued also. That made a tremendous improvement for the ride of my truck.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Wayne,
Who does the truing and how does it work?
~Jim
Authorized Pest
Authorized Pest
Jim,
We have a great Tech Tip on "truing" tires. Dave did a good job with this write-up.
Peg
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
After letting my bucket seats just set in the panel for the past few days....you know, moving them, checking how they look, ect, I finally drilled some holes yesterday and bolting them down. I have two more holes to drill today and they're done...finally.
Well I am making more progress on my bed. I got the wheel wells out of the bed and have started the exhausting process of taking all the bolts off. I am going to have to have someone weld repair piece because there was soooooooo much rust in the bed from where the diamond plate was trapping water. More to come later. Haven't taken pics of the wheel wells being out but will try to later today.
1966 Chevy C10 Longbed
"Dave's '66 Custom"
More pictures on Photobucket
Anything that's hard, will always be worth it in the end.
Originally Posted by Peggy M
Jim,
Peg
I checked the link on the mfg. and left a message request for a list of shops in the Dallas area. It seemed like quite a job to true those tires. I wonder what the cost would be.
~Jim
Jim, I had the same process as described in the tech tip.
I also had a bent rim. I found a company that straightened the steel wheel for $50. Then I went back to the alignment shop for truing and balancing.
I paid $25 per tire.
There happens to be a shop just 3 miles from my house.
Wayne
1989 Silverado
$25 sounds good for so much labor. Thanks for the information Wayne.
~Jim
Just got The Old Man outta storage and into my new garage to work on this winter. Looks like itll be a cold one here in MT... boy i love only being able to work on it in the winter.
Hope to have it running and rolling by spring!
Chooglin
1954 3600
[/url] www.tors54.tumblr.com
