5 members (Jon G, frogfarmer, Cletus1950, Wally / Montana, greenie-reddy), 152 guests, and 6 robots.
Topics128,106
Posts1,056,213
Members48,436
#88340 09/24/2004 6:26 PM
Greetings,
OK, so I have my new (old) 1966 Chevy C60 and it didn't come with a key? So, I need to get it started to get it off the road (where the tow truck dropped it off) and into my back yard. The back of the ignition switch has several wires, so which ones do I jumper, etc. to get it running? Essentially "hot wiring" it to get it started?
Any info would be appreciated!!
Thanks, in advance!!
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
#88341 09/24/2004 8:32 PM
Riding in the Passing Lane
Red is hot wire. Pink is ignition. Purple is
starter. You can just string a wire from the
bat. to the coil +. Then jump from the inside
small wire on the starter to the cable post to
engauge the starter. Don,t leave the wire on
the coil very long or you will burn the points.
smile
1972 Chevy c10 Cheyenne Super
#88342 09/25/2004 1:45 AM
Find some old Chevy keys and start trying them.I bought a '63 truck with no keys and the door was also locked. Got it home, put my '64 truck key in the door, wiggled it some and she opened right up. It also worked in the ignition. Also, you can start my '64 with a screw driver since the tumblers are so worn.
Give it a shot, may get lucky,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#88343 09/25/2004 1:47 AM
Also, you could go to a salvage yard or parts store and get a new ignition switch since you need one anyway,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#88344 09/27/2004 7:42 PM
You Know I have lost track, just how many of these trucks do you have? And when are you going to find a LCF?
#88345 09/28/2004 1:31 AM
Sorry Jolly...no LCF's in the near future :rolleyes: :rolleyes: . I prefer the conventional cabs...but you never know what the future holds??
I currently have 2 C60's...a 1964 dump truck and a 1966 with a diamond plate flatbed and hydraulic lift gate. The bed/lift gate will be sold whenever I get it off the cab/chassis and then I'll be using the parts on the '66 for my '64 and e-bay'in the rest grin grin grin ...
Thanks for the note!!
Burgie
#88346 10/01/2004 7:04 AM
An Chevy LCF is pretty much a conventional cabs sitting higher with a shorter hood.
[img]http://www.classiccoe.com/oldcoetrucks/trucks/lcf.jpg[/img]
