| | | Forums66 Topics128,117 Posts1,056,298 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88340 09/24/2004 6:26 PM | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Greetings, OK, so I have my new (old) 1966 Chevy C60 and it didn't come with a key? So, I need to get it started to get it off the road (where the tow truck dropped it off) and into my back yard. The back of the ignition switch has several wires, so which ones do I jumper, etc. to get it running? Essentially "hot wiring" it to get it started? Any info would be appreciated!! Thanks, in advance!! | | |
#88341 09/24/2004 8:32 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Red is hot wire. Pink is ignition. Purple is starter. You can just string a wire from the bat. to the coil +. Then jump from the inside small wire on the starter to the cable post to engauge the starter. Don,t leave the wire on the coil very long or you will burn the points.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#88342 09/25/2004 1:45 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Find some old Chevy keys and start trying them.I bought a '63 truck with no keys and the door was also locked. Got it home, put my '64 truck key in the door, wiggled it some and she opened right up. It also worked in the ignition. Also, you can start my '64 with a screw driver since the tumblers are so worn. Give it a shot, may get lucky, Scott | | |
#88343 09/25/2004 1:47 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Also, you could go to a salvage yard or parts store and get a new ignition switch since you need one anyway, Scott | | |
#88344 09/27/2004 7:42 PM | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | You Know I have lost track, just how many of these trucks do you have? And when are you going to find a LCF? | | |
#88345 09/28/2004 1:31 AM | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Sorry Jolly...no LCF's in the near future :rolleyes: :rolleyes: . I prefer the conventional cabs...but you never know what the future holds?? I currently have 2 C60's...a 1964 dump truck and a 1966 with a diamond plate flatbed and hydraulic lift gate. The bed/lift gate will be sold whenever I get it off the cab/chassis and then I'll be using the parts on the '66 for my '64 and e-bay'in the rest  ... Thanks for the note!! | | |
