0 members (),
186
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | I was wondering about gasoline additives for my Big Bolts and Pickup. I have been adding one cup of kerosene per tank of gas. Plus octane booster, it seems to eliminate ping and knocks. Been adding one cup of kerosene per 10 gallons of gasoline in my old '42 Fxxd 2N Mototug tractor/loader. GMC never made farm tractors or loaders. So I have a Fxxd tractor...  Anyway, anyone have ideas or recommendations.
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Marvel Mystery oil, Seafoam... | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | GM's offering in the tractor world was named "SAMSON" around 1920-30, loaders would have been the "TEREX" of the 60's I think---different company ownership now.
Bob Taylor
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | depends on what you really want. If is just a little something to clean the tank, or give it a little boost I like the Techron additive. It goes on sale fairly regular buy one get one.
If its water in the tank, just add a bottle of isoprophyl alcohol. Other than that marvel or seafoan will do the trick. | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | I always considered isoprophyl alcohol like "rubbing alcohol" a step in the wrong direction since, if you read the label, it can already contain from 30% to 50 % water. I recommend NO additives for our low compression engines and non-alcohol added gasoline. The kerosene works against the octane booster. keep the tank full-buy your fuel where a lot of GOOD brand fuel is being sold-run it enough to keep the fuel fresh. Maybe a little Nitrotoluene???
Bob Taylor
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | No water in tank just wanted to get input and other ideas.
I use Kerosene in my Ford tractor, it has the 9N running gear. The old flathead 4 banger. Tractor engine has never been apart so it does not have hardened valve seats.
New gasoline formulas flash to fast, want to slow down the burn rate.
Never use Alcohol based gasoline if I can avoid it. Even in my new truck.
I have to use Octane booster in my 2000 Sportster 1200cc, it runs cooler and smoother. Gas formulas have changed about 3 times since 2000.
| | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | The 9N series began in 1939 and leaded gasoline was a extra cost premium and would not have been expected to be run in a tractor. My book says the 9N (1939), 2N (1942), 8N (1948) design tractors had seat inserts as original. I have found that valve seat recession from lead free fuel and non hard seat inserts is an exaggerated threat in low compression, under stressed engines like our old engines and tractors. More important to keep correct tappet clearances in preventing valve seat wear/recession.
Bob Taylor
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..clarification. I'm not advocating adding alcohol as a regular additive but if you have water some alcohol will get it out. I printed using alcohol based inks for 13 years and during that time I kept the local Toyota and Nissan dealers stocked with Butyl and propyl alcohol. They used it regularly. For that they kept me stocked with oil filters and ect for my Nissan!! The thousands of gallons of alcohol we used had NO water in it or it'd spoil the inks. Maybe ours was "special".
Just didn't want any mis-understanding on my part.
Good luck GMCpics, keep us posted on how you come out.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Back the timing up until the ping is gone and use standard pump gas, Scott | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | Sounds like you had some good stuff there Chip, and your part of the country, like mine, was known to turn out some sippin' alcohol that was the pride of the maker. I have had some working aquaintenances that tried to be thrifty(cheap) and use rubbing alcohol instead of "gas drier" but they should have read the label.If you read the label the componant percentages are usually listed and water is the second greatest part. To use this isopropyl alcohol in the tank would be actually ADDING water.
Bob Taylor
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | i would use marvel mystery oil or lucas oil,i prefer marvel because it has been around since WWII and is proven to help prolong the life of an engine.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | The only thing I add is stabil during months it might sit. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | No water in tank just wanted to get input and other ideas.
I have to use Octane booster in my 2000 Sportster 1200cc, it runs cooler and smoother. Gas formulas have changed about 3 times since 2000. new gasoline contains ethanol unless it has a decal that states "does not contain ethanol" or "ethanol free" if it does, it will most likely be premium. there is nothing you can add to ethanol fuel to make it last much longer than 30 days, or keep it from phase separating gasoline formulae change all the time. what works on a buds old johny-popper, 8n and various old cars and trucks, along with the girlfriends fathers T-bird is 1 part leaded aviation fuel, 2 parts premium ethanol free. that will put enough lead in the engine to keep the valves from eating themselves. to keep the fuel from going bad, drive them to keep putting fuel in every 3 months.
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | I go to my local parts supplier and order 110 Octane Racing gas (not cheap!) and I apportion it into a tank (18 gallon on my rig) and I add 1 gallon per tank fill. It works for me and when it is all figured up it amounts to what I used to pay for 104 octane gas at a station in Sacramento. But it sure run better. Normbc9
| | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | With little over 7 to 1 compression, you shouldn't need any additive. If its pinging and or knocking, our timing is set wrong. I would also bet, you are lowering the octane of your fuel quite a bit with the Kerosine additive.
Run the engine at a high idle and slowly dump a cup a straight water down the carb. The steam being made will clean the piston tops of any carbon build up. If it still pings, back the timing down till it quits. Pay no attention to the pointer or timing marks, just get it to quite pinging.
Once you are satisfied its not pinging at anytime, check the timing marks against top dead center of #1 piston.
More octane is wasting money if the engine doesn't need it. Low compression engines do not need much! I would also bet the Marvel oil is gumming up the carb when the fuel evaporates out. Ethanol creates enough problems on its own, don't go adding to it. | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | You can't retard the timing on a Sportster (no points), it has preset electronic timing.
There's a big difference between the alcohol used in printing ink and rubbing alcohol. As much difference as between Moonshine and Red Vino. The alcohol used for diluting the water in gasoline after a long cold winter is not the same as alcohol for in your local drug store.
I let my old Ford tractor set for a couple of months without starting it, the gas was as dark as coffee and slightly sticky. I had to flush the carb and tank with fresh gas to wash it all out. It was almost like sludge.
I had forgot to put kerosene in the tank with the gas.
