Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, NJC, Hotrod Lincoln), 105 guests, and 2 robots.
Topics128,277
Posts1,058,451
Members48,490
I'm very glad to have found this forum. I've been restoring farm tractors and related implements for over 25 years and have always wanted an old truck to pull them with.
I have a rather unique project though. I wanted a much older style truck, like a "C" cab Mack or similar type, but restored ones are prohibitively expensive, and ones that need restored are worse.
So... I'm building my own.
I've started with a 1951 3600 3/4ton frame.. that was pretty much all I got, having only axles and steering on it. No body, engine, radiator or tranny... nothin'.
But that actually made it easier.
I found a nice little 235 that used to be in a truck that belonged to my old high school. The boys in "shop" class rebuilt the engine, after which it smoked like a coal plant. The school junked it. Having NO engine, it seemed like a start, and to my surprise, I found it was actually in excellent shape.. but all of the ring grooves were lined up perfectly..:)
The radiator is off of a mid 20's 10-20 McCormick Deering tractor, the tranny out of a '59 3/4 ton Chevy, the steering wheel out of a'29 Chevy car (nice wooden one), and the rest of the truck, bed, cab, fenders, running boards firewall, hood, roof, etc, I built.
The cab is white oak, stained with three coats of spar varnish, as is the bed. All wood is trimmed with 1/8" steel, painted gloss black w/ screws and nickel finish washers. The frame was sandblasted clean, and all unnecessary holes welded up and ground down. It was then painted gloss black.
My engine will be smoke gray and I'm taking extra pains to seal it up against oil leaks. The front and back glass are specially cut laminate safety glass.
I know it sounds like a complete morphodite, but it actually looks like it will be really nice when done. It has a "C" cab design with a half door, a squared off, downward angling roof like on a Mack, covered in black boat canvas, a gull wing style hood w/ louvres pressed in each side (will be painted cream color) and double strap front and rear bumpers. The fenders are made of 1/8" thick steel, rolled, with a piece of 1/4" round stock welded around the edges to make it appear beaded. They are gloss black also.
The bed is a flare box design with a chain drop tailgate.
The headlamps are some old teardrop style I picked up, that have a half cone type turn signal mounted on top. The taillights are off of a Model A Ford.
The wheels currently are Ford 3/4 ton 8 hole, painted a beige or cream color, but I hope to build wooden spoke ones in the next yr or so, or perhaps go with a solid, flat steel disc design.
If I can figure out how to post pics, I'lll add some in the months to come... My target finish date is the end of April.
Although very little of this truck is "as original" the fundamental chassis/drivetrain is 50s Chevy and it hs been gone through from stem to stern. I've even disassembled the leaf spring packs, sandblasted them, painted them, and used the plastic liners between each to quiet them down and slow down the wear/rust.
I'm hoping this site will provide the tech answers I need on a few things, like torque values, clearances, etc .. Thanks in advance. Kelley Hulsey, Kinmundy, Ill
Leo Offline
Moderator
Moderator
Welcome Kelley, quite a plan you have there. Do you think you can pull this off in 3 months? Good luck.
Leo
Hey guys, there's no bull about this sgt. Sounds like he is one dedicated wrench head like us...... smile
Welcome to the Stovebolt,Kelly. I think you will fit right in here. We anxiously await some pictures. Sounds like you have a labor of love. Look forward to seeing you around the shop..... Oh,and don't pay any attention to the first statement. Chipmunks are prone to do that once in a while......Alvin
Glad you found it too. I've also restored several tractors and have a 2-ton Chevy to haul them around (when it's done).If any help is needed just drop a line. By the way, I have somd McCormick Deering operators manuals.
Good luck
Ken
1946 Chevrolet 2-Ton
More pix of the '46 on Photobucket
1954 Chev 1/2-ton
3 Farmalls
4 John Deeres
1 Oliver
1955 DeSoto Fireflite
I'm pullin for ya. We're all in this together -- Red Green
#857030 06/06/2012 4:59 PM
I posted early this yr that I hoped to build a truck that "looked old." Well, its done. I had too many pics to post and really wasn't sure how to post them here, so here is a link to an old tractor forum that has the pics...
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=870089
sgtbull #857036 06/06/2012 5:48 PM
great work Sgt,, thanks for the post and pix
I will be 10-7
Redryder pix
My Hotrod
sgtbull #857037 06/06/2012 5:52 PM
WOW!!
That's really neat that you made such a lovely looking "frankentruck", even using the tree. I feel sorry for you having to answer when someone says "What year is it?"
How will you title it? Will it be as a '59?
TxLaTx #857044 06/06/2012 6:25 PM
sgtbull,
Very nice. Thanks for posting the photos.
TxLaTx #857047 06/06/2012 6:59 PM
Beautiful truck. As for the year(s), I think Johnny Cash even has a song for it. Again, beautiful.
New_Ton #857078 06/06/2012 9:48 PM
Very neat ! I like it!
Drew
DrewP #857094 06/06/2012 11:43 PM
Leo Offline
Moderator
Moderator
Very well done, good to have that 235 in it.
Leo #857127 06/07/2012 1:47 AM
yep, nice job. nice work and tons of enjoyment. Just don't get any better!!
Be sure you post us a picture of the trailer.
sgtbull #857144 06/07/2012 2:46 AM
That turned out great, a true one of a kind. Congrat's on all your efforts. thumbs_up
Very nice. I like how much of the coach work of teens and twenties trucks were wood.
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
WOW, NOW THATS NICE! Great job!
Stranger
Frank in Iowa
"Mater's Cousin"
More pix in Photobucket
It took you 6 months to build that truck? Dang, did you sleep during those 6 months?
Very cool truck!
Now that's what I call a real woody!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
sgtbull #886193 10/01/2012 6:32 PM
Red dot, center of chest ...
That's the coolest dang truck I've seen in a long time. You got me jealous now. I'd like to have me one of those things. Super job on building something completely unique. I'll bet it's a blast to drive and turns heads everywhere you go. Lots of old fellars like me scratching their heads trying to figure out what it is.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
sgtbull #886196 10/01/2012 6:39 PM
WOW,Very nice job, Its a stovebolter!
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
joker #886230 10/01/2012 8:49 PM
Nice job on the truck sgt. I'm especially interested because I'm building a boat tail speedster using a 3600 chassis (1953) I have a radiator from a 31 chev. 1ton. The engine is a later model 230 or 250. Will use a granny 4spd with emergency brake attached. I'll be posting some pics of it on photobucket soon.
