1 members (2-Ton),
141
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 2 New Guy | | New Guy Joined: Jan 2012 Posts: 2 | I'm very glad to have found this forum. I've been restoring farm tractors and related implements for over 25 years and have always wanted an old truck to pull them with. I have a rather unique project though. I wanted a much older style truck, like a "C" cab Mack or similar type, but restored ones are prohibitively expensive, and ones that need restored are worse. So... I'm building my own.
I've started with a 1951 3600 3/4ton frame.. that was pretty much all I got, having only axles and steering on it. No body, engine, radiator or tranny... nothin'. But that actually made it easier. I found a nice little 235 that used to be in a truck that belonged to my old high school. The boys in "shop" class rebuilt the engine, after which it smoked like a coal plant. The school junked it. Having NO engine, it seemed like a start, and to my surprise, I found it was actually in excellent shape.. but all of the ring grooves were lined up perfectly..:) The radiator is off of a mid 20's 10-20 McCormick Deering tractor, the tranny out of a '59 3/4 ton Chevy, the steering wheel out of a'29 Chevy car (nice wooden one), and the rest of the truck, bed, cab, fenders, running boards firewall, hood, roof, etc, I built. The cab is white oak, stained with three coats of spar varnish, as is the bed. All wood is trimmed with 1/8" steel, painted gloss black w/ screws and nickel finish washers. The frame was sandblasted clean, and all unnecessary holes welded up and ground down. It was then painted gloss black. My engine will be smoke gray and I'm taking extra pains to seal it up against oil leaks. The front and back glass are specially cut laminate safety glass. I know it sounds like a complete morphodite, but it actually looks like it will be really nice when done. It has a "C" cab design with a half door, a squared off, downward angling roof like on a Mack, covered in black boat canvas, a gull wing style hood w/ louvres pressed in each side (will be painted cream color) and double strap front and rear bumpers. The fenders are made of 1/8" thick steel, rolled, with a piece of 1/4" round stock welded around the edges to make it appear beaded. They are gloss black also. The bed is a flare box design with a chain drop tailgate. The headlamps are some old teardrop style I picked up, that have a half cone type turn signal mounted on top. The taillights are off of a Model A Ford. The wheels currently are Ford 3/4 ton 8 hole, painted a beige or cream color, but I hope to build wooden spoke ones in the next yr or so, or perhaps go with a solid, flat steel disc design. If I can figure out how to post pics, I'lll add some in the months to come... My target finish date is the end of April. Although very little of this truck is "as original" the fundamental chassis/drivetrain is 50s Chevy and it hs been gone through from stem to stern. I've even disassembled the leaf spring packs, sandblasted them, painted them, and used the plastic liners between each to quiet them down and slow down the wear/rust. I'm hoping this site will provide the tech answers I need on a few things, like torque values, clearances, etc .. Thanks in advance. Kelley Hulsey, Kinmundy, Ill | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome Kelley, quite a plan you have there. Do you think you can pull this off in 3 months? Good luck.
Leo | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Hey guys, there's no bull about this sgt. Sounds like he is one dedicated wrench head like us......  Welcome to the Stovebolt,Kelly. I think you will fit right in here. We anxiously await some pictures. Sounds like you have a labor of love. Look forward to seeing you around the shop..... Oh,and don't pay any attention to the first statement. Chipmunks are prone to do that once in a while......Alvin | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Glad you found it too. I've also restored several tractors and have a 2-ton Chevy to haul them around (when it's done).If any help is needed just drop a line. By the way, I have somd McCormick Deering operators manuals. Good luck
Ken | | | | | Joined: Jan 2012 Posts: 2 New Guy | | New Guy Joined: Jan 2012 Posts: 2 | I posted early this yr that I hoped to build a truck that "looked old." Well, its done. I had too many pics to post and really wasn't sure how to post them here, so here is a link to an old tractor forum that has the pics... http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=870089 | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | great work Sgt,, thanks for the post and pix I will be 10-7 Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | That's really neat that you made such a lovely looking "frankentruck", even using the tree. I feel sorry for you having to answer when someone says "What year is it?"
How will you title it? Will it be as a '59?
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | sgtbull,
Very nice. Thanks for posting the photos.
| | | | | Joined: Sep 2011 Posts: 82 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 82 | Beautiful truck. As for the year(s), I think Johnny Cash even has a song for it. Again, beautiful. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Very well done, good to have that 235 in it. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | yep, nice job. nice work and tons of enjoyment. Just don't get any better!! Be sure you post us a picture of the trailer. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | That turned out great, a true one of a kind. Congrat's on all your efforts.  | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Very nice. I like how much of the coach work of teens and twenties trucks were wood.
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | WOW, NOW THATS NICE! Great job! | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | It took you 6 months to build that truck? Dang, did you sleep during those 6 months?
Very cool truck! | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Now that's what I call a real woody! | | | | | Joined: Mar 2000 Posts: 1,182 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,182 | That's the coolest dang truck I've seen in a long time. You got me jealous now. I'd like to have me one of those things. Super job on building something completely unique. I'll bet it's a blast to drive and turns heads everywhere you go. Lots of old fellars like me scratching their heads trying to figure out what it is. | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | WOW,Very nice job, Its a stovebolter! http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | Nice job on the truck sgt. I'm especially interested because I'm building a boat tail speedster using a 3600 chassis (1953) I have a radiator from a 31 chev. 1ton. The engine is a later model 230 or 250. Will use a granny 4spd with emergency brake attached. I'll be posting some pics of it on photobucket soon. | | |
