Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (55shaker, Wayne67vert), 118 guests, and 4 robots.
Topics128,281
Posts1,058,465
Members48,490
#82381 09/02/2007 10:20 PM
Hello,
I am having a maddening noise in my transmission in 3rd and 4th gear.I took the tranny out disassembled it looked it over. No broken gears, bad syncros, etc. Greased it put it back together, installed it. Same noise. Bearings? Man, they looked and felt good. Hard to say when you can't put a load on em' at the bench. It only happens in 3rd and 4th under load. Reverse, 1st,2nd fine at any rpm. Transmission experts please tell me the answers!!!!! Thanks!!!
240,000 worker bees!
1960 Two ton Chevy
#82382 09/05/2007 3:40 AM
I have no experience with this myself, but I can tell you what my manual says. It says if its noisy in high gear range it could have excessive clearence on the mainshaft. I just rebuilt mine and the clearance is supposed to be between .003-.012 between the gears.
Again, no personal experience! I hope that will help though... ohwell Jeff
My 1953 Chevrolet
1947.1 Gallery
#82383 09/05/2007 9:58 PM
Riding in the Passing Lane
Was the mainshaft & rollers good where they go into the maindrive gear? How about the clutch pilot bushing. Could it be the rear end?
1972 Chevy c10 Cheyenne Super
#82384 09/06/2007 2:04 AM
Hey Nuts, I just happened to be looking through the SM420 manual today, in antisapation of rebuilding mine. I think you meant .012" +/-.003"for the 2nd speed gear and .012" +/-.002" for the 3rd speeed gear.
That wouldn't be causing the noise that the Bee is hearing, a bad bearing is most likely the problem. And as George mentioned, it could be from the rollers, are you sure that they were all in there when you loaded them. It's possable that someone left one out previously. Loading them can be tricky if you haven't done it before and it wouldn't be the first time one got left out.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#82385 09/06/2007 3:01 AM
Are you sure it's not a reasonance at a cetain speed/load that you're hearing ? It could be caused by the trans but could actually be something else making the noise. Usually a bearing noise will go away (for the most part) when in 4 th gear.
Just a thought,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#82386 09/06/2007 3:26 PM
Thanks Denny! Thats what I meant :whistle: What a big difference that would be!
Jeff
My 1953 Chevrolet
1947.1 Gallery
