3 members (Guitplayer, Patina 54, Steelonsteel), 42 guests, and 2 robots.
Topics128,035
Posts1,055,441
Members48,422
#805480 12/10/2011 6:11 PM
List the 1-Ton (or 1-Ton's) that you have.
Pictures would be a bonus.
Mine are:
-'64 C-30 Stake Body (Parts Truck)
-'65 C-30 Stake Body (Restorable)
-'68 C-30 Flat Bed Dump (Needs Finishing)
-'71 C-30 Wrecker (Yard Truck)
-'72 C-30 Flat Bed (Soon to be Daily Driver)
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Do I count? It's got a one ton bed.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Sure thing.
Your truck sure looks like a 1-Ton.
GMC 9500 Fan
Detroit Diesel Fan
back yard wrench turner
Mine is a '38
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
1 Offline
1951,3800 1 ton, original 216 engine SM420 4 speed with a 1969 HO72 3rd member 4:11to 1 rear gears, LT2.35x85R16 front LT2.65x85R16 radial rear tires, Looks pretty nice,
1948, 3800 1 ton for parts truck
1947, 3800 1 ton for parts truck
1950 3800 1 ton, 235 with SM420 4 speed. Down to the frame, just about ready to put her back together.
'53 3800-Was my grandfathers, and his fathers before that. I drug it out of the woods with the wheels sliding, and have been working on it about 5 years. Trying very hard to drive it back to my grandfathers house, while he is still there.
'53 3800 for parts
'49 3800-bought it for parts sight unseen, but when it got here it was too nice to part out, so now its sitting in the back of the barn, waiting.
i got a 59 3800 with a 283 and now a 350 trubo auto and power brakes used to be an old brush fire truck in kansas it's down to the frame but comming up alittle at a time
panman #806437 12/13/2011 7:58 PM
V
VEW Offline
V Offline
We have a 59 3800, 235, 4spd. It's patiently waiting for some attention. Runs, but not well. Need to go through it, but there's hope.
~ Victor
1957 3100 - moved on
VEW #806955 12/15/2011 4:19 AM
'62 one ton driver with a 283 and a tired flatbed. Hoping the replace the bed wood this winter and maybe find a 60-61 hood.
'57 3800 with 29k original miles. Spent it's entire life on a wildlife refuge near the Mississippi river, used only to haul wheat raised on the refuge that was used for trapping woodducks. Few dings and very little rust. Will eventually put a 9' stepside bed on it when I have time to devote to it.
http://s305.photobucket.com/albums/nn214/jfnar/57%20chevy%203800/
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Here is my C-30 Off craigslist this summer was busy saw it paid $450. never really looked at it much lady claimed her late husband bought new . Got to looking hard at it and realized quickly that all of the flex brake hoses are new. Oil is as clean as bottled water. Antifreeze is bright green, so I dumped the gas tank out, put a carb kit in it, purged the fuel line, dropped a battery in it, and spun it over. It had no fire. Put a new set of made-in-the-USA points and it fired right up. It runs well. The locking ring tires don't look that dangerous, but it would appear that the outer ring holds the inner ring in place. The only time you would risk injury would be if the inner ring was not completely seated. Working on getting my nerve up. May slide it under the truck and hook an air hose to it. Let me know what you think, as I look forward to tinkering with this truck a lot.
Pictures
Dado #808172 12/19/2011 3:46 AM
Dado, we have similar trucks as mine's a '62 C30. When I picked mine up a few years ago it had later model one piece rims on the front but still had the lock ring rims in back. I needed new tires in back and the tire shop found one of the rims and lock ring had rusted real bad and was too pitted to safely use so I bought another pair of later model rims for the outside wheels. I kept the lock ring rims for the inside wheels. The tire guys weren't crazy about working on those older rims and inflated the new tires in a cage as a safety precaution.
So be careful, you may have a rusted out rim that isn't obvious at first.
1930 LR 1 1/2 ton has 33,000 miles on it
BILL #808499 12/20/2011 12:42 AM
Yea that's pretty good advice was planning on a good wire wheel cleaning first checking tubes as well . Those tires are 700x18 is that what you have on yours ?
'59 3800 235 SM420 dual wheels with flatbed and PTO powered dump. I purchased it last year in Mississippi and have found the dump bed to be very handy. As purchased, the 235 runs great, the steering is tight, the brakes are good, and the body is in good shape except for a little rust on the front fenders. I have found a set of no rust fenders that will be installed when I get around to painting it. My truck gets lots of positive commments from the country folks in my community. However, the city types just don't "get it". They think there is something wrong with me for driving "that old truck" instead of my crewcab 2500 duramax.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
I have a 56 chevy 3800 that I'm finishing a bed for and a 57 chevy 3800 with the original 283 and a 10' bed. i drive it all the time.
I
I Offline
I have a 46 (built in 47) Open Express. I put in a T5 behind a 235 with dual intake and Fenton headers.
Still working on the sheet metal.
Y
Y Offline
1949 3800' just got it back on the road after an engine overhaul.
216 with 4 speed, hydraulic hoist, 6 volt system. Pics are in my signature block, however it does have a new set off tongue and groove stakesides on the bed, and the cab has been cleaned and waxed.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
1949 Chevy 3800 dually. It's unrestored, running and driving. It's stock, except for the 1955 235 motor and 12v. Pictures are in the link in my signature.
62401
Hey Bill!
If y'all look on the Stovebolt.com home page, as well as in the column on the left of this page (and all pages of the forums), you will see the Flagship of Stovebolt.com -- Peggy's and my '49 3800 pickup. Mostly original and unrestored. It's an excellent driver and we really enjoy taking it to shows and cruise-ins.
This winter, I hope to do a brake job and a tuneup on it.
So one tonners be proud -- The "Uberbolt" is a one ton!
One tons ROCK! smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I have a non-running 1946 tonner bought off fellow bolter John Branch. It currently resides sideways against the front wall of my garage. I even built an enclosed landing/closet to the main house around the truck.
Over the summer and fall I've accumulated all the parts necessary to get it running. I also have most of the parts to reseal the axles and put new brakes on it. During the Christmas break I hope to get it running with the aid of my young sons. I bought them some socket sets as motivation!
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
"MONGO"
"MONGO"
Here's my 50ish GMC one Ton. 270 Engine, with a 4 speed.
The truck was revived a little by a previous owner so it's had some paint and body work at some point. The first thing I did was lose the terrible bed it had on it. Not sure what kind of bed will end up back on it but I need to get it up and running again first.
Pictures
Mongo
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
Now that's a sexy forklift you have in your pictures, I like it!!
Bruce
My Trucks
Stuff I Collect
I have a 50 3800 Deluxe cab, with a 9 foot bed, original 216, SM 420... IN the last year i have replaced the third member with a "No Spin" 4.10 locker gear set, replaced the brake Master with a tandem system (still ironing it out) re did the electrics throughout, 12V alternator, wiring etc. new window seals all around. Its my daily driver and soon i'll be driving it back to Colorado with its new 261!
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
Thought i would include a picture of my old 1949 Chevy 1 ton. It still has the original 4 speed tranny and 216 engine that runs like a dream.
Jordi55 #811406 12/29/2011 11:42 PM
Very nice! What are the plans for the back end?
Bruce
My Trucks
Stuff I Collect
1947 1 ton. 9 1/2 foot bed. 248 GMC.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
1952 GMC 9430 one ton. Only had her a month and have most of the body off with only the cab and drive train remaining. Just verified that it has the factory motor which made me happy. Hope to keep it as stock as possible. As I tear it down my list of needs keeps on groing.
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
1950 Chevy 3800 dually - all original, weathered and aged well on my dad's ranch in South East Sacramento county. Yellow/Cream coor
1952 GMC 253 - just picked this up - 5 window cab, dual, flat bed.
all oroginal, interior decent enough - one exception, floor boards remind me of the the like Fred Flintstone braking method. ....just stick your heels straight down and dig in to stop...
looking for shop that can replace all the floor boards...GMC red and white
'50 Chevy 1 ton dually daily driver, 1960 Ford F-100, 1972 GMC C-20, 1958 Kenworth, Cat D4, 1972 Ford F100 Ranger
9
9 Offline
71 C30 157"wb 350 4 spd ps pb white with blue int. 12' flat bed. New duals with turbos to the rear. Paint, Int, grills, bumper and Spicer aux tranny to come. Holds 3 cords of wood.
55 250 8 GMC Flatbed
67 M715
69 CJ5
72 M35A2 Bobbed
75 CJ6
80 K3500 Flatbed
95 XLC2
71 C30 Flat Bed
95xlc2 #814262 01/07/2012 9:12 PM
Sounds like a nice truck.
Keep us posted on the Aux Trans. I would be interested in more about it.
GMC 9500 Fan
Detroit Diesel Fan
My '52 (see signature) was brought to CA from the PO's family ranch in Wyoming. It came with a really strange ranch bed that was all cobbed together with a lot of scrap metal and was probably great for mending cattle fences but not much else. I pulled the bed off and gave it to a fellow stovebolter to make a welding trailer, had a metal frame built by another friend, and built myself a flatbed from recycled doug fir 2x10s. She's got great door art from the original family ranch construction company, and the original '52 babbit 235 still runs great. Love that old 1-ton.
Just picked up a 38 chevy .Not sure what i am going to do with it yet. http://i323.photobucket.com/albums/nn476/wingedexpress1/381.jpg
I have a '46 1 ton, sitting outside (gulp, please don't throw rocks at me) waiting for me to finish other projects. It has the 9' long bed. Which brings me to an important question: Does anyone know what rear fenders should be on this truck, since I don't have any; do the 1/2 - 3/4 ton rears fit or are they supposed to be the ones for a panel truck? In my searching I don't want to buy the wrong ones, if I should ever happen upon any. Thanks.
dwreills, sorry to say the 1/2 (or 3/4) ton fenders are smaller. Apparently they were intended for the corresponding smaller wheels. The panel truck rear fender is more of a fender flare. Bedsides and rear fenders for the 9 foot bed are hard to find. Keep a close eye on the Truck Parts for Sale forum.
Dave Baird
1951 Chevy 3803
1954 GMC 250 W/ 270 CID
Yes, officer it's licensed.
Dave51Chev: Thanks for responding; though the info makes me a bit more despondant, LOL. I might try to borrow a rear from a 1/2 ton to see how wrong it is. Maybe use as a pattern to stretch my own (a bit ambitious maybe). I'll try to watch the Parts forum. Unless somebody who reads this has some out there, (hint hint). If not for sale I'd rent them to measure and make a pattern from. Anybody?
dwreills #818458 01/22/2012 12:03 AM
Hey All, 57 Chevy 3800 1 ton flat bed 235. Runs and still waiting to be retored. Yahoo posted today that the old trucks with original rust patina are hot these days. Ole red will be waitng while.
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
Duwop #818467 01/22/2012 12:23 AM
I haven't posted about mine yet, so here it goes:
Mine is a '51 Chevy 3800 with a transplanted '53 216. Originally had a dilapidated cattle pen on the back, which is now gone. I'm planning on building a flatbed with stake-bed sides and wood tailgate.
Last summer, I purchased a 1951 1-Ton Panel Truck. It was mostly stripped, and I was buying it to use as a parts vehicle. The remaining rusty-holed shell met up with the Metal Scrapper.
Dave Baird
1951 Chevy 3803
Moderated by  Dusty53
