5 members (Wally / Montana, greenie-reddy, carbking, Forty9, 1 invisible), 75 guests, and 3 robots.
Topics128,185
Posts1,057,281
Members48,467
Page 55 of 177 1 2 … 53 54 55 56 57 … 176 177
Ok, it was a "pain" installing it. LOL but it is a great birthday present.
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
My air fiters and headers arrrived. Installed the intake, headers and carbs. Getting ready to remove the cab and start cleaning the frame.
If you never tell a lie, you never need to remember what you said.
I pulled all this stuff from a 66 C10 1/2T Stepside at the local salvage yard for $67. WooooHooooo!
See pic.
http://i618.photobucket.com/albums/tt269/fastboatman29212/65%20Chevy%20C10/Doorplusxtras.jpg
Lugnutz, you made out like a champion today. Heck, maybe you should go into used parts business....buy and re-sell. Man, you saved a days pay!
That's the deal of the day !!!
Tim
1951 3100 Chevrolet
Realigned the driver's door on my 57 GMC 100. Talk about chasing panel fitment... ended up taking hinges off and enlarging the adjustment holes. Fits great now!
Took heater from under dash - cleaned and shined - checked out fan motor - OK
Ken
1946 Chevrolet 2-Ton
More pix of the '46 on Photobucket
1954 Chev 1/2-ton
3 Farmalls
4 John Deeres
1 Oliver
1955 DeSoto Fireflite
I'm pullin for ya. We're all in this together -- Red Green
Leo Offline
Moderator
Moderator
Put the radio in the '53. If everything went as smooth as this, I would have been done this truck long ago.
Still working on mounting the bear claws. Got both latches & solenoids installed and the outside door handles removed and smoothed. Bought a set of Autoloc interior handles to install as well.
Robert C.
I'm a Genius in the making.
1950 3600
Just finished installing a new fuel tank sending unit. Finally a functioning fuel gauge!
back yard wrench turner
Repaired the bottom of the passenger door with a new piece of framework and door skin.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
got all my rusted solid regulators and hood handles freed grin "i love my pb buster" forget WD40
1937 1/2 ton
Took another batch of items out of the de-rust vat, cleaned them up and boxed them till time for assembly and paint.
Then threw another armload of items into the vat!
I rebuilt the distributor, placed it back in the engine with new parts and wires. New plugs, fuel pump, radiator hoses, and battery leads. Primed the rocker arms and adjusted the valves. Then put new plugs in and started it up for the first time since the 70's or early 80's.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
641Workmaster,
I bet that was thrilling to hear her run! Did you drive her?
Lugnutz, it sure was! I got my boys to come out and watch. It struggled at first. The cylinders were full of oil, PB Blaster, and whatever was in there for 30 years. That and I forgot to lube up the throttle/choke cables as well as the gas pedal.
It will be awhile before its driven. It's wedged sideways in the front of the garage, tight to three walls. The rear wheels are locked up. So next is to put new wheel seals and rework the whole brake system. Then I'll feel comfortable taking it out for a shakedown!
At some point I'll upload a video to Youtube.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
any suggestions on how to free up pads rusted to the drums 641 lol all four are stuck on mine
1937 1/2 ton
I'd hose it down with liquid wrench and then try an air chisel with the nail head looking tip. The vibration and impact should knock it loose.
Or do it like my grandpa used to.... squirt oil in it and drag it around the field with a tractor! That pretty much was his answer to everything. wink thumbs_up
In my case its not so much rust but grease and oil soaked pads that have stuck to the drums. I tried one and was able to back off the adjusters to get it move.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
Painted the CHEVROLET script on the tailgate of my '65 Stepside using a high density foam roller and some satin white Rustoleum paint.
Came out pretty good.. good enough for my old Shop Truck anyway.
http://inlinethumb30.webshots.com/46557/2006796130103882008S600x600Q85.jpg
http://inlinethumb09.webshots.com/48904/2612453640103882008S600x600Q85.jpg
Pulled the engine and tranny of my 65 chassis. Removed the windshield and clear everything off the fire wall. Wanted to pressure wash the chassis before tearing it down but I've misplaced a water hose adapter...bummer.
Re-torques the head bolts on my 235 per this thread
Installed my ...Guide B-31... reverse light
...pic...
...pic...
Have to be carefull with the tail gate with that light back there
located and bought my radiator for 20 and a pair of camero bucket seats for my 37 and got a lead for next weekend on a 250 for 125 :)just wondering how much longer the 250 is than the 213 in it now
1937 1/2 ton
Just found a steal of a deal on 7.5 x 20 with rims. complete set of 6 nearly new for one bill. happy day! Those will be installed before dark
Pulled the steering wheel and ran a new horn wire down the shaft. Also cleaned up the wires in the engine bay and hooked up a new fuel filter and lines.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
Woo Hoo! After a couple of weeks searching the net i finally located an Eaton HO72 rear end with 4.10's for my 54 3/4 ton and it's only 45 mins. from me. Hopefully i'll be swaping the Diff. by next week!
[Linked Image from i1188.photobucket.com]
Got the sender in the gas tank and the tank mounted. Fenders went to my body man last week. Progress!
sps Offline
Made a new wire harness for the whole truck, set up a fuse block out of a 78 C20, and I'm useing all the stuff on my 94 tilt column. Its going in my 53 5 window. Boy, what a head game!
Where are the pics sps?
~Jim
I hooked up the new tach. Tomorrow I will crank her up and back out on the driveway and let her idle to warm up. Then I'll turn on the heater to see if it all works.
~Jim
You're closing in on it, Jim.
sps Offline
Can't get any on yet, working on it.
Steve
Changed out my lower A-arms and installed coil overs. Now to get that squeak out of the left door then tear her down for paint. Maybe I can get her back by April.
I have a squeak in one of my doors also and have reduced the squeak only temporarily. Ford used some kind white lube, I forget the name. Does anyone know a solution that will work?
~Jim
Wiped her down (to cold to wash) and since we have been having nice sunny dry days I took her out for an hour long drive. Lots of thumbs-up and smiles!
http://community.webshots.com/photo/2071318780102454676foVBMK
Finally got the ol' Rochester rebuilt over the holidays. On to the next items.....
JIm,
Is it white lithium grease?
In fact it is. I found a spray can of it this AM while cleaning out the garage. It would have to be 15 years old. The problem is, there is no spray tube so I can direct the spray to the hinges.
The old stuff we used at the Ford dealership came in a tube. I don't remember how we applied it to the hinges. It's only been 48 years.
~Jim
Well everyone, I did it again! I found some more parts for my 65 Stepside at the local salvage yard - and CHEAP TOO!. Found a hood - although the one I have is in better shape. Found cowl corners from the same 66. One thing I like is that the PS cowl corner doesn't have the hole for the antenna - so now I won't have to weld my other one shut! Woohoo!!! Also, the other day I bought some new wheels to dress her up. See pics or website.
http://i618.photobucket.com/albums/tt269/fastboatman29212/65%20Chevy%20C10/C10%20Hood/0107121445.jpg
http://i618.photobucket.com/albums/...20Chevy%20C10/C10%20Hood/Cowlcorners.jpg
http://i618.photobucket.com/albums/tt269/fastboatman29212/65%20Chevy%20C10/C10%20Hood/DSCN1273.jpg
http://i618.photobucket.com/albums/tt269/fastboatman29212/65%20Chevy%20C10/C10%20Hood/HoodNwheel.jpg
