Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#808345 12/19/2011 5:18 PM
Is there a vendor that makes door windows that eliminates the wing window vent.
Your local glass shop can cut one. What about the mechanicals? The original equipment won't work very well if at all.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Couldn't you just swap doors with an earlier truck?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
The mechanism is completely different you would need to swap doors or:
Get 1947-50 glass/regulators
Inside/Outside window trim pieces
1947-50 weatherstrip pieces
Sir Searchalot
Sir Searchalot
I guess everybody knows what truck you have, but I don't. Anyway, yes there are vendors who offer one piece window kits. Classic Truck Glass, Ecklers, www.onepieceproducts, and here is an interesting discussion http://forums.classictrucks.com/70/...53-chevy-pu-window-conversion/index.html
Sorry forgot to explain truck. Thanks for the replies. Truck is a 52 3100. Truck is out of paint and now is running (not drivable yet)The wing vents are toast since I had to have the body media blasted. New wing vent assemblies are available for LMC for $290 each, !!OUCH!!
Take your old vent assemblies out and get them powdercoated and use glass of your choice.(clear or tinted) Sure saved me a lot of money and I had to pull them out anyway.
I removed them on my '52 3100. Cut out the wing window supports, installed new tracks on the hinge side and added power windows.
Here is a write up showing basically the same procedure.
http://www.customclassictrucks.com/...e_piece_window_installation/viewall.html
Moderated by  ndkid275, Phak1
