2 members (artinva, Chip O),
112
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | So, Cup holders. I have none. I had a plastic center thing that the shifter hit so I tossed it. Looking for something else. What do you have? Just would like to see my options.
Thanks | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Good topic. I bought a seat from Wise Guys in NY, one with a fold down arm rest; I've gotten pretty soft as I have aged. Your post made me think how much I depend on cup holders in my other truck and what I might do to fix this problem. If you remember back in the early 70's, as cup holders were introduced in new cars as an option and standard equipment in luxury cars, the aftermarket came out with add-on cup holders. I remember the ones that snapped down on the armrest and on the tranny hump in the floor.
~Jim
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Have a look at " cupholdersplus.com " | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I bought a couple of cup holders at O'reilly's, the kind that hook in the window slot. They were loose, so I added come 1/2" foam, now they work fine.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....and if the money is tight a roll of duct tape in the floor will get you there.
hey, I understand. There is just not much room in a 37.....especially when you add mom and pop. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi Alvin. I use the roll of duct tape on the floor. It holds the drink, you can move it, and doesn't slide around the floor.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Dennis, Red Green would be proud of you!
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Check with Bigbadswingdaddy he made a custom one. It fits in his 1959 GMC dash. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | When I drive my truck (A.D.) to work I take a cup and thermos. I use this box I have. It clips over the seat. ...pic... I keep some small tools in it also Keeps things from rolling around. Works for my solo trips. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | In true Canuck fashion I have continued the duct tape cup holder tradition for Dennis' truck | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | my answer is not to drink and drive.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i use an empty savinelli cigar box stuck to the floor. it holds two drinks if you have company or one drink and some cigars if alone. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Here is what I did. I got a piece of 2 inch PVC irrigation pipe, cut it down one side. Then cut away all the unwanted material. Carefull use of a heat gun, and I formed it to my coffee cup. The one tip I have on this is get a piece of pipe longer than you need. That way you can leave a long tail at the top, later to be bent over at 90% and attached to the dash. A couple of hours with a rasp, sandpaper, and paint and you have a cup holder that looks as good as any you can buy, plus you can customize any way you like. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I was wondering where my cup holder went.
Cheers Mapes
| | | | | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | I use a roll of duct tape. It doesn't move on the floor and holds my drinks without tipping. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I just got one of those fat-bottom cups with the rubber bottom to sit on the floor. They don't move around. Another option would be to get a pardner to ride with you to hold the cups. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Your pardner may empty the cup before you round the corner
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Here's a link to the custom cupholders in my 59 gmc. cup holderI spent a few days tinkering around at a machine shop. Although not terribly pretty, the cup holders are invisible when not in use, and no holes were put in the truck to install the holders. I can get anything in there from a standard Coke can to a Super big gulp and everything in between. I wanted at the very least to be able to hold a cup of coffee and the "trucker's restroom" gatorade bottles.
| | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Wow. I like the in dash cup holder. May have to try that out some time when I get some time. But I will toss a role of duct tape in for the time being. Thanks for all the input. I sure need a place to put my coffee in the morning. Its a long drive sometimes so I need a little wake up.
Once again, Thanks | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | "sausage fingers" did a nice job
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | nest he needs to install a passenger (camera operator) holder. He almost lost it under hard brake conditions. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Yeah, My friend Ted who was filming was a little nervous. The cup holder was built from scratch as a brain exercise. I looked at many ready-made options on ebay and in the bone yard. In the end I decided why not make my own, as all the vehicle pullout cupholders are plastic. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I just use a pop bottle with a screw on lid. Don't allow cups in my cars/trucks.
I love the roll of duct tape! | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | http://video.search.yahoo.com/video/play?p=youtube%20red%20green%20duct%20tape&tnr=21&vid=1059819421813&l=442&turl=http%3A%2F%2Fts2.mm.bing.net%2
Duct Tape Guru. Red Green I'm sure this guy has many cup holders made with a roll of duct tape. Have a look just for fun. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Sort-of on topic, but on some early model trucks from what I have seen is that there are some glove box door that have shallow indents in the interior side that "while" parked you could have a place to rest your drink, or keep it from sliding on a slight incline. I've only seen them on a few models. Not very often or many, sometime I wondered if I imagined them.
Anybody have these? | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I just throw the roll on the floor but I am sure you could be creative (Red Green?) and construct a sling to attach to the door or dashboard. Fancy Engineering
| | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 | I have an idea. If you have an ash tray and do not smoke, why not replace it with a pull out cupholder or just cut a hole in it with a drill with a hole saw bit. It would probably only be big enough for one drink, but it beats nothing! My granddad just got some plywood and made a deep tray with various sized compartments and small holes for things like pens. its not pretty, but it works or you can sand and paint it and make it look pretty, or you can make it out of something flashy but manly out of diamondplate | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | I got this from Kennys' Trucks in Tulsa, Ok holds my beer and keeps my pistol tucked away, glove box will be gone after vintage air install.....it is a good arm rest too. It only straps in place and can be moved if need be. About $100.00 Kieth http://kieth.smugmug.com/Trucks/66-GMC/13311086_gRF57#1438206736_rjGkFPB-XL-LB
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Kieth: Very nice, I'm going to look at that. Thanks for the picture and source. don
| | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | I like that. Nice and clean. Ill check it out
| | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 |  Cup holders are very important! | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Best cup holder I've ever had has done a great job for nearly 28 years now. Only cost me my freedom and a couple of gold rings.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Stumbled across this on Ebay. Interesting, says it vintage but I've never heard of such. But then, there are lots of things I've not heard of.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 | That is one expensive cup holder! $168! I would rather build one than buy that one on ebay! I do like it though. Does anyone know what vehicle that cup holdeer is off of?  | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | ya. The price is a little high. But A good idea it is. I will use that as a templet to build one. | | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 | Hey GrandpasTruck, give us plenty of pics if you do build one! | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Why not start with a six-pack muffin tray? Hahaha. I do like the look of that tray though, neat idea. | | |
