| | | Forums66 Topics128,090 Posts1,056,024 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | well gents, i ended up selling my 39 1/2 ton and got a 38 1/2 ton. it has the 235 motor, automatic tranny, the guy had put a different ear end. when i got it it needed some repairs to make her run, i had the gas tank cleaned, carb rebuilt, i checked fuel pump. starts up. my sons help me on this one too... QUESTION: automatic tranny does stop on park. it still moves, the old man told me cabling issue/????? http://i186.photobucket.com/albums/x315/oldmemoriescc/0728011841.jpg?t=1311951791 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Depends on what tranny set up you have. It may be that the linkage needs adjusting to let it go all the way into park. I'd put wheel chocks under all the wheels, or put it on jack stands, and disconnet the rod to the lever on the side of the tranny. Then see if the "arm" will move into the park position and if it does then see if the wheels spin or not. If they don't then adjust the lever/rod to the "arm" on the tranny and you should be in business....depending on what your running or if its a aftermarket kit that you can adjust...or you may have to buy one.
I should have ask if its on the column or in the floor!! | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Like Alvin says, good chance it's in the linkage. I've done a few homemade setups, and getting the rod just right is tricky. Good news is, nowadays you can buy an adjustable shift linkage setup. But, are you using a floor shift or a column shift, and what kind?
Sorry to see a '39 go away, but that '38 it Sharp!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | | | | | | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | | | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | thanks to all, i am still working on the truck, my sons and i put the gas tank on, redid some gas lines and today will give it a tune up. as for the shifter, from my understanding its a camaro shifter on the floor. i did see the cable that leads to the tranny which is all home made, i will try to adjust it. thanks to all | | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | Very nice truck you got there. | | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | thanks...im going to replace the fuel pump. anyone have one with a glass bowl for sale? | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Now that is Art Deco!...no matter what Chevrolet says! Sweet! | | |
