Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (MTD91, FAST55, frogfarmer, Jon G, cmayna, ndkid275), 121 guests, and 4 robots.
Topics128,288
Posts1,058,570
Members48,492
Page 39 of 177 1 2 … 37 38 39 40 41 … 176 177
Originally Posted by TooMany2count
These old bones along w/all the replacement parts I have just don't move as fast & hurt a hellva lot quicker then they use to.
I never realized that it took 5-10 minutes to get up off the floor.
BUT, I did get about 98% of the welding done on the front suspension cross member.
Gotta weld a few small places, grind down & re-weld any bubble gum looking garbage that might be there.
Then the rear suspension goes back under it.
I SEE PROGRESS yahoo ...joe
Joe it seems as we get older our work periods get shorter and our rest periods get longer. lol
~Jim
Spent part of yesterday and today chasing down some electrical gremlins.
The alternator quit working. Got that replaced with a one wire unit.
The turn signals and all the lights in back had quit working. Found a bad connection. Also found one of the parking light bulbs was back feeding, making the turn signal light up when the parking lights were turned on. Also ran a ground wire from the truck frame in back to the frame of the (tilt) bed. That took care of the lights in back.
The joys of rust and corrosion on 60+ year old equipment!! ohwell
Then spent some time getting it cleaned up, as it's going in a parade tomorrow.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
While waiting for parts to come in to finish Jaunita..I finally finished the wooden side rails. Looks good,can't wait till I have the vineyard logo painted on the door and the wine barrel in the bed on it's side,cut in half & hinged for a took box.
Just wanted to share...see pics below if you would like.
http://i1091.photobucket.com/albums/i381/snipewarrior/P1010125.jpg
http://i1091.photobucket.com/albums/i381/snipewarrior/P1010127.jpg
http://i1091.photobucket.com/albums/i381/snipewarrior/P1010128.jpg
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
I replaced the choke and throttle cables today. The choke cable was easy since it was still hooked up, but the throttle cable wasn't hooked up. I couldn't find where the throttle cable attaches to the throttle lever on the back of the carb.
The throttle cable goes through the hole in the throttle rod where there is probably a cotter pin now. Then a little chilibob goes on the cable below the throttle rod.
The chilibob.
The chilibob.
We always called it a "thingamagig". lol
~Jim
Busted out the paint stripper and got the drivers side of the bed stripped.
There were a few layers of paint,and it took a couple of applications.
The metal does look really good,no holes thankfully!
I'll try and get it primed up tonight,it's been pretty damp/humid here recently,so I don't want flash rust to form....
More pix on Flickr.
That's exactly it! No chilibob, just a cotter pin. Does anyone still use the throttle cable, should I just leave it disconnected?
Moderator
Happy Birthday Leo
Moderator
I have my throttle in place, handy when PTO work is involved.
Today I found a pair of seatbelts out of a 1987 Chevy pickup. Will be putting them in the panel.
The chilibob.
I call it a dohickey.... grin
GMC: Get More Cash...
1958 GMC
My Webshots photos
Door hinges blasted and primered.
Got motor to storage and all body parts to sand blaster.
Nothing,still collecting parts !
Tim
1951 3100 Chevrolet
I got my frame painted! I used flat black Chassis Saver. If you brush the flat black on it comes out streaky. It does say that in the instructions which I didn't read. I've used the gloss black before and that goes on great with a brush. So I scuffed up the 1st coat and sprayed the 2nd and it turned out real nice!
1955 6100 Frame
1955 Chevrolet 6100 Wrecker
More pix on Flickr
"A good mechanic doesn't know everything, but he can figure out anything". ~ --My DAD
1955 Chevrolet 6100 Wrecker Video
1955 Chevy 6100 Wrecker Update Video
I added a a amber marker light as a turn signal at the rear end, eliminating several problems I have been having with the horrible wiring. Now stop, tail, and turn have their own filaments. I like how it looks, and am thankful it works well.
Alex
57' 3100 (The Bondo Bandit)
Bad rust and worse wiring, but so much fun.
4 more rivets to remove and the cross member comes off. Then it's cut and Camaro clip time.
V
V Offline
Washed and waxed the cab and front fenders.
sanded primer/surfacer on '67 bolt, thought about driving the Big Bolt...
Keith
If it were easy they'd have grade schoolers doing it!
back yard wrench turner
put on 4 new tires to replace the 45+ year old ones on my '38 1 ton.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Wheel cylinders for brakes. One went to leaking, figured I might as well tackle all of them.
sandblasted the west coast mirrors on the firetruck,
working on the doors to get the winders windin' up and down...
painted the mirrors with a new product....
Spraycan 603 Stainless steel paint...see how it looks in the sunlight later on in the week!
1958 GMC
My Webshots photos
Installed a repro (nice one) condensor tank, every time I parked after a drive the radiator would bleed a tiny bit of coolant well the can solved that.
http://community.webshots.com/photo/2172412050102454676WsKHxg
I did some touch up painting on the bed and painted the front splash panel. I wired the horn and ran the AC/heat vent cable. Now the AC is set, I just have to run the wire to the compressor. This weekend will be a busy time around the old garage here.
~Jim
I drove my truck to work today.
Moderator
Happy Birthday Leo
Moderator
I drove my panel to the mechanic to get certified. I hope she passes but I know I need to get the speedo working. I had her going 55mph, according to my son behind me.
Sounds good, keep your fingers crossed.
~Jim
I made a list of things I need to get done this weekend on the '53
Parked it at home and started cleaning out the mouse nests from the cab.
Wayne
1989 Silverado
Moderator
Happy Birthday Leo
Moderator
Checked with my mechanic to see if the panel passed the safety check, he said I can pick up the certificate on Saturday. I just need to get the speedo working but he said he would overlook that as long as I will get to it soon.
He sounds like a "good old boy"; just what we need in this sport.
~Jim
woo hooo, finally got both mirrors on the panel.
Installed the drivers side mirror, and replaced all the door panel bolts with stainless dipped in oil (I had a time getting the original ones out...) The mirror is the most chrome I have on the truck lol
Alex
Moderator
Happy Birthday Leo
Moderator
I had to pull out the speedometer drive gear. That meant pulling off the torque tube. The drive gear is all mashed from someone putting in the wrong speedo gear, funny what damage a 12 tooth gear will do when you need a 13 tooth gear.
I also picked up the new license tag, so I am officially road legal, small consolation when my truck is on the hoist sans transmission.
Got the driver side rear fender stripped and primed, the LH bed side stripped,primed and painted.
Measured clearances three times for my new wheels before I order them tomorrow(Monday)as I got the go-ahead from the 'Boss.'
I'm going for these in 18x8" with 235/45x18 rubber.
What do you think?
More pix on Flickr.
Dalyman, was the oil to keep the bolts from ceasing up?
~Jim
Jim,I lubed my stainless bolts with a copper based grease when I was assembling my truck.
Stainless bolts can gall the threads when screwing them into mild steel captives etc.
Don't ask how I found that one out......
More pix on Flickr.
I removed the spark plugs to put in penetrating oil.
I found #3 plug covered with rust. It may have had a blown head gasket when it was parked in 1965.
Wayne
1989 Silverado
Jock, I think they look good. Sort of reminds me of the old Cragar mags from "way back when" and it also reminds me some of the S-10 wheels I have on the 37. You ever think of looking at the S-10? They have several "mag" type wheels depending on years and may save you some money.....oh, I forgot that the "boss" gave you the go ahead. Hurry, before she changes her mind smile
Alvin I don't know if you saw the UK prices for the Rocket wheels, I wanted a similar size Cragar 5 spoke and they want nearly £400GBP a corner!
And that didn't include rubber!
I can't go smaller than 17" diameter due to the lowered spindles.
I chose the grey for a slightly more retro look,and bear in mind as S-10s never made it over here so the wheel vendors don't really cater for them.
Update; I ordered the 2 rear wheels today,I wasn't totally convinced the 8" wide rims will fit the front so i'll try on one of the rears before I buy the fronts.
There's a 7" wide wheel available if I have any issues with the 8"s.
More pix on Flickr.
I also got the left rear fender painted and started cleaning up the bedside strips.
Turns out they're not nearly as bad as I thought.I might be able to save them.
More pix on Flickr.
