Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (farmallb, Lostbuthaulinass, Bill Hanlon, TexasJim50), 40 guests, and 4 robots.
Topics128,010
Posts1,055,251
Members48,418
#751217 06/01/2011 4:54 PM
Any tricks to sliding the door rubber in to the track on the body? 52 truck
joes1952 #751222 06/01/2011 5:12 PM
I haven't got to try this yet but have been noting suggestions since several people have commented about struggling with this task. For starters, make sure the factory pinched areas are opened up. You should find a few of these on each side. Take a small piece of the strip and see if it will glide throughout the entire channel. If not open those areas a little. I used a old screwdriver with the tip bend over at 90 degrees to open the factory pinched areas. Lube the rubber with soapy water or some other lubricant. Don't use silicon if you plan to paint anytime soon. Some people apparently have been able to start at an open spot and feed the rubber both directions. Others have resorted to poking it into the channel with a blunt tool. I am still a ways off from installing the rubber myself. Good luck and let us know how it went.
Chuck
Hookalatch #751279 06/01/2011 8:46 PM
As noted above the Factory Assembly Manual has a diagram for how to do it and where to pinch it. I used K-Y 0n a Q-tip that I wiped in the track not on the rubber. Note this was after paint I had both of mine in after about and hour.
Brad Allen #751340 06/02/2011 12:26 AM
Ex Hall Monitor
Ex Hall Monitor
You mean there's TWO uses for KY???? not me
Tiny #751357 06/02/2011 1:52 AM
I used WD 40 worked great!!
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Charley #751417 06/02/2011 4:08 AM
...and even windex will make it slick as cow slobber if you wet it down good.
Achipmunk #751499 06/02/2011 3:50 PM
Just did this on my COE and the above answers contain the keypoints. First, make yourself a two inch long segment of the new or old rubber and slide this along the track. This will locate all the pinch points, some you won't have detected at all. Open those up with a screwdriver or other tool. I used Windex for lubricant, works great and doesn't leave a residue. I started at the upper rear open area and fed the rubber down the relatively straight rear area. This will give a feel of what it will be like. I would add that to have two people will make it go alot faster and easier. Once you get a good length in the track, you need to pull at the leading edge of the rubber while you feed new rubber at the rear. Two people do this much better.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Achipmunk #751501 06/02/2011 3:52 PM
Hey, why not use cow slobber?!
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Tom R #751582 06/02/2011 10:32 PM
When I was a kid (back in ought9) there was a saying "slicker'n snot on a gold tooth".
Sounds pretty slick to me.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Moderated by  ndkid275, Phak1
