2 members (TexasJim50, Gdads51),
108
0
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | I have a door handle with lock for a 36 truck and I'm looking for someone that can make a key. I don't think that a locksmith would have the correct blank?
Help! | | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | I'd give an Ace or Truevalue a try. I bet theres a blank that would work. It probably wouldn't say Chevy on it, but it would be worth the try for $1.50. Try to take it somewhere that uses an old manual machine to cut it though
Alex 57' 3100 (The Bondo Bandit) Bad rust and worse wiring, but so much fun.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you don't have a key to copy, you'll need a good locksmith, any locksmith will have blanks that will work, most should have OEM shaped blanks - the originals might have said GM, but not Chevrolet, most said Briggs and Stratton or BASCO, who started making auto lock cylinders and keys for the industry in the 20's
Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The ones Bill describes pop up on eBay fairly regularly so you can get them there and have them cut by the locksmith to your tumblers. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Tell the locksmith that you need a B10 and B11 blank. I forget which is which but one is the hex end and the other round. The hex is the ignition/door, the round the glove box (and trunk on a car). If he doesn't have, or can't get, B10 & B11 there are modern equivalents.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | B10 is the hex head and B11 is the round head. They were used in all GM cars from 1935-1966. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | A lot of the parts vendors have New Old Stock blanks that they sell... so, poke around on those and see what you can find.
Then you can take the blank to the local locksmith to have it keyed properly.
someone already mentioned them for sale sometimes on eBay.
-W | | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | My locksmith here in Blairsville,GA made a key for my 37 door lock. This town is so far off the beaten path that they have to pump in daylight. Go figure | | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | You guys are great! Thanks for the info and advice. I will try to get a blank at the local hardware or Chevy place and find a Locksmith. B10 or B11
Thanks again | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I've seen vintage locksmiths at the automotive flea markets. I have original keys for my 1967 Beaumont with the knockouts still in them. (The octagon key says Briggs and Stratton and the round key says Rochester Products Division) | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | a farily old reputable locksmith should have what you need. Just last year I needed 3 cut for some old locks and an old gentlemen "fixed me up"... for $7.50 per lock. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The key blank itself is common. I recently bought a bunch of them. If you find someone with the code book for 1935-66 I'm sure he'll have the blanks. | | |
