4 members (delwrench, Southerntruck, cmayna, dt235sd), 123 guests, and 3 robots.
Topics128,142
Posts1,056,490
Members48,442
#741598 04/22/2011 4:05 PM
Any tips on removing the rear bearings and oil seals on a '53 3100? Having a hard time with it.
You should be able to pry the seals out with a small pry bar. If you have a slide hammer, that would work to, just reverse the jaws.
If the rear end is apart, stick a 6' piece of pipe through and beat on them with a sledge hammer, knocking each side out from the other side.
Jeff
My 1953 Chevrolet
1947.1 Gallery
ODSS Lawman
ODSS Lawman
Goto you local FLAPS like Advance Auto and you can borrow a 3-jaw slide hammer. Make sure you get a 3-jaw, makes the job much easier.
Like this......
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
use a crowbar... and sometimes you can use the claws on a hammer.
If you're replacing the bearings, this is the fastest and easiest way to remove them. If you're only replacing the seals, use a seal puller. A small prybar or large screwdriver will work, too.
Bill Burmeister
ODSS Lawman
ODSS Lawman
I should also mention that the cost for using the tool I mentioned above is FREE!!!! You put a deposit on a credit card for the cost of the tool, and it is returned to the card when you return the tool.
Do your self a favor and use the tool that was designed to do the job. Not only will it be done correctly, but will be easy.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
H Online: Content
Once you get the bearing out, don't count on re-using it. The housing that holds the rollers in place usually gets damaged in the process of removing the bearing.
Got the loaner tool and 10 minutes later everything was out! Thanks for the info. Putting everything back together today...new bearing and seals...total cost from Classic Chevy parts was $109 including shipping. Thanks for all the help guys!
