6 members (UtahYork, 78buckshot, dt235sd, Goach2, pauld, 1955 1 Series), 52 guests, and 4 robots.
Topics128,185
Posts1,057,286
Members48,467
Page 35 of 177 1 2 … 33 34 35 36 37 … 176 177
Can't wait to do the same with mine.... I'm jealous Achipmunk... wink
....drove the 37 home from my nephews. Yes, I smoked the tires!
Alvin, you dirty wascal!
~Jim
The front fenders, both inners and outers are primed and ready for paint, hopefully today!
Showed the ’65 at a car show for the first time on Saturday, what a blast.
More pictures to follow…………………
’53 5 window
http://s783.photobucket.com/albums/...%20pickup%20project/?albumview=slideshow
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Brake lines installed and thought about how I was going to fix the rust inside the cab & under the windshield. =(
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
I always seem to have the greatest intentions.... should have been able to get everything done I wanted but other peeps projects become more important this time of year....
I did get the Block ready for the second tanking.... hopefully will get it bored by friday... can't mock up pistons until the block is done.... sheesh
the block does look good...
pic 1
Last edited by cletis; 04/12/2011 6:17 PM. Reason: Repaired one link. Couldn't figure out the second one.
Replaced all the Ignition parts under the hood Timed it then took it for its first drive. Bloody fantastic feeling grin as wide as the grill. Now found my speedo doesnt work, My thanks too this board for all the help getting me too this point
1954 3600 With 1950's Powers of St Louis Utility Bed.
My truck
Installed the headlights, still need the beauty rings and junction boxes. Tonight continued frustration with the electric wipers, still looking for defroster stand-off clips.
~Jim
The ‘53’s front fenders, both inners and outers are painted and assembled. The passenger side is resting in place, waiting to be bolted up tonight.
Working on the radio in the ’66 and adding door speakers. Also removed a rusty spot and added a glass patch to the bottom of the door.
’53 5 window
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Well congrats ryan. They are alway great to drive unrestored. Not a worrie in the world. Dont even care if anyone touches it.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
Got the headliner installed. Now the dome light.
Weeds
Got the driver's side window in. Now I need to find some shorter bolts to hold the window regulator. The 1.25" are too long and won't let the window go all the way down.
While attempting the passenger's window I managed to crank it down pushing the run channel down enough to break off the clip on the bottom of the metal channel. I guess I'll have to put a screw in the run channel to hold it down there.
~Jim
Hi crew, ive been struggling fitting a patricks rear end kit..found the rear springs, and everything is a little knackard¬! ive a 3100 panel truck 1953, running a 235ci...
ive booked a two weeks holiday starting tommorow and hope that by this time next week ive left the u.k for france it her! hard work waiting for parts when they take upto 10days!
tommorow im ready for the shims and lash set up before the final install.! cheers Dano! u.k
1953..panel truck.I love my truck!...
See if you can get ole Jock-the-Scot down from Scotland to help. Tell him it was my idea. grin
~Jim
Leo Offline
Moderator
Moderator
Hey Joe, hope you are up to it after your surgery. Hopefully you can do more than simply unwrapping it.
Run some tests on the 235 tonight and it looks like #2 cylinder had a bad wrist in,rod bearing or cracked piston. It has what sounds like a loose rocker arm with no load on the motor,dont know how long its been like that but I think a couple years so if I want to go to Flint in july it will be getting another motor.
Thanks for offering my 'services' BIG, I'd love to help Dano,but i've got more than enough to do here! wink
More pix on Flickr.
Washed the winter crud off my '48 and took it out for a nice run.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Rebuilt my Rochester BC carb (with auto choke, fancy!) sitting on the shelf. The old Carter YF has an air leak around the throttle shaft and would not idle right. Once the BC was rebuilt and installed, the old girl sounded like a dang sewing machine. HUGE improvement.
p.s. - anybody want to put a bushing in the YF?
I started trying too remove the gauges there must be an easier way trying too fit my 6ft 5 frame in there with ham sized hands
My truck
If your working on an AD truck it helps to remove the radio grille... .may take a little longer but beats standing on your head taking it out or putting it back in!!
Achipmunk unfortunatly its a 54 3600 so solid dash :o(
My truck
I drove her to breakfast with my grandaughter, Washed her up after the hurricane winds and rain, finaly made her really jealous when I parked her in the garage and got in the wifes new jeep to go to a B-day party.
Hope she starts up tomorrow.
Have a great week-end everybody.
Proud Southern Stovebolter
Share the past for our future:)
1964 C10
http://s679.photobucket.com/albums/vv153/chrisgardner07/CGG_64C10/
Ryan,
Add a signature to your posts telling us what your Bolt is. That way you get better information if you have a question. A few pictures, if you're proud of her, would help as well.
~Jim
Drove me and the boy to get donuts for the family this morning. Took grandma on a ride this afternoon. It was good to just drive it and not work on it.
Big Chev Sig and photo linky added :o) Cheers
My truck
Ripped out the radio to access the wiper motor, cheap aftermarket pos....replacement was totally wrong....GRRRR....
Finally worked up the courage to drill a hole for the factory attenna...everything worked out fine!
mounted a NOS RARE Washer bottle and foot pump so I can wet the wipers when I finally get them to work!
still have to install my amp guage to replace my Genny Idiot lamp and a better looking Oil pressure guage....
GMC: Get More Cash...
1958 GMC
My Webshots photos
1 Offline
The underbed fuel tank is complete, so I put the Wood back in the bed and installed the new Fuel Door thumbs_up
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Good work there on the bed Todd. I will be doing the same thing soon. I've been worried that the hole will need to be cut through one of the metal bed-strips. I did some measurements and looks like the hole will be through one of the boards.
~Jim
Got my gauges out finally, so re wire can proceed, Now I know the job Thing the unbodied hand had before he joined the Adams family. He was on the production line putting in Ad chevy gauges lol. BigChevy How is that wipermotor mounting going as I ordered the same one
My truck
Finally got it in and working. You will have to tweak it to make it fit. It comes with a bracket to bolt to whatever you like. No directions to speak of. I bolted it to the cowl vent brace. Good luck, you'll need it.
Right now I'm busy trying to figure out the air conditioner. It requires using one of the old heater stud holes in the firewall. Unfortunately I filled in all my firewall holes. If you need some pics of my wiper motor placement PM me and I'll send you some.
~Jim
Got my power steering hoses fitted,I had to wrestle them in,there's not a lot of room!
The return was fairly easy but the pressure side was a real PITA!
It doesn't bend too easy!
Still,I got them in,nothing rubs so I should be good to go!
Off to the flaps for a drive belt and some fluid today.
Yet another step closer.......
More pix on Flickr.
Looks great Todd, BTW does the truck still sound as good with the modified exhausts as I did in your YouTube vid?
More pix on Flickr.
Installed the lifters, pushrods and rocker assembly on the 261... Then cleaned-up, painted and installed the manifolds. I need to order new gas lines and clean the tank.
I'm so looking forward to installing this puppy in the truck!
Been trying to install the air conditioner the past three days.
Put insulation in the pass side vent hole and bolted the plate on.
I've been trying to find the hole in the firewall that I sealed up and where the heated bolted on. One of our good Bolters here volunteered to make a template of his and send to me. I may have hair left when this is done.
~Jim
Didn't have much time yesterday but I managed to swap out the water pump and
install the fan and carburator/breather on the 261. The fan blades had to be bent back into place... It all looks pretty good.
Hopefully today I'll get to install the distributor, coil and spark plugs... wondering now, where the heck I put the coil. headscratch
Got the armrests and side panels today. I got lucky in color. They are a perfect match with the truck's color
~Jim
I had my wheels sandblasted about a year ago, they have been under plastic sheeting since, Living in Iowa with the humidity they were covered with surface rust, I got them all clean with my side grinder and a 4" wire wheel, And as soon as weather permits I can get them painted. All thats left are the bed sides wood bed and tail gate, I can't wait till its done. It's been a long process but i've enjoyed every minute. What a great project. Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Finally got engine smoothed out after forgetting to adjust valves during replacement of a rocker arm. Still wasn't right. Tracked down loose spark plug wire. Fixed! (note to self: runs best on six cylinders)
Finished fuel tank replacement last weekend. Idling a bit low right now, could use some tuning, maybe a carb kit and she'll be running a like a sewing machine. Posted sound vid on another thread, forgive me for posting here too...I just can't get enough of it.:-D my 216
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Awesome sound.... I love putt!!!!
Got the 302 Decked and bored.... gotta wait my turn for honing.... hopefully monday....
Pulled Grandpa's home made wood panel off the passenger door and got the door latch mechanism loosened up and functioning again then popped the panel back on.
Dallas Huybregts
Sherwood Park, Alberta
1951 Chevrolet 1300
email
Photobucket
flickr
