3 members (1955 1 Series, KEVINSKI, Charles in CA), 92 guests, and 4 robots.
Topics128,185
Posts1,057,207
Members48,465
Page 33 of 177 1 2 … 31 32 33 34 35 … 176 177
Finally got the 261 block and bell housing mounted on the "not so universal" HF engine stand.
I primed and painted the assembly, Detroit Deisel Alpine Green.
Hopefully today I can run a hone through the cylinders and begin installing a crank and some pistons!
Looking to get the gasket set tomorrow (fingers crossed).
Didn't get anything done to the truck but I used it to haul enough lumber and drywall to build a 12 x 24 room in my garage. I got some slack-jaw looks while loading all that lumber in the truck.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Maiden Voyage a success!! I have worked on my '49 3100 all winter, replaced the whole brake system head to toe, rebuilt the cylinder head, new radiator, starter, etc.
Started it up, let it warm up checking for leaks, pulled it out of the garage & went for a 10 minute drive, no issues, everthing worked as it should! Not going to win any races with it that's for sure, however it was a blast.
One of the best feelings....period!
I can see your smile from waaaay over here!
More pix on Flickr.
well back for parts, broke the first piston ring on No. 6. found 2 bad intake valves. and 1 cracked valve guide. should have held my tongue on the other side. the rest of you have fun. I'll be working on some other part of it the next couple of days.
Drive with Pride. mike j
family pic
Havnt really had time too get anything done on Mine as been working and waiting for parts too arrive lots of big boxes now in garage including EZ wiring harness seat heating pads all the parts needed too completely rebuild my brake system, But like everyone else one job leads too 10 others lol
1954 3600 With 1950's Powers of St Louis Utility Bed.
My truck
looked at it and day dreamed.
V
VEW Offline
V Offline
Put a flatbed on Thor....8x12 steel. Looks pretty good......well, better.
~ Victor
1957 3100 - moved on
My son and I got busy today putting the bed together. We expect the truck back from the paint shop in the next few days and wanted to have the bed ready to bolt on. When we get it put together we will take the boards off and put on 4 coats of Spar Urethane and soak the ends.
http://s729.photobucket.com/albums/ww296/BIGCHEVY3600/?action=view&current=BEDBUILD1.jpg
~Jim
cleaned the windows and drove it
Took the 261 block back to the machine shop and watched them (with my arms folded and foot tapping) correct my cam bearing orientation.
It's been one step forward and three steps backward lately.
Maybe some assembly this weekend...
Leo Offline
Moderator
Moderator
Changed the fuel pump, put on the dual action one for extra vacuum. Now it won't start, even though gas is coming into the carb.
Fired her up today. Started on the first crank!!. Did a little waxing on the chrome!
got the points installed and set. tried to time it but I cant find the darn timing mark, so I vacuum timed it instead. sounds much better now but still ticks a bit. I need to get out there and adjust the valves this weekend.
made a bracket to hold the 12-volt tail light bulbs farther back in the houseing so that the lense will fit nicely. One more to do. Should be a productive weekend. Might pull out my 28 if the weather is nice.
1953 Chevrolet 3100
had a look at a second potential 'bolt purchase today... might go for it... uh oh...
Installed the crankshaft and assembled the new pistons in the 261. I also bought a bypass filter on Ebay.
Getting closer...
You know, I'm thinking I should consider giving my truck a "name" when it's finally put back on the road...
Ah! I got it already!
Lazarus! thumbs_up
This is all I've gotten done on my truck for the last week.
http://www.pbase.com/dennygraham/1954_radio&page=all
DG
Denny G
Sandwich, IL
Put us out our misery.....did ya? grin
More pix on Flickr.
1 Offline
I finished wiring the fuel pump and fuel gauge sending units on the New tank Hopefully this weekend I'll finish the fuel lines.
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Looking good Todd.
~Jim
It's been a while, but we've been working on her. Here's the latest:
Wheels done, hubcaps painted: http://i858.photobucket.com/albums/ab145/BagdadChevy/untitled-2.jpg
seat is in and windshield will be replaced tomorrow: http://i858.photobucket.com/albums/ab145/BagdadChevy/untitled-05955.jpg
she's ready for a spring test drive- this weekend probably.
I just finished replacing the third power steering pump. The truck has not been driven except to drive it out of the garage to keep my wife from going ballistic because of the open pipes. Hopefully this one won't leak and I'll be able to get my exhaust finished.
~Jim
I removed my draft tube and intalled a PCV valve. Worked out great. I can put my hand over the valve cover and feel some heavy vacuum. This will help a lot since I do a lot of sitting in traffic now that Im in California. Also keeps some water out of the oil.
http://talk.classicparts.com/picture.php?albumid=180&pictureid=1520
http://talk.classicparts.com/picture.php?albumid=180&pictureid=1521
http://talk.classicparts.com/picture.php?albumid=180&pictureid=1522
http://talk.classicparts.com/picture.php?albumid=180&pictureid=1523
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
nice job. I have a 53 3600 annd am at a sticking point. Forgive me for not knowing how to properly describe it but the nut that you have to take off to change the seal (and determines the back lash) it has a cotter pin that is between the differential 3rd member and the universal joint. I measured it and it looks like an 1 5/8 but it did not fit, I am not sure if my socket wasn't thin wall enough or I had the wrong size. Any help would be great. Here is the picture.
Jeff
Installed the piston assemblies into the 261.
In process of getting a stock radiator for the '59 from a fellow Stovebolter!
Sweet! thumbs_up
I have been trying to assemble my MarK bed and reached step 23 that involves drilling a 1-9/16" countersink using a 1-9/16" Forstner bit. The closest size I have in my set is 1-5/8” which it seems is just a bit too large. I found a 1-9/16” bit on line at http://www.mlcswoodworking.com/ however though the freight is free it will take 10 days to get here. Well, I guess I have enough to install to keep me busy until then, windshield wipers and elec motor, radio, inside trim, door glass, vent windows, air conditioner, etc, etc, & etc..
~Jim
Well lets see I blocked sanded my frame and then I painted it!!! tomorrow will see how it looks ! then put it all back together !
The Stove Bolt Forum is a great place to SHARE information helpful to everyone who is involved in an old truck project. That old adage," a picture is worth a thousand words" is certainly true here. Anyone that can operate a computer can operate a $40 Walmart digital camera. Be proud of your "Bolt" and of your work; Share some pictures. Give as much as you take.
~Jim
Took the ole '66 out for a spin around the neighborhood. Bought it for $500 (put another 500 in it---needs more!) and it runs like a top!
I hooked up my neutral switch...finally.
http://s729.photobucket.com/albums/ww296/BIGCHEVY3600/?action=view&current=P4010354.jpg
Bought a new (SMALL) halogen lamp. I'll start tomorrow installing the wipers.
~Jim
1 Offline
Looking real good Jim !
1 Offline
I finished the underbed tank install, Ran all new Lines, And had no leaks ! "I did leave my cell phone on the running board during the test drive and lost it" But some lady found it and called so I got it back.
The truck is running awesome now !
welded up some new brackets for the tail light bulbs. I used the stock backet, installed a two point light in the top and kept the single in the lower. z-ed the bracket to set the lower light back enough to allow the lens cover to fit.
I think maybe I should have just bought one already done. grin
1953 Chevrolet 3100
Woooohoooo, got the hood on the panel today. Well, sort of. It is sticking up at the back about 2 good inches but it'll have to wait till another day to get adjusted. I was going to take a pic but had to pull the club trailer to a cruise-in.
Maybe tomorrow I can get a shot or two posted.
~Jim
Earlier in the week got the brakes bled and freed up a stuck caliper, changed the oil and filter and determined that my power steering box has a leak that can't be repaired, so ordered a new one (okay, the local repair shop did all this). Then yesterday I got my muffler and tailpipe put on, mounted the hood and new chrome handles, and spent several hours trying to figure out which belt(s) was squealing. Tightened 'em, loosened 'em, burned my arm on the radiator tank, applied belt dressing, removed the belt dressing with brake cleaner, tightened, loosened, removed one at a time, put them back on one at a time, burned my arm on the radiator tank again, took them off again, put them back on, left them loose, no squeal finally - for now.
Also suspicious of my brand new (Chinese no doubt) ignition switch causing a battery drain and it's also starting to engage the starter solenoid when I go to turn it off.
And, mounted my '46 plate.
Then went for a spin around the neighborhood, no windshield makes for a breezy ride.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
rebuild the master cylinder
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
As I mentioned above I finally got the hood out of the floor after it laying there for 2 years. Now the grandkids are happy as I will not be shouting at them "don't get near the hood"!!!
As promised here is a couple pics.....and boy is my work cut out for me adjusting the hood. I've read all the "how to's" but I may ask again!!!
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0252.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0253.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0254.jpg
Love the color. Alvin
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
