4 members (37 GC, TexasA&M48Truck, TooMany2count, 1 invisible), 76 guests, and 2 robots.
Topics128,110
Posts1,056,574
Members48,448
#734330 03/29/2011 2:44 PM
I've read about POR15 for under the truck, but not to much on the rear axle and diff. I've removed 46 years of grease of grime and the control arms, trcking arm, springs, shocks and mounting plates...ready to re-assemble after blasting and power coating. I plan to use POR15 on those under parts I could not remove. The axle is different and not referenced for that application. Appreciate any advice. Not an off-frame repair.
MDL
65 Chevy Fleetside
I blasted my chassis and rearend and used POR15 on it. It works good. I will say, if there is any grease anywhere on the axle the POR15 will not stick so be sure its really really clean. It makes the rear end look nice and the stuff is tough as nails!
Por would be great but a rattle can worked for me ok.
gazim #735155 04/01/2011 4:57 AM
http://img.photobucket.com/albums/v602/likaroc13/1966%20C-10/100_2332.jpg
mine was blasted...then we just used a rust control rattle can satin black...nothing fancy
Painted mine with rattlecan rustoleum satin red from home depot. Looks great!
JDog #735859 04/03/2011 3:43 PM
A red rear end? Hope I don't have to follow you on a trip. I have a weak stomach.
Aw that was a little harsh. I was just kidding you.
