| | | Forums66 Topics128,089 Posts1,056,367 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 56 | I've read about POR15 for under the truck, but not to much on the rear axle and diff. I've removed 46 years of grease of grime and the control arms, trcking arm, springs, shocks and mounting plates...ready to re-assemble after blasting and power coating. I plan to use POR15 on those under parts I could not remove. The axle is different and not referenced for that application. Appreciate any advice. Not an off-frame repair.
MDL 65 Chevy Fleetside | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I blasted my chassis and rearend and used POR15 on it. It works good. I will say, if there is any grease anywhere on the axle the POR15 will not stick so be sure its really really clean. It makes the rear end look nice and the stuff is tough as nails! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Por would be great but a rattle can worked for me ok. | | | | | Joined: Dec 2010 Posts: 21 New Guy | | New Guy Joined: Dec 2010 Posts: 21 | Painted mine with rattlecan rustoleum satin red from home depot. Looks great! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | A red rear end? Hope I don't have to follow you on a trip. I have a weak stomach.
Aw that was a little harsh. I was just kidding you.
