8 members (Perro, Hush, Lightholder's Dad, John L., Otto Skorzeny, lumbersawyer, FAST55, Hanks custodian),
182
Mod | | | Forums66 Topics128,075 Posts1,056,007 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 21 | I'm finally getting ready to paint the ole girl and install the new oak bed. The truck will be used for pleasure and the occasional trip to Home Depot so I'm not so interested in a show quality high gloss finish but rather one that will look good and be durable. Best suggestions would be appreciated.
"I'm not as good as I once was, but I'm as good once as I ever was". Toby Keith
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | You know, you are going through a lot of trouble and spending good money on oak wood. You might as well put a nice finish on it. A good finish is going to be durable. Mar-K has finish test that they did here. Why not take a look at it. Here is the site. http://www.mar-k.com/wood_finish_testing_i.html | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I used Minwax Helmans Spar Urethane, 7 coats, sanding in between coats. Nice gloss finish with lots of UV protection. You can check out the bed wood process on my site at the bottom. Any questions, just ask!!! Coach Frank | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | coach frank, I'm plan on using minwax on my bed. How much do I need to buy? Will two quarts do it or do I need a gallon? | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I bought a gallon, had some left over. 2 quarts would be real close to finish it off. | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | I've heard marine varnish works great (see Mr. Lang's truck bed here) - it's tough enough to protect wood on boats at sea, so I bet it would be more than good enough for a truck bed. He used Epiphanes varnish. | | | | | Joined: Jun 2010 Posts: 32 New Guy | | New Guy Joined: Jun 2010 Posts: 32 | I used Minwax Helmans Spar Urethane, 7 coats, sanding in between coats. Nice gloss finish with lots of UV protection. You can check out the bed wood process on my site at the bottom. Any questions, just ask!!! Coach Frank I'm curious as to how you came about 7 coats. I did the same thing is why I ask, but I'm just curious as to why you chose 7 coats. I had some rough sawn pecan (hickory) that I had cut down to size. I used Cabot deck stain. Then I put 7 coats of McCloskey's Man O' War Spar Varnish. I will get back to you on how well it holds up in my daily driver once I put it in and get on the road. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I went with 9 coats on mine, using Halmsman Spar Varnish. I consulted with my dads cousins husband, who is a professional woodworker about it, that was the product he suggest (he even gave a 1/2 quart of it). He suggested 8 coats, I went one more as I had some leftover. Took about 2 1/2 quarts total, my truck is longbed 1/2 ton.
Bill Burmeister | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | For what it's worth I used Minwax Helmans Spar Urethane that I got at home depot. The bed was oak and I used the truck as a daily driver. After about 6 months (including an east Tennessee winter) signs of black mold, a bit up cupping and cracking on the ends of the planks appeared. I think I had applied 3 coats.
Nothing was hauled in the bed during this time.
I think next time around I will use yellow pine like the original AD trucks and leave it bare (the next truck will only be a weekend driver).
1955 First Series 3100
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I also used Minwax Helmans Spar Semi-Gloss Urethane (7 coats - do not ask why, I do not know). I thinned it 50% on the first two coats in an attempt to get better "penetration". This seems to have worked pretty well (13 years). However, I have a heavy rubber bed mat and try to keep from damaging the surface seal of the varnish.
One of the most important things to be careful about when applying a varnish as a moisture sealer is to cover all six sides of the board (end edges are especially important and can suck-in a lot of varnish). Also, if there is ever any mechanical damage to any part of the board - damage that breaks through the seal, you will 100%-certain have expansion and contraction from changing internal moisture. Cracking is then assured.
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | A boat restorer friend of mine told me he uses 7 coats of spar-urethane on the mahogany boats that he restores. He says with the sanding between coats you need at least 7 coats to have a durable finish on boats. Being a woodworker myself I know moisture will be absorbed by wood, so all sides need the 7 coats so that moisture is absorbed evenly by the wood. Oak has a tendency to turn black with any moisture that gets to the bare wood. The cupping and cracking again was the result of moisture getting to the wood. If there is an area that the urethane did not fully protect moisture will find it! My bed is going on three years now and it still looks great. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | memdonjo, a fellow bolter,Swradial, turned me on to a little trick several years ago. Stand your boards up on their ends in some of the product your using and let the ends soak over night. I used the helmsman spar urethane in 1999 and it works good. It does stay inside most of the time but it has seen its share of rain..... then, about two years ago, I refinished mine and did like Tim, SWraidal, suggested and the same boards look nice today. Just SOAK those ends. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | My floor is pine and I used 2 heavy coats of Minwax sealer, stain and protector on it followed by 3 or 4 (can't remember) coats of spar Varnish. It hasn't held up well at all. The high Colorado altitude UV rays have done a number on it. I may end up replacing the pine with oak but really don't want oak just because everybody has it. Anyone have a good idea on salvaging the pine? It's still straight. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Dave, I took the boards out of my pickup and took them to the guy who built all my cabinets when I was home builder. He ran them through his planner and took off enough to barely get the old finish off. I measured it and doggone it, you couldn't tell he took any off!! I then redid mine using the Helsman Spar Urethane finish and it still looks nice but I must admit it stays in the shop most of the time. Nevertheless, the planning sure did the trick. I had a couple of small low places about the size of a silver dollar and a paper dollar but sanded those by hand so as to not cut anymore off. Oh, and it was Oak. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I did one a few years back using I think 6 coats of Helmsman-did fine all winter but the summer sun killed it quick, I ended up painting it. I don't think anything other than paint will hold up on a daily driver. | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Agree. We tested numerous clear finishes http://www.mar-k.com/wood_finish_testing_ii.html and none lasted as long as the painted finishes. The black painted sample has been outdoors in the weather 24/7 for nearly 6 years and still looks great. Mar-Ktech | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | what grit sandpaper did y'all sand the in-between coats with? Thanks, Pete 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I used 220 Pete, then used a tack rag to get the sanding dust off. Be careful not to sand thru the finish, just sand enough to get the bumps and imperfections out of the finish!!! | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | Thanks Coach Frank, as soon as I return from New Brunswick I'm starting. 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | As a woodworker, I sure love finished oak in a bed. BUT, unless it's a show truck, as mentioned above, I agree painted is the way to go for a daily driver (like mine.) It is also easy to touch up if you scratch it up.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
