5 members (BarryP, Mike B, ShopRag, Youngin' Tut 59, klhansen), 90 guests, and 2 robots.
Topics128,139
Posts1,056,756
Members48,454
#695590 11/17/2010 3:16 AM
Hi Guys & Girls, I just rescued a 1949 3100 from a untimely death! Hoping to get her road worthy soon. Great blank canvas!
Baffled by one thing though....leaky axle seal! how to you replace it? Looks like the axle retainer is riveted on, drill & remove? Thanks. Great site!!!!
49BOLT #695598 11/17/2010 3:38 AM
Welcome, we like pics too!
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
andy46 #695623 11/17/2010 4:39 AM
Leo Offline
Moderator
Moderator
Hi Kevin, welcome! Not sure about how to seal that axle but I know that a lot of these old trucks leak here and there. I'm sure someone will have the answer.
Leo
Leo #695701 11/17/2010 3:31 PM
Maybe ask your axle question in one of the other forums. I'd try General Truck Talk first. Ol' Cletis will move it from there if he thinks there's a better place for it.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
What Rich said.
49Bolt, welcome to the Stovebolt.
You will need to pull the cover off the rear end. Once inside there is a square looking block that goes between the spider gears/end of the axles, that a bolt must be removed and then the "block" taken out.
Then once you do that you can push in on the offending axle which will be enough to let a metal "C" clip fall down that is around the end of axle and otherwise keeps the axle in when you put it back together. Once you do that you simply pull the axle out of the housing.......that is if your 49 is like my 52 which I think it is.
Also it helps to purchase a shop manual and an assembly manual from one of the vendors. They are about 20-25 dollars.
In the meantime you may find what your looking for in the online manuals. Go here.....
http://chevy.oldcarmanualproject.com/
Hope this helps.
