9 members (klhansen, Tronman, electors, 78buckshot, cmayna, JW51, tclederman, Otto Skorzeny, 1 invisible), 62 guests, and 4 robots.
Topics128,042
Posts1,055,497
Members48,424
#69300 11/28/2006 4:34 PM
I have to rebuild my engine. What I thought was a 216 babbitt motor for my 49 turns out to be a 1960 vintage 235 with matching period head and modern styled bearings, not dippers. The valve cover, however is not the flat engraved type with the bolt pattern at the base. Instead it has the rounded two bolt style found on the 216 motors. Were these covers interchangeable? The engine number is 3769716 (F82 GM 28) and the head number is 3836848 (GM 30).
#69301 11/28/2006 4:44 PM
235's prior to 1954 had the 2 bolt valve covers, same as 216's. The 848 head should be drilled and tapped for the 4 screws on the valve cover so you could use either type.
#69302 11/28/2006 9:31 PM
I have seen a lot of GMC's to 56 with the same valve cover. Seem as GMC may have used it longer than Chevy. Just an observation.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#69303 11/28/2006 10:05 PM
Is the GMC 2-bolt valve cover the same as the Chevrolet 2-bolt valve cover?
#69304 11/28/2006 10:28 PM
I don't KNOW good queston. Anybody know?
user
#69305 11/29/2006 1:48 AM
I don't think so. They call the GMC engine the "long motor" because it's demensionally longer than the Chevy, but I guess the head could still be the same, who knows,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#69306 11/29/2006 2:11 AM
I would bet they are different but I am not 100% certain.
#69307 11/29/2006 4:21 AM
Patrick's shows them for 216, 235 and 261 Chevies but nothing for Jimmies.
#69308 11/29/2006 4:25 AM
Theres quit a difference between the chevs and gmcs. Gmcs are longer, a few inches longer. They wont interchange. But some of the rocker arms can be interchanged, just not all of them as the chev valves are at opposing angles while the gmcs are all in a line.
My 1953 Chevrolet
1947.1 Gallery
#69309 11/30/2006 2:11 AM
I have a GMC engine and a Chevy sitting side by side on my garage floor. The GMC is about 1 1/2" longer, the valve covers are not interchangeable.
#69310 11/30/2006 2:46 PM
As I mentioned over in the serial number thread, swapping a 216 valve cover onto a newer 235 is relatively easy. Most of the vendors sell a kit that includes two threaded studs, two acorn nuts, and a couple of rubber gaskets. You simply replace two of the rocker arm hold down bolts with the threaded studs and put the 216 valve cover on to the 235 engine.
The only reason for doing this is to make the newer 235 look like the original 216.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#69311 11/30/2006 8:36 PM
See that is what I like about this place. You fined ansers to questions, you may not have ever thought to ask else where.
user
buddha #1049350 08/14/2014 6:20 AM
OK, I may need another head. I want to use a 216 valve cover. I want to try to get a "848" head if the existing one on my engine is indeed bad. From what I see on this thread, the "848" head can use a 216 valve cover... is that correct?
This is also my understated, sly way of putting the word out that a guy in N. Ala. is looking for a good 848 head... hint, hint...
buddha #1049361 08/14/2014 12:16 PM
No need to buy any kit. Just use the two studs and associated hardware from your old 216 or babbit 235.
Lots more pictures
