7 members (Gdads51, 55shaker, greenie-reddy, UtahYork, 3B, Peggy M, joe apple),
125
Mod | | | Forums66 Topics128,259 Posts1,058,291 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | I get a rotational scraping sound inside my dash that increases when going faster. I've listened to the sound, and the it seems to originate from the speedo cluster. My speedometer needle bounces around like crazy. I suspect it is the speedometer cable turning the gear inside the cluster that is the problem. What are some measures to take in order to fix this issue? Thanks.
1958 Apache Shortbed Fleetside
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Disconnect the cable from the back of the speedo. Pull the core out of the cable. Put some grease on it as you feed it back in. You may have to disconnect it from the trans. to get it to feed in all the way. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | Well, I pulled the cluster out and put a hole in my brass oil pressure line. Oil everywhere! I capped the line for now, but anyone know where I can get a replacement?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | don't think the metal line will be available, but plastic replacement line at any FLAPS, along with new ends ... the noise could be the speedo head dirty and the cup spun by the magnet scrapping [not a "gear"] Bill | | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | don't think the metal line will be available, but plastic replacement line at any FLAPS, along with new ends ... the noise could be the speedo head dirty and the cup spun by the magnet scrapping [not a "gear"] Bill I've oiled it up and it seems to have fixed the problem. Found some metal line on ebay, but I'll check my local parts store. Thanks!
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | mbarrad, I just got a "kit" from Advance Auto that is the right size. You do have to use the fitting that screws into the oil guage though. Its called a "threaded sleeve" or "compression fitting". This kind of fitting uses no compression "o-ring". I know O'Rielly's has them as well as NAPA. The old ones are hard to get off the end of the old line so a new one just insures it seals off good.
Hope this helps. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Its copper tubing. And as Alvin says, get new fittings. | | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | i have a 63 chevy C10, bought a new speedo cable hooked it up, now my speedometer needle bounces like crazy!!!! from 30-100, and making a weird winding noise, any ideas, first rebuild, young and trying to learn the ropes ??????????
speak softly and carry the biggest wrench
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Did you lube the cable? Your symptoms are typical of a dry cable. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | LMC carries the copper line with fittings. | | | | | Joined: Oct 2010 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 26 | No, but i will, whats the best to use ???
| | | | | Joined: Nov 2010 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 27 | I had the same thing happen on my Impala,I tried lubing the cable but no luck. The noise was coming from the head so I changed the head, same thing so I tried and loosened the head cable about one turn and the noise and jumping needle went away.Hope this helps | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I bought my copper tubing from the hardware store and the fittings from Oreilly auto parts.
Maybe the speedometer head needs the old hardened grease cleaned out and re-lubed.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | any auto parts sells the kit or what ever you need.
dan-pa
| | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Had the same problem when the cable was very cold. Used white lithium grease on the cable. Fixed the noise and eratic needle. Had the same problem years ago, found the drive cable was about 1/2 inch too long and put pressure on the speedometer head. | | | | | Joined: Nov 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 78 | When yours makes the noise, does the needle then get off kilter? Mine migrates so that 0 becomes 50, almost like the hub is being forced too fast for the needle or something. So I disconnected the cable and it just sits pointing at 50 all the time now. I can move the needle back to 0 but it just moves again. 1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in. | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | When disconnected the needle reads 0. When I spin the cable input the needle goes up and returns to 0. Sounds like your head is sticking. I used some WD 40 to get it to spin freely. | | |
