0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 32 New Guy | | New Guy Joined: Jan 2010 Posts: 32 | Can some gaskets be replaced just using a sealant such as permatex rather than a replacement gasket? Gaskets for valve cover, valley cover, or pan gaskets is this reasonable? thanks tom | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I use it on the ends of the intake on a V8 but wouldn't consider it on the pan or valve covers. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Not in my shop! I often use permatex # 2 with a gasket, but nothing replaces a gasket.
Grigg | | | | | Joined: Oct 2009 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 136 | Use gaskets where applicable. A sealant will be a very temporary fix if it works. | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Yes with the right sealant. http://www.permatex.com/brand_right_stuff.htmThis stuff will hold anything, and you will bend the covers getting them back off if needed, its that strong. It works just as well with gaskets to. Don't get it on you, it takes a while to wear off! Joe | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Why would you use an $8 tube of sealer in place of a $2 gasket? | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | We use RTV. New lubricants and Ultra Low Sulfur Diesel penetrate cork gaskets. | | | | | Joined: Mar 2010 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 76 | Gaskets are cheap and the cleanup from a sealant is a pain. I hate cleanin up some jokers sealant mess. Use the gaskets! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ...This stuff will hold anything, and you will bend the covers getting them back off if needed, its that strong..... Joe And how exactly is that a good thing?  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... I agree with Joe H. guys. Unless your a mechanic you will not likely to ever have to pull a pan, or intake, off in our lifetime if we do the job right and while we age the chance of leaks all over the drive way or in the garage are lessened. We've used it on racing engines and once the pan is in place you get pretty good after a while wiping the edge of the pan to leave a pretty and smooth seal that will withstand a lot!!
I DO use gaskets and I usually make individual choices on different jobs..... Just my .02 | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Pans and covers that require a liquid sealant are designed differently than gasketed surfaces. A liquid joint needs a groove in it to act as a bead lock to keep the sealant in place after its cured. Flat, smooth sufaces require a gasket. Also, some gaskets are a factor in clearances between the two parts. My 2 cents, use a gasket when a gasket is called for, Scott | | | | | Joined: May 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 89 | gaskets serve a prupose. if they were not a necessity. then throw it together,and see how far you get. The sealants complement, not replace.
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | We use sealants because we know we will see it back if it fails. We only work on our own fleet. | | |
