Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Peggy M, crenwelge, Wayne67vert), 182 guests, and 5 robots.
Topics128,282
Posts1,058,494
Members48,490
smile Can some gaskets be replaced just using a sealant such as permatex rather than a replacement gasket? Gaskets for valve cover, valley cover, or pan gaskets is this reasonable? thanks tom
I use it on the ends of the intake on a V8 but wouldn't consider it on the pan or valve covers.
Not in my shop!
I often use permatex # 2 with a gasket, but nothing replaces a gasket.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Use gaskets where applicable. A sealant will be a very temporary fix if it works.
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Yes with the right sealant. http://www.permatex.com/brand_right_stuff.htm
This stuff will hold anything, and you will bend the covers getting them back off if needed, its that strong. It works just as well with gaskets to. Don't get it on you, it takes a while to wear off!
Joe
Why would you use an $8 tube of sealer in place of a $2 gasket?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
C Online: Content
We use RTV. New lubricants and Ultra Low Sulfur Diesel penetrate cork gaskets.
Gaskets are cheap and the cleanup from a sealant is a pain. I hate cleanin up some jokers sealant mess. Use the gaskets!
Originally Posted by Joe H
...This stuff will hold anything, and you will bend the covers getting them back off if needed, its that strong.....
Joe
And how exactly is that a good thing?
ohwell
---All pictures---
.... I agree with Joe H. guys. Unless your a mechanic you will not likely to ever have to pull a pan, or intake, off in our lifetime if we do the job right and while we age the chance of leaks all over the drive way or in the garage are lessened.
We've used it on racing engines and once the pan is in place you get pretty good after a while wiping the edge of the pan to leave a pretty and smooth seal that will withstand a lot!!
I DO use gaskets and I usually make individual choices on different jobs.....
Just my .02
Pans and covers that require a liquid sealant are designed differently than gasketed surfaces. A liquid joint needs a groove in it to act as a bead lock to keep the sealant in place after its cured. Flat, smooth sufaces require a gasket. Also, some gaskets are a factor in clearances between the two parts. My 2 cents, use a gasket when a gasket is called for,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
gaskets serve a prupose. if they were not a necessity. then throw it together,and see how far you get. The sealants complement, not replace.
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
C Online: Content
We use sealants because we know we will see it back if it fails. We only work on our own fleet.
